Author Topic: MS 461 "De-Limiting" the Speed Limiter  (Read 16500 times)
Offline ladylake
Re: MS 461 "De-Limiting" the Speed Limiter
« Reply #20 on: August 09, 2014, 06:09:31 PM »
 I don't own a tach and never will, saws should be adjusted to where the cut the fastest in bigger wood and that won't be lean or rich.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #21 on: January 13, 2015, 03:02:15 PM »
So how's that 461 running?  I've been thinking of de-limiting mine, but am tentative.  Have you had any experience taking the carb limiters out?
Boy, back in my day..
Offline John Mc
« Reply #22 on: January 14, 2015, 10:32:10 AM »
4x4 - the "carb limiters" are a different thing than the speed limiters. Carb limiters affect your ability to adjust the mixture, and are easy to get out or modify.
Offline 4x4American
    • Website Link
« Reply #23 on: January 14, 2015, 11:02:17 AM »
I know, i asked about the carb limiters because the stihl's have them inside the carbs on the new ones and are harder to remove.  for example on my husky 346 the carb limiters are plastic and on the outside and easy to remove.  the carb limiters on my stihl 362 are inside the carb and from what I've read aren't as simple to take out, but I've never tried either.  I haven't taken a look at how the ones in the 461 are in there, but I would think they're built into the carb.  I modded the muffler on the 461 and want to fatten up the mixture a hair more, but the limiters dont allow it.  The spark plug color indicates that it's fine, but when it comes summer time who knows what that will do to it.
Offline 4x4American
    • Website Link
« Reply #24 on: January 14, 2015, 11:04:01 AM »
I wouldn't have asked if he had any experience taking out the carb limiters if I thought they were the same thing as the limited coil, because this thread shows his experiences  ;D
Offline John Mc
« Reply #25 on: January 14, 2015, 12:18:48 PM »
OK. I haven't seen the new Stihl limiters. I guess in another couple of years when everyone has switched to auto-tune saws, this will all be moot.
Offline joe_indi
  • The older I get the more I learn
« Reply #26 on: January 14, 2015, 12:32:14 PM »
These pictures should give you the required 'How-To-Do-It' info
Offline joe_indi
« Reply #27 on: January 14, 2015, 12:49:54 PM »
BTW
I started this topic in Jan 2014. Since then I had been experimenting further to simplify the coil mod. I had started a new topic on a simpler method to do the 'de-limiting' with a video uploaded to youtube. I have modded more than 50 461s using this latest method with very good results. Though the video makes no mention of it (wanted to keep it simple there ) additionally to go the whole hog on the mod,  I also replace the standard muffler cover with a 460 magnum cover, replace the standard 0.68 fixed jet with the 0.70 jet of the older HD14 carb of the 046 and then free the limiter caps as shown above to tune the carb for the change in the muffler  and jet size. Andyshine77's post on this thread with the youtube link was what told me that the 461 coil also has an ignition timing advance and I found this was the actual problem to my local 461 users. So, though I lack the tools for confirming it, the wide gap at the 3rd pole eliminates the ignition timing advance and helped the local users get a 461 that they found more acceptable because it now seemed more similar to the 460 that they were used to.
Offline 4x4American
    • Website Link
« Reply #28 on: January 14, 2015, 10:26:07 PM »
Thanks for the detailed reply, Joe!
Offline Wildman Ben
« Reply #29 on: November 18, 2015, 05:56:42 PM »
So I have a few questions on de-limiting the ms 461, I know it would make it a lot easier to tune thats a fact, but I've heard with this saw it adjusts the timing for some reason or another and also when its cutting in the wood it maintains a higher RPM while this pole is active does anybody know anything about this? you could get a higher overall RPM yea but if it is lower when cutting then it doesn't matter to me I'd rather be cutting faster than anything else.
TLDR: does the 3rd pole do anything else besides limit the top end RPM of 13,500 that I might like to keep?
Offline joe_indi
« Reply #30 on: November 19, 2015, 06:06:16 AM »
If you read back on this thread you will find a post by Andyshine77 where he has given YouTube link. In the video the uploader has checked and found that other than limiting rpm at 13500, the third pole also advances the ignition timing. This maybe good for most applications, but in applications here with poor fuel and inexperienced users who are yet to know how to file a chain, it is much safer to eliminate the ignition advance, we faced a very high number of crankshaft burnouts. With the elimination of the third pole or a coil swap, we avoid this.
This recent thread too might be of interest to you.
http://www.forestryforum.com/board/index.php/topic,86302.0.html
Post Script: The overall higher rpm under load is not only because of the ignition timing advance. The exhaust stratification design in the 461 results in much better torque so rpm drop under load is at a minimum. Plus stratification saves 20 - 25% fuel.
Offline ladylake
« Reply #31 on: November 19, 2015, 06:24:05 AM »
 I'd think you'd lose quite bit of power without the timing advance.  Those tabs on the limiter caps grind off in 2 seconds on a bench grinder .  Echo saws advance the timing 30 from start to full rpm , sure wouldn't want to be without that.  Steve
Offline John Mc
« Reply #32 on: November 19, 2015, 08:26:10 AM »
Losing 30 degrees of advance is a lot - you'll lose some power at higher RPMs without it. On the other hand, I've heard the more aggressive you are with the timing advance, the less tolerant the engine is of marginal fuel or "less than optimal" tuning. If fuel quality is a concern, maybe it's worth the trade-off?
Offline Wildman Ben
« Reply #33 on: November 19, 2015, 01:30:13 PM »
Okay well I have good fuel and know how to sharpen a chain properly, is it nicer to keep that 3rd pole for the ignition advance then? I don't know anything about ignition timing / advance or how it works. I like the idea of taking away that 3rd pole mostly for tuning purposes, I find it difficult to tune in the cut. but if the ignition advance is a big plus I will leave it where it is.
A little bit about me and my saw, I run this saw (ms 461) with a 28" bar, I have switched the muffler to a dual port and removed the carb tuning limiters. I have good fuel thats payed for by company and am pretty experienced with the saw and maintanence, cutting production wood up here so the faster I cut the more money I make.
Offline John Mc
« Reply #34 on: November 19, 2015, 02:14:59 PM »
There are others on here far more knowledgeable than I about saw tuning and power, However, I believe if you are looking for the best performance, you do NOT want to disable the ignition timing advance.
As you noted, tuning without a rev limiter is easier. However, you would likely not see any improvement in performance even if you could disable the rev limit without disabling the ignition advance. The rev limiter is typically a factor when operating at full throttle out of the cut. Under load, your saw should not be approaching the rev limit, and that is typically not where you see the max power anyway. (NOTE: if you are running a highly modified race saw, the above may not apply, but from your description, that's not what you are running.)
And now, for the guys who really know what they are talking about in this regard, please jump in and correct me if I've got it wrong.
Offline ZeroJunk
« Reply #35 on: November 19, 2015, 02:56:38 PM »
Watch the video. That MS461 advances from 8 degrees at idle to 16 degrees or so. A stock MS360 which he swapped the coil off of is fixed at 12 degrees.
So, it is not like it has no advance at all.
Offline Wildman Ben
« Reply #36 on: November 20, 2015, 03:35:07 PM »
yea that 360 coil would be nice to have to swap out. I assume then if you remove that 3rd pole on the 461 that the timing would stay down at 8 degrees? which is super low
@joe did you trim the flywheel at all to try and get a more moderate timing after removing that 3rd pole?
Offline joe_indi
« Reply #37 on: November 21, 2015, 11:30:23 AM »
No, I never touched the flywheel.
BTW, I would go with the 460 coil for a coil swap. The  360 flywheel seems to be a bit smaller in diameter than the 460/461 flywheel.
Offline JohnG28
« Reply #38 on: November 21, 2015, 08:13:48 PM »
A good way to tell you are close with your tune is "reading the plug." You want a nice brown colored spark plug after some good use. Greye or white is lean, black or real dark is too rich. As for in the cut, if you have a nice big diameter log have a helper hold it WOT in the cut while you fine tune the carb
Offline gowanus2015
« Reply #39 on: March 10, 2018, 04:24:58 PM »
I know this thread is quite old, but i followed the steps outlined here in order to "de-limit" the MS461 coil and have not been successful.  First i tried making the gap from the 3rd pole larger, next I removed the 3rd pole altogether by cutting it away.  The way I know these modifications didn't work is that I tested it with a tach.  When it bounced off the limiter the tach started jump all over the place until it returned back to normal RPM levels.  Without another coil and spending significant $$ to get a replacement one from the MS460, are there any other tips on how to successfully remove rev the limiter?
