Author Topic: QUESTION?  (Read 919 times)
Offline tmarch
  • I'm older, maybe not wiser tho
QUESTION?
« on: February 21, 2014, 11:12:28 AM »
This is probably easy to explain for some, but why do most manual mills have the sawdust exhaust on the same side as the operator walks?  Looks like it would be easier to see and breath if it was on the other side of the track.
THANKS
Retired to the ranch, saw, and sell solar pumps.
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
Re: QUESTION?
« Reply #1 on: February 21, 2014, 11:15:08 AM »
My Norwood exhausts away from the operator.
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline GAB
Re: QUESTION?
« Reply #2 on: February 21, 2014, 11:28:33 AM »
tmarch:
Most mills are designed so that the sawdust exhaust is on the opposite side of the log loader, or log loading side.  Having to shovel sawdust after every or every other log is no fun when the sawdust falls on the next log to be sawed.  Baker bought out a company whose mill sawdust exhaust was onto the next log if it was on the log loader.  I took one look at the design and said this mill is not for me.  I don't have a problem cleaning up, but once a day is often enough.  Gerald
Offline dboyt
  • Log On!
Re: QUESTION?
« Reply #3 on: February 21, 2014, 12:24:44 PM »
Though it is possible to load logs from either side of my Norwood, I prefer to load from the operator's side, and the sawdust blows away from the log deck (or loading ramps) and the sawyer.  Shoveling sawdust is a once-a-day task, if I spend all day sawing.  I suppose this is less of a problem for mills with power feed.  No good answer as to any advantage of putting the sawdust exhaust on the sawyer's side.
Offline thecfarm
Re: QUESTION?
« Reply #4 on: February 21, 2014, 03:48:44 PM »
I have to walk on my sawdust. My mill don't move,so it's easy to clean up the sawdust. No logs or log bed to shovel around. I like it that way.
Online Chuck White
  • Sawing Mobile since 2005
Re: QUESTION?
« Reply #5 on: February 21, 2014, 04:13:47 PM »
The most direct answer I can come up with is because, if it went to the other side you would have to roll your logs through it, or over it!
~Chuck~
I LOVE MY SAWMILL
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: QUESTION?
« Reply #6 on: February 21, 2014, 05:40:43 PM »
I agree with chuck
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline kelLOGg
Re: QUESTION?
« Reply #7 on: February 21, 2014, 07:23:57 PM »
My MP32 exhausts opposite the side for loading and walking.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: QUESTION?
« Reply #8 on: February 21, 2014, 07:44:42 PM »
Sawdust exhaust location is a product of the decision of whether or not you want to saw towards your backstops or the clamp. It is easier to have the operator walk down the side of the mill that does not have loading arms or ramps. I fold up the hose on my LT40 so the dust blows far enough away from the mill that I don't have to walk in it when I have to approach from that side of the mill.
Offline bandmiller2
Re: QUESTION?
« Reply #9 on: February 21, 2014, 08:01:49 PM »
Jeeze, I thought all band rigs blew the dust out the back away from the operator, mine does, I load logs on my side and dust out the back. If you need to work close to the mill for safety reasons the dust should go out the side away from the operator in case of a broken band following the sawdust out. No one should be allowed next to the dust chute. Suppose if you have the command control station it really doesn't matter. Frank C.
    • My homepage
Re: QUESTION?
« Reply #10 on: February 21, 2014, 08:22:40 PM »
On the WoodMizer mills, even though the chute is on the operators side, it is ahead of you by a couple of feet. I agree, nobody should be in line with the chute.
Offline drobertson
Re: QUESTION?
« Reply #11 on: February 21, 2014, 08:24:14 PM »
I am thinking, this is why many have rigged up a  bucket that hangs at the dust exit, then they dump the bucket when full?  I have walked in a pile of it, and kind of like it, better than a concrete floor for sure,    david
Offline hackberry jake
Re: QUESTION?
« Reply #12 on: February 21, 2014, 08:27:14 PM »
One big variable in this equation is bark cutting. Bands last a lot longer if they enter clean wood and come out of the bark side. Ez boardwalk mills sawdust comes out the operator side. The only time the band has to enter bark is on the first cut... or really big logs...
Band selection question (boring question but includes bonus pics!)
Started by Piston on Sawmills and Milling
Last post October 15, 2010, 05:39:58 PM
by barbender
angry
Question for you surveyors (sorry but it's a touchy question)
Started by SwampDonkey on General Board
Last post September 25, 2008, 10:55:40 PM
by cheyenne
Skidder question and a question about Clark skidder
Started by ohiowoodchuck on Forestry and Logging
Last post March 12, 2016, 09:34:50 AM
by oldseabee
Oil Mix Question
Started by JOHNNYV on Chainsaws
Last post November 02, 2008, 08:44:19 PM
by JOHNNYV
