Author Topic:   Movable Kiln  (Read 1399 times)
Offline dail_h
  • G-Diddy and the Baby Hurlenator
  Movable Kiln
« on: June 06, 2004, 05:43:54 PM »
   I would like to build a sola kiln, but I don't have my mill-lot too well organised yet,so I'm not sure where everything should go.I have plans for an 8x12 ,my question is,instead of putting it on a permanant foundation,could I put it on 6x6 skids? The plans call for styrofoam insulation in the floor,and fiberglass batts in the walls. Would not ridgid foam work ok throughout?
  It's pretty obvious I don't know much 'bout kilns,so any ideas would be a helo.
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline Carl_B
Re:   Movable Kiln
« Reply #1 on: June 06, 2004, 07:12:48 PM »
Yes you can make you kiln moveable when I built mine we put it on 5 x 12 white Oak skids. we use joist hangers to fasten 2 x 8 between the skids put plywood on the bottom added bat insulation then plywood for the floor.
Some pics. of my kiln.
Offline Kedwards
  • All wood is good wood , Iron Station NC
    • Edwards Custom Milling and Lum
Re:    Movable Kiln
« Reply #2 on: June 06, 2004, 08:30:45 PM »
hate to point you to another website, but here it is..
http://www.woodweb.com/knowledge_base/Solar_Kiln_Designs_2.html
Dr Wengert is pretty knowledgable and has always responded back to e-mails specific to your question.
Give it a whirl..
Kyle
His thoughts tumbled in his head, making and breaking alliances like socks in a dryer without cling free
Offline ElectricAl
  • 1993 LT40HDE15 2012 LT50HDE25
Re:   Movable Kiln
« Reply #3 on: June 07, 2004, 06:10:18 AM »
In our area a Portable Building is exempt from property tax. Just something to think about.  ;)
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
English walnut trees
Started by Left_Coast_Rich on Sawmills and Milling
Last post January 21, 2004, 03:50:53 PM
by D._Frederick
Wood-Mizer  4 deg  blades  ?
Started by Ohio_Bill on Sawmills and Milling
Last post January 11, 2003, 07:56:47 PM
by Bro. Noble
PTO circle mill  Good or Bad  ?
Started by WV_hillbilly on Sawmills and Milling
Last post January 08, 2005, 11:43:56 AM
by Buzz-sawyer
question
Nyle  -  -  Powered Vents or Not ???
Started by DR_Buck on Drying and Processing
Last post February 21, 2005, 01:27:34 PM
by Mike_Doolittle
