Author Topic: Husky saws  (Read 2356 times)
Offline shawn55
  • MN logger
Husky saws
« on: January 27, 2014, 09:58:37 AM »
I run a 570xp saw and I know it could be bigger but that's just what I started with. Been looking at a 372xp  looks like a good saw. What does everybody run and how do they like it.
Offline Autocar
Re: Husky saws
« Reply #1 on: January 27, 2014, 12:44:10 PM »
I run 395XP's with a 32 inch bar and 3/8 full chisel chain. Keep them sharp and there cut as good as any saw. Sence the E.P.A. has stuck there fingers in the pot the last few I bought didn't hold up very well just bought another before the first of the year but haven't ran it much. I was considering going back to the other brand but talked with another producer that had two 066's with extra bars ,chain and parts for two thousand said he had alot of problems also so I bought another 395 I can tear them apart in my sleep and put them back togather just very upsetting when you want to make production and the saw gives you problems.
Bill
Offline bandmiller2
Re: Husky saws
« Reply #2 on: January 28, 2014, 07:02:36 AM »
Those EPA yuppies should be forced to work a year in the woods cutting before they make unsound decisions. Frank C.
Offline John Mc
Re: Husky saws
« Reply #3 on: January 28, 2014, 08:19:23 AM »
What is it that's going wrong with the newer saws?  From this and other threads, I gather that you guys are not being caught by the fact that they are often set too lean from the factory. So I assume it's more than just a mixture problem (I'm assuming these are not auto-tune saws you are talking about).
Offline AdkStihl
    • J.Miller Photography
Re: Husky saws
« Reply #4 on: January 28, 2014, 08:23:09 AM »
50:1 is whats going wrong
Offline NCFarmboy
Re: Husky saws
« Reply #5 on: January 28, 2014, 08:39:11 AM »
AMEN!!!!!  Go to 32:1 synthetic non E premium gas and watch a lot of your troubles disappear.
Shep
Lots & Lots of Saws
Offline FWPT
  • I'm new here but love chainsaws
Re: Husky saws
« Reply #6 on: January 28, 2014, 09:55:49 AM »
I run a 372xp xt with a 24" bar and it cuts pretty fast. A muff mod really woke it up! Have run about 20 tanks of 32:1 synth oil and no problems yet. It holds much higher rpms in the cut after the mm. I heard the 570 is pretty stout after some porting or even just a mm.
Husky 42 special ported(screamer)
husky 372xp xt muff modded
Offline nk14zp
Re: Husky saws
« Reply #7 on: January 28, 2014, 09:56:14 AM »
DITTO on the 32:1.
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
Offline HolmenTree
Re: Husky saws
« Reply #8 on: January 28, 2014, 11:22:51 AM »
I rely on 40:1 on my latest XP AutoTunes going right back to the 621 Jonsereds I made a living with in the mid '70s.
But having said that I'm in a colder climate where extra oil is not always needed. Yes hotter climate 32:1, but from what I see across the weather map we're all in a little deep freeze at the moment :D
Offline ehp
  • logger/chainsaw hack
Re: Husky saws
« Reply #9 on: January 28, 2014, 12:37:53 PM »
the biggest problem is ethanol in the gas and just because the pump says no ethanol you still better check it cause I have found ethanol in gas that is not to have any and the biggest problem is the amount of ethanol in the gas , we did a test around where I live and found as high as 28% ethanol in the high test pump gas which was to be 5%, Ethanol does not mix very good with most 2 stroke oil so the ethanol breaks the oil base down so you end up running the motor alot dryier than what you think you are and at 15% lots of 2 stroke oil does not mix with ethanol so that is pretty bad for the 2 stroke engine , the ethanol burns alot dryier than gas so hard on crank bearings so abit more oil in the mix sure cannot hurt and puts a safety guard in there , Most of my guys run 32-1 and no trouble
Offline John Mc
Re: Husky saws
« Reply #10 on: January 28, 2014, 02:42:34 PM »
One of the problems with ethanol gas at least in some parts of the country was that it was "splash mixed" - that is, they filled the tanker with the non-ethanol blend stock, and added the appropriate amount of ethanol to the tanker.  The idea was that splashing it in, and then driving down the road, would mix it up well enough.  This turned out not to be the case in some instances, resulting in the weird mixes Ed refers to.
I'm not sure if it is still blended that way, or if it's been mandated that they use some better means of assuring a uniform mix.
Offline chet
Re: Husky saws
« Reply #11 on: January 28, 2014, 03:39:25 PM »
Our local hauler still does it that way.
Offline SawTroll
Re: Husky saws
« Reply #12 on: January 28, 2014, 03:39:55 PM »
The 570 never was an xp saw.
Information collector.
Offline ehp
Re: Husky saws
« Reply #13 on: January 28, 2014, 06:34:54 PM »
if ethanol gets any worse we will have to start running oil like Klotz which I got gallons of but just didnot want to waste it
Offline shawn55
  • MN logger
Re: Husky saws
« Reply #14 on: January 28, 2014, 08:56:46 PM »
Sorry 570
Anyways just seeing if the 372xp is better than the 570 or what. I've never run a 372xp. I've run the 395xp that's all
Offline ehp
Re: Husky saws
« Reply #15 on: January 28, 2014, 10:32:29 PM »
yes the 372 will have more power , the 570 was to replace the older 365 , the 570 never sold very well up here nor did the 575 or 576
Offline Spike60
Re: Husky saws
« Reply #16 on: January 29, 2014, 07:02:50 AM »
The 570 never sold well anywhere. They even tried to give that saw to Red Max as their "big" saw.
Red Max BTW, is dropping out of the saw category now that all Red Max distributors also have Jonsered.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline husky fan 500
Re: Husky saws
« Reply #17 on: January 29, 2014, 02:46:47 PM »
i couldnt tell u much about the 570. im on my 2nd 372 only because my first one got crushed by an excavator, i loved that saw. the new one is an x tork model, at the beginning it didnt seem like it had any balls. ive been doing some lite mods to it and its starting to come alive.  at any rate u cant go wrong with a 371 or 2 with some small mods
Offline shawn55
  • MN logger
Re: Husky saws
« Reply #18 on: January 29, 2014, 10:00:33 PM »
what kind of mods are you doing. Where can I look to find out what a person can do to for mods?
Offline JakeG
Re: Husky saws
« Reply #19 on: January 29, 2014, 10:13:49 PM »
Personally, I had my 372 modified by a man who does that for a living. I don't have time to modify and/or possibly make a mistake on a $700-$1000 tool :)
$5.00 fine for whinin'
big husky saws
Started by ehp on Chainsaws
Last post October 31, 2014, 08:05:20 AM
by ehp
husky 372 saws
Started by logger444 on Chainsaws
Last post February 22, 2009, 10:35:05 AM
by rebocardo
difference in husky saws
Started by letsgetitracing on Chainsaws
Last post March 03, 2008, 06:52:12 AM
by SawTroll
moved
MOVED: Husky saws
Started by chet on Forestry and Logging
Last post January 27, 2014, 02:06:33 PM
by chet
