AVAILABLE
Author Topic: Cutting Telephone Poles  (Read 8747 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Cutting Telephone Poles
« Reply #20 on: February 19, 2014, 09:50:28 PM »
We used telephone poles back in the 70's to build a pole barn. Not sure where my Dad got all those poles from but we couldn't call Georgia for 6 weeks.
Offline Arbor-Mill
  • Arborist
« Reply #21 on: February 19, 2014, 10:14:33 PM »
I read some previous post about a year or so ago about sawing creasote poles and all the Do's and Dont's and decided that I would do it anyway to atleast form my own opinion.  Customer had 10-20' poles and wanted 6x6's to build a deer stand so I figured I could handle anything for 40 cuts and knock out 600 bf in an hour or so.  I set up up wind but my customer was down wind.  I figured him being a tough old farmer a little creasote wouldnt hurt him.  He actually had burn type rashes around the collar of his gloves and around the collar of his neck.  We finished the job and he actually made an ER visit due to the discomfort.  I felt bad since a little sawmill job cost him a trip to ER.  I guess my point is, you definitely have to keep others in mind as well as your well being.  Good Luck!
Offline Red Good
    • www.cycleonemanufacturing.com
« Reply #22 on: February 20, 2014, 01:26:50 AM »
Power poles and telephone poles treated the same ? Been looking at some poles that the local power company is replacing , thought it may be a good source . Used to them being cedar .
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
Offline Too Big To Fail
« Reply #23 on: February 20, 2014, 08:36:37 AM »
I spent 2 days milling up some fully treated poles last fall.  I wore a tyvek suit, nitrile gloves and respirator.  It was raining, which helped keep the dust down, but after a while the exposed skin at my wrists developed a slight chemical burn.  I definitely felt like I had been poisoning myself a little bit.  Kept an eye out for trash, and only hit one nail.  I might do it again if the price was right.  Not worth it at the regular rate IMO.
Offline NMFP
  • 1895 01 Frick Handset(Steel) 2000 WMLT40SH
« Reply #24 on: February 20, 2014, 12:44:35 PM »
I have cut them but if I do it again, it will be for my own use and no one elses.  Its a real pain in the rear, especially with the dust, the chemical burns and the wear on the machine.
I would run and not even consider sawing them.  There are better jobs out there that have a lot less risk than what you are proposing to do.
Offline hunterbuild
« Reply #25 on: February 20, 2014, 02:02:23 PM »
The western cedar ones we get here are only treated on the bottoms. The upper part is clear of the black mess on the bottom. I'm still very careful and wear a respirator when cutting, and keep the saw dust separate. I use it for fencing and decks. I go over each pole with a metal detector and get out all the metal which can take a lot of time, but we don't have any other supply of cedar here. Store bought is expensive.
Offline Woodbine Saw
  • Member*
« Reply #26 on: March 31, 2014, 10:41:41 AM »
I have a sawmill and live in Airville, Pa. I am looking for used telephone poles. The person I was getting them from can't get them any more.
Does anyone around my area have any to sell.
Nadine
Offline delvis
  • "I jus' 'bout 'magine"
« Reply #27 on: March 31, 2014, 08:09:26 PM »
I can tell you first hand that sawing standard telephone poles (even ones that have never been in the ground but have been treated) is not an easy proposition.  The very first job we took when we bought our second mill was sawing 30 telephone poles flat on two sides.  They were clean and free of metal and had never been in the ground as they were purchased new.  They were treated with creosote and that is the stuff that kills the job almost as much as any metal in them.  I made an arrangement with the person we were sawing for to pay for Wood Mizer's carbide tipped blades plus the sawing which we did by the hour.  Those blades are about $75 each and we bought a box of 5 as I had no idea how many we would need.
Just making 2 cuts per pole I ended up using 2 blades because of the creosote in the logs.  I keep hearing people talk about cutting the butt ends off poles but the standard telephone poles are treated all the way from one end to the other.
Anyway, considering the distance you have to travel and what the job entails, I would steer clear off it unless you can get the customer to agree to have you saw by the hour and pay for the blades you'll need.  Good luck.
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #28 on: March 31, 2014, 08:13:33 PM »
Welcome to the Forestry forum, Woodbine Saw.
Offline Nvfd3052
« Reply #29 on: April 01, 2014, 12:02:44 AM »
Their are quite a few mills around me, and none will cut poles. So I jumped on that opportunity and now that is all I cut. Always where a mask, glasses, face shield, and long sleeves. Stay up wind. Lay down tarps to catch the dust, and haul it and the scrap wood to the dump. It will have to be manifested and they charge me $45 ton. If you dont the epa will have a cow.. Poles are dryer than a popcorn fart so dont use any water or lube on the blade till after the cut is made, then run it full bore for a sec and let the blade spin dry for a sec before you start the next cut. I cut 6" off of the butts,they are full of sand and mud. Just my 2 cents
Woodmizer LT35HDD18 diesel
Stihl ms290
Deere 260 skid loader
01 Chevy 2500hd duramax
And a wife that loves me!
Offline stephen tillery
  • Member*
« Reply #30 on: September 08, 2018, 05:15:59 PM »
Are you still cutting poles? Anything new as to government regs?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #31 on: September 08, 2018, 08:52:08 PM »
The above was his last post and he has not logged on since July 17, 2015.  ::)
Offline Bruno of NH
« Reply #32 on: September 09, 2018, 04:09:33 AM »
I hope he didn't get sick☹
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline Al_Smith
« Reply #33 on: September 09, 2018, 09:42:06 AM »
The guy I had mill me about 3500 Bd feet of ash,oak,cherry is one of three brother who are IBEW linemen and have worked out of Detroit for years .They were able to get the butt ends of 90 feet western cedar untreated poles which had been cut down to 70 footers for reuse .They got a small wood mizer of about 16 HP and paid for the mill plus each one now has cedar lined closets in all their homes plus made some money. The cedar lumber turned out really nice .
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #34 on: September 09, 2018, 02:40:23 PM »
The key is treated vs untreated.  Big difference.
Offline Al_Smith
« Reply #35 on: September 09, 2018, 05:42:25 PM »
Another story .About 35-40 years ago the Erie-Lakawana railroad went out of business and tracts of right of way were sold off .Mainly for the salvage rails etc .One company out of Indiana had some of the ties cut into lumber .Basically new ties only down for about two years prior to the bankruptcy .Those oak sleepers were completely soaked with creosote .Evidently people bought the lumber for farm use .I bought about 400 tons of ballast rock at a $1.25 a ton .
Offline jimparamedic
« Reply #36 on: September 09, 2018, 07:13:12 PM »
tyvex suit glove and respirator is a must. and diesel fuel in drip tank to keep blade clean. then figure what you need to do the job and triple that price.
Offline NewbieSawyer
  • Member*
« Reply #37 on: September 10, 2018, 12:41:53 AM »
I'm also from Canada, Near Vancouver British Columbia. I cut a bunch of poles for siding a decking when I built by house- lovely wood. They were all really old WRC Poles. I wasted anything that was below the "hash" mark. Even if it doesn't look treated the drill holes in the lower part of the pole are for pouring pesticides into, plus what ever it was treated with and then the dirt its buried in- hard on blades. I was choosey about picking the best parts of the poles where it appeared the weather had worn down what ever they were treated with. I would stay away from "fully" creosote or pressure treated.
Offline thecfarm
« Reply #38 on: September 10, 2018, 07:28:41 AM »
NewbieSawyer,someday you will be a oldie sawyer. :D
Welcome to the forum. Whatcha got for a mill?
Offline samandothers
« Reply #39 on: September 10, 2018, 09:47:06 AM »
Welcome Newbie!
Cutting cedar telephone poles
Started by Articcub on Sawmills and Milling
Last post June 22, 2016, 05:21:12 PM
by caveman
Telephone poles?
Started by keddle123 on Sawmills and Milling
Last post November 14, 2010, 07:17:14 AM
by bandmiller2
telephone poles
Started by mac on Sawmills and Milling
Last post September 13, 2005, 08:24:12 PM
by treeboy
Telephone poles???
Started by KjBarnwood on Sawmills and Milling
Last post April 02, 2008, 03:50:29 AM
by Woodchuck53
