Author Topic: Question for Franklin owners  (Read 1492 times)
Offline plasticweld
    • EmpireGP.com   my other business
« on: January 16, 2014, 05:11:32 PM »
I have a 89 170 that the tag with the serial number is so messed up I can not make out the number to order some parts. My Clark and a stamped number in the frame up front is there a separate location on the Franklin that would have a stamped number? For those of you with 170s I need transmission filters and they tell me there are several to chose from. If someone can tell me a better way to find the filter numbers I would appreciate it. The filters that are in there are no longer made by manufacture who made them and I have having horrible luck with anyone returning any phone calls when trying cross numbers.
 The machine 453 turbo with a powershift it currently has a Schoeder  8339   it has a spring inside, the hole in the middle is 2 inches the outside diameter is 4 inches and it is 9 inches long, there are two of them stacked inside the tank.. Any help would really be appreciated  Bob
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
Re: Question for Franklin owners
« Reply #1 on: January 16, 2014, 06:13:28 PM »
There should be a serial number stamped on the frame ,or cab bottom  looking at the machine from the front ,it would be on the right side, just above the steps. Don
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline BargeMonkey
« Reply #2 on: January 16, 2014, 07:11:17 PM »
Call bakers in OH. Ask for jeff in parts, he has been real good and should be able to help you with parts or knowing where to look for numbers.
Offline lynde37avery
  • machines from the 1970's making a living today
« Reply #3 on: January 16, 2014, 07:24:49 PM »
my franklin is a 1970. its in the little door by the steps on drivers side of the machine. inside like, under the seat area.
Detroit WHAT?
Online Southside
« Reply #4 on: January 16, 2014, 07:53:41 PM »
Try Woody, he is a member on here, and a big help with Franklins.  He gave me the name of a good parts suppler, now I just have to remember where I saved it and I will get it over to you.
Online Southside
« Reply #5 on: January 16, 2014, 07:57:27 PM »
Found it, this is from him, Woody said he knows a lot of part numbers off the top of his head, he purchased a lot of NOS inventory and if he does not have it he knows the cross reference for it.
check this place out  http://forestryconstruction.com/
He ships world wide
Ask for Keith
Online Southside
« Reply #6 on: January 16, 2014, 08:00:08 PM »
He ships world wide
Ask for Keith
Offline smwwoody
  • Makeing round wood square
« Reply #7 on: January 16, 2014, 08:55:24 PM »
Hi
I crossed that number to a Saylor Beall HFI K02A355  that filter is available from NAPA for $12.00.  the demensions they give for it are
Area (sq. inches) : 5
Bottom O.D. (Inches) : 5.88"
Bottom O.D. (mm) : 150 mm
Height (Inches) : 4.75"
Height (mm) : 122 mm
Hydraulic Filter Style : Air Filter
Media Type : Paper
Micron Rating : 5
Top I.D. (Inches) : 3.62"
Top I.D. (mm) : 92 mm
Top O.D. (Inches) : 5.88"
Top O.D. (mm) : 150 mm
I am not sure if this is the right filter it is listed as a hydraulic filter but they call it an air filter.  I will do some checking.  I am sure Keith from forestry and Construction can give you the right part number.  he may even have some NOS franklin filters in stock
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
Offline smwwoody
« Reply #8 on: January 16, 2014, 09:07:07 PM »
Looking at the right side door opening the serial number should be stamped in the cab just behind the door opening and in the bottom of the door opening itself.
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Offline smwwoody
« Reply #9 on: January 16, 2014, 09:20:58 PM »
are you sure the schroeder number (8339)  is a good number.  it does not check out with them as a good number.  i have tried to cross it a bunch of different ways and the only cross i have come up with is the napa number and i dont think it is the right one
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Offline plasticweld
« Reply #10 on: January 17, 2014, 06:29:26 AM »
Woody not sure the number is good, just the one my mechanic read to me over the phone, not sure that the filter that was in there is even right. I will have Leroy call your Keith when you open, thanks for the time and research to help me out...Bob
Offline smwwoody
« Reply #11 on: January 17, 2014, 07:13:48 AM »
Anytime
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Offline plasticweld
« Reply #12 on: January 17, 2014, 01:13:56 PM »
Thanks for all your help filters ordered, I appreciate the good customer service
Franklin winch modification question
Started by Southside on Forestry and Logging
Last post March 29, 2014, 10:45:07 AM
by Brleclaire
Question for WM LT 15 owners
Started by 4speed on Sawmills and Milling
Last post December 01, 2012, 08:15:25 AM
by VT-Woodchuck
Question for TK owners.
Started by Ga Mtn Man on Sawmills and Milling
Last post April 11, 2012, 08:30:30 PM
by Ga Mtn Man
Question for LM2000 owners
Started by Nomad on Sawmills and Milling
Last post January 12, 2009, 09:53:19 AM
by ely
