Author Topic: Im having a little grief  (Read 1298 times)
Offline lyle niemi
« on: February 16, 2014, 06:16:17 PM »
I had some fresh green frozen spruce hauled in. I'm not having much luck sawing it up... the sawdust is sticking to the log and throwing the cut out. Im gonna try putting a new set of bits on and see if that will make a difference.???
Offline mad murdock
Re: Im having a little grief
« Reply #1 on: February 16, 2014, 07:04:18 PM »
I don't have any hands on as a "millwright" around a handset circle mill, though I have done my share of duty on the "green chain"!  A question Lyle; would some sort of lube diesel,soap, or glycol mix help reduce the problem?
Offline drobertson
« Reply #2 on: February 16, 2014, 07:18:23 PM »
I spoke with a 20+ circle sawyer today, he dropped off some pine for me to saw, due to kerf, he wanted max yield. Anyway we got to talking about pine, frozen logs and the such, as it turns out everyone at some point will encounter pain in the rear logs, gonna happen, get through it and be done with it,    david
Offline Ron Wenrich
« Reply #3 on: February 16, 2014, 08:15:43 PM »
Are the logs frozen solid?  The only time I've had major problems is with uneven freezing.  You're sawing some that are half frozen would mean that you are sawing through 2 different types of wood.  The frozen outer wood freezes to the unfrozen inner wood.  When they start to thaw out, it works the same way.  Sitting in the sun may do that.
What is your shank and tooth pattern?  Are you using a standall bit and a summer shank, or a summer bit and a winter shank, If you're not using that type of a combination, your sawdust has too much velocity in the gullet and is spilling out.
You don't necessarily need new bits.  Short bits usually work better in frozen wood, as does less lead.
Offline Coon
« Reply #4 on: February 16, 2014, 09:31:28 PM »
Lyle, try sawing at half your normal speed with these spruce logs and ALWAYS saw from the small end first with these frozen logs.  We have always had issues with frozen spruce and these things seem to help.  Try using a combination of longer and shorter bits if that does not work.  Ron is correct about the sawdust filling the gullet too full and causing just enough binding that its giving you fits.  You may have to take out a bit of your lead too but it really don't take much adjustment.  Remember spruce is a complete different animal even compared to pine......
Offline bandmiller2
« Reply #5 on: February 17, 2014, 08:26:17 AM »
Lyle, perhaps if the logs were just cut you could leave them out for a wile to freeze through and then handle as Ron says. Frank C.
Offline Coon
« Reply #6 on: February 17, 2014, 10:40:12 AM »
 :D  :D  Frank I am sure that these logs are frozen completely through he lives in the frozen north so unless you have been sitting beside these logs with your bic lighter for days on end we definitely know they are frozen.   :D   :D
Offline lyle niemi
« Reply #7 on: February 17, 2014, 02:06:34 PM »
I have things under control again, I had sharpened my bits just the other day and I can usually go a looonnnggg time before I have to resharpen. I decided to hit the bits again with the grinder and that did the trick. I had looked at the bits and felt the bits and I thought they were sharp enough, they were for the dryer logs but not the green frozen ones. You would think I should know by now!! SHEESH!!!! Do I ever feel tupid...lol
Offline Billbob
  • Retired..I need to find a job so I can get a rest!
« Reply #8 on: February 17, 2014, 02:57:24 PM »
                                                 :D :D :D :D :D
Woodland Hm126 sawmill, LS 72hp tractor with FEL, homemade log winch, 8ft pulp trailer, Husqvarna 50, Husqvarna 353, homemade wood splitter, 12ft dump trailer, Polaris Sportsman 500 with ATV dump trailer
Offline Ohio_Bill
  • Wood is Good
« Reply #9 on: February 17, 2014, 03:47:07 PM »
Glad you got it figured out  :)
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor Loader ,Bob Cat 763 , Riehl Steel Edger
Offline bandmiller2
« Reply #10 on: February 18, 2014, 08:47:34 AM »
I don't recall ever having any problems with frozen logs on the circular mill in fact they seem to cut cleaner and it kinda depitches them not so messy to handle the pine. Like you said Lyle and I have found sharp seems to conquer all. Frank C.
570 grief
Started by arojay on Chainsaws
Last post April 09, 2007, 06:56:28 PM
by arojay
Feed problems..new parts..good grief
Started by BB on Sawmills and Milling
Last post March 16, 2014, 09:29:09 AM
by Knute
