Author Topic: Difficulty sharpening chainsaw chains. . .  (Read 1038 times)
Offline MrWobbly
  • Member*
  • I've used chainsaws since 1978
« on: January 01, 2014, 06:10:10 PM »
I have a Mac10-10, a Stihl 026, and a Stihl MS-460. I have around 75 chains and have sharpened many successfully. However, regarding the MS-460 (35 teeth, 70 skips  105 drive links  3/8” pitch  gauge 0.050”, full skip), lately I just cannot seem to do it right. I use 7/32" files at 30º, I feel the very sharp cutting edge with my fingertip, and the depth gauge is below the cutting edge. The groove in the bar is kept clean and the chain is well -oiled and adjusted. However, I find that in dry, hardened logs and stumps with fibers running every which way, the chain just throws out dust and small chips. What do you think?
Offline 1270d
Re: Difficulty sharpening chainsaw chains. . .
« Reply #1 on: January 01, 2014, 06:15:43 PM »
If you are filing down into the cutter enough providing a decent hook, the rakers are set and everything is pretty even, its probably the wood.
I haven't been able to make a chain pull good chips in big hardwood knots when flush limbing.  Dead, dry wood doesn't cut very nice in the first place and if the area you are cutting has funky grain and knots it all be even worse.
Does it cross cut OK?
Online clww
  • Oh yeah? Watch this!
« Reply #2 on: January 01, 2014, 07:11:39 PM »
Dry, dead wood is the hardest thing you can use a chainsaw on, even if it's sharp.
Welcome to the Forestry Forum. :)
 :new_year:
Many Stihl Saws-16"-60"
18-Wheeler Driver for Knight
Offline CTYank
  • Ain't he cute?
« Reply #3 on: January 02, 2014, 02:06:35 AM »
Also, make sure there are no burrs on the outside edges of the bar rails. They can snag wood.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
Offline Jemclimber
« Reply #4 on: January 02, 2014, 07:28:07 AM »
When the wood being cut is end grain instead of side grain, as happens when cutting knots, swirling grain, or a steep wedge, the saw will through dust no matter how sharp it is.  Stand a log on end and cut across the end grain with a brand new chain or newly sharpened chain, and you can verify this. Chainsaw milling folks see this more.  As long as it's cutting at a good rate, disregard reading the chips to indicate sharpness when in these type of cuts.
lt15
Sharpening chains
Started by mrwood on Firewood and Wood Heating
Last post November 11, 2011, 07:15:17 PM
by lumberjack48
Sharpening Chains/Files
Started by s grinder on Chainsaws
Last post November 07, 2011, 07:36:23 PM
by T Welsh
I suck at sharpening chains.
Started by Firewoodking on Chainsaws
Last post June 13, 2013, 07:03:56 AM
by cuterz
Sharpening chains in the field
Started by bigtrees on Chainsaws
Last post May 08, 2019, 05:55:01 PM
by old guy
