Author Topic: porting an 044  (Read 4046 times)
Offline charleswalton
Re: porting an 044
« Reply #20 on: January 16, 2014, 11:39:50 AM »
How do you measure squish?
Offline Al_Smith
Re: porting an 044
« Reply #21 on: January 16, 2014, 12:44:02 PM »
You put 4 pieces of soft solder on top of the piston .Two in the center over of the rod and two dead center at a right angle .Roll the piston over to smash the solder then use a set of micrometers to measure the smashed solder .Use as thin of solder as will just be smashed not something like heavy 50/50 body solder.
You can buy it in 62 thou rosin core which mashs fairly easy .I'd probabley avoid acid core myself .Solid would work if you can find it small enough .
Offline Al_Smith
Re: porting an 044
« Reply #22 on: January 16, 2014, 12:46:22 PM »
When I said dead center I meant towards the outside of the piston not center of the piston .All that would do is shove it up into the combustion chamber .
Re: porting an 044
« Reply #23 on: January 17, 2014, 07:40:45 AM »
Thanks everyone for the advise.
smiley
359 porting
Started by nuke1 on Chainsaws
Last post November 27, 2015, 12:24:44 PM
by ehp
porting
Started by oakwood productions on Chainsaws
Last post May 30, 2009, 11:53:05 AM
by Cut4fun
Woods porting
Started by Timbercruiser on Chainsaws
Last post June 19, 2012, 09:45:01 PM
by Al_Smith
wireless
Woods Porting
Started by JohnG28 on Chainsaws
Last post January 01, 2019, 06:44:56 AM
by Hartman
