Cupcake Pan Chicken Thighs
Started by Mooseherder, February 01, 2014, 08:33:55 AM
Mooseherder
I boned out some Chicken Thighs leaving the skin on, seasoned and cooked in my pizza oven with some wood for smokiness.
They turned tender, juicy and flavor packed.  The cupcake pan holds the moisture in and the meat stews.  Definitely a hit and become a more frequent dish.  Cooking in an oven would be just as good. :)
Chuck White
goose63
goose
thank you to all the vets
pappy19
That's really cool. What temp did you cook them and what seasoning. Did you grease the pan first?
Pap
2008 F-250 V-10
2007 Lincoln LT
1996 Ford Bronco
Kubota 900 RTV
Shindiawa fan
Mooseherder
I use pepper, garlic and onion salt along with Montreal Seasoning on everything I cook.  Chicken and pepper are a natural go together in my opinion.  Dark meat is very forgiving if you overcook a little.  My Pizza Oven is around 450 when I put them in and shut the door and I take them out a few hours later it is around 200.  You may want to put a cookie sheet or tin foil underneath if your doing inside.  The moisture stays in and fills the pan.  No need to grease the pan.
POSTON WIDEHEAD
Where do you come up with these great cooking ideas?  :P
Mooseherder
It wasn't my idea.  I saw in done on BBQ Pitmasters a while back and finally remembered to try it.
Ljohnsaw
I might do that on my BBQ.  I love dark meat but it flares up way too much - especially when there is skin on it.  This way it would not drip and flare!  My household always wants white meat and I've learned to cook it really fast to preserve the moisture.  I hate dried out chicken!
John Sawicky
clww
If I make it in my kitchen oven tomorrow, how long and what temp?
Many Stihl Saws-16"-60"
18-Wheeler Driver
Mooseherder
I haven't done it that way but I think 350 for 75-90 minutes would do it.
clww
My wife came home with a pack of thighs from the store the same day this thread appeared. Looks like I'll be home all day tomorrow from the rain, so I'm going fix them for dinner. I'll update on how this works with a conventional oven. ;)
18-Wheeler Driver
clww
Had the chicken tonight. Delicious, and I don't normally cook! food3
I used a stoneware muffin pan with 12 spaces. I set the oven on 350, and ended baking for 50 minutes. I used the same seasonings, but added a few drops of extra virgin olive oil to rub on the sides before adding the chicken. Leftovers for mid-week.
18-Wheeler Driver
Burlkraft
I also made the thighs last night. Used a little different seasoning and they were awesome.
Thanks Glenn
Why not just 1 pain free day?
clww
18-Wheeler Driver
Ocklawahaboy
One question:  where is the bacon that should be wrapped around those?
Mooseherder
The bacon on top would work nice also.  :)
I've got a chicken recipe that has bacon on it and have made it a few times including last night.
I'll document it and put it on here because my family does enjoy it.
2-3 Boneless Chicken Breasts depending on how many people you are serving.
Remove any center cartilage or bone if present.
Cut the thick Breasts in half.  Pound them down to make them thinner and to the diameter they were before you cut in half.
Season and put aside for a few minutes.
I do these steps so I only dirty one large skillet and use tin foil to make cleanup easy.
Sautee one sweet sliced onion in skillet with butter until desired golden brown.  Put in a tinfoil and wrap up to keep them hot.
You can place on your warmer burner if you have one.
Sautee a package of Sliced Mushrooms for a few minutes.  Cover the pan so the moisture stays in the pan.  I use tin foil for that then use the same tin foil to wrap them up to use in a few more minutes.  Keep them warm on your warmer also.
Pan fry 7-9 slices of bacon and put on a tin foil with a paper towel to soak up some grease.  Fold over the foil to keep the bacon warm.
Dump the bacon grease. Wipe pan.
Now it's time for the Chicken Breasts.  Cook them on medium/high heat for a few moments the turn the skillet down to medium with a lil butter until done golden brown.
When the Chicken is cooked, place the mushrooms and onions evenly on the Chicken, then place the Bacon on top of that.
Finish it off with Provolone or Swiss Cheese on top.  Cover the pan with your previously used foil to melt the cheese.  Let it stew for a minute.
It's ready to serve.  Takes about 45 minutes.
Also goes great on a Kaiser roll.
I used a second pan to cook some zucchini last night on another burner.
Don_Papenburg
Moose, Did you not insulate your pizza oven to retain heat? If I get mine up to 400it will take about 16 hours to get down to 200.
Mooseherder
No, I didn't insulate it and now regret that move.
It works okay but my design has some flaws.
luvmexfood
This really sounds and looks good. I also am a fan of dark meat in chicken. I am going to try soon.
Give me a new saw chain and I can find you a rock in a heartbeat.
Weekend_Sawyer
Quote from: Mooseherder on February 05, 2014, 06:31:25 PM
Now Mr Mooseherder I'm not nit picky but didn't you mean "Dump the bacon grease in an old coffee can for future use"  ;D
Imagine, Me a Tree Farmer.
POSTON WIDEHEAD
Quote from: Weekend_Sawyer on February 21, 2014, 05:52:01 AM
Waste not....want not. (old saying )
Weekend_Sawyer
BACON! Probably the first word primal man ever said.
Mooseherder
I think bacon makes everything taste better but we have backed off using it.
The cost of it is ridiculous right now and we are trying to reduce all the grease intake anyway.
I like a couple strips of bacon on a Chicken Sandwich or Burger but we don't make it with eggs anymore.
You can buy a 5-6 lb Ham portion for the cost of 1 pound of bacon.  It's crazy what folks will pay for fat. ;D
Ljohnsaw
Just made some - Ground up some rosemary and sweet basil and coated them.  Bubbling hot in less than 40 minutes.  Just enough time to make the mashed potatoes and peas to go with them.  Yumm.
John Sawicky
