Arborwear
Author Topic: Sketchup 2013- where are my shop drawings?  (Read 1222 times)
Offline romanccm
« on: January 30, 2014, 11:04:31 AM »
So I got a new computer, and got the new sketchup program whether I wanted it or not.  Put the TF rubies on, they showed up where they were supposed to- but when I select 'make shop drawings' nothing happens.  Anyone have a clue where those are going?
Offline bmike
    • Mike Beganyi Design and Consulting, LLC
Re: Sketchup 2013- where are my shop drawings?
« Reply #1 on: January 30, 2014, 03:07:56 PM »
Did you install the rubies using the extension wharehouse? Or just copying them into the plugin folder?
You should get a dialog box asking where you want the part saved. If not, something is broken.
www.mikebeganyi.com
Offline romanccm
« Reply #2 on: January 30, 2014, 06:08:35 PM »
Thanks Mike, I installed using the warehouse-- all of the other options show up (make joint, show peg, etc) and shop drawings does too just dosn't seem to go anywhere, and there is no noise either.  Weird.  I guess I will try uninstalling and reinstalling.
Offline romanccm
« Reply #3 on: January 31, 2014, 09:59:21 AM »
So I uninstalled both sketchup and the rubies and then re-installed them.  Same thing- should I take this up with Trimble at this point I wonder?
Offline bmike
« Reply #4 on: January 31, 2014, 02:06:51 PM »
are you not getting the dialog box to save them? really weird behavior, from how you describe it.
www.mikebeganyi.com
Offline romanccm
« Reply #5 on: February 01, 2014, 11:24:09 AM »
Nothing at all.  The component highlights edges in blue, I right click, select Make shop drawings and then the RC menu disappears and nothing happens.  The selected component remains edged in blue afterward. I was able to use it on last version, select the object, make shop drawings and a window would come up with the layout view overlaid by the dialog box for saving options- with the update I got nothing.
Offline romanccm
« Reply #6 on: February 12, 2014, 02:49:48 PM »
All right- this is getting a bit crazy.  I have a brand spanking new computer out of the box, put sketchup on, put TF rubies on and the same thing happens- click on make shop drawings and get nothing.  The button is not grayed out, it closes the menu but then does nothing.  GAH!
Offline bmike
« Reply #7 on: February 12, 2014, 04:55:13 PM »
It might be a permission issue. Are you running SketchUp as an administrator?
I'll email Clark and let him know about this thread.
www.mikebeganyi.com
Offline klpauba
« Reply #8 on: February 17, 2014, 11:08:53 AM »
I'm having the same experience -- loaded just fine and appear to work but I get no shop drawings.
Offline romanccm
« Reply #9 on: March 03, 2014, 10:19:49 AM »
I am the only account on this computer, so am certainly the admin.  Thank you guys for all the help!
Offline romanccm
« Reply #10 on: March 03, 2014, 12:07:45 PM »
To heck with it, the scripts run fine with my newly installed sketchup 2014.  Thanks for the help!
Offline klpauba
« Reply #11 on: March 03, 2014, 02:32:49 PM »
Thanks romanccm, that fixed it for me too!
Shop Drawings for Rafter Pairs?
Started by jander3 on Timber Framing/Log construction
Last post May 24, 2013, 04:39:27 PM
by jander3
Timber Frame Shed 10' X 12' Shop Drawings
Last post March 07, 2011, 09:22:33 PM
by fred in montana
Drawings
Started by buffhale on Timber Framing/Log construction
Last post May 09, 2007, 02:24:50 PM
by Jim_Rogers
Need 3D CAD drawings . . .
Started by TexasTimbers on Wanted
Last post November 15, 2007, 12:55:33 PM
by TexasTimbers
