Arborwear
Author Topic: winter is starting to get the best of me  (Read 3732 times)
Offline Woodboogah
    • Blue Ribbon Outdoors
« on: February 26, 2014, 01:56:44 PM »
Between suagary snow, uphill skid, hidden rocks, digging out stumps, this winter is starting to beat me up.  My whining isn't going to help any though.
Keenan Logging & Tree Care, LLC
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
Re: winter is starting to get the best of me
« Reply #1 on: February 26, 2014, 02:32:54 PM »
Well its winter like we used to have !!! i remember years ago the snow was so deep when we shoveled out the trees, there was hardly any way to get away from them when we cut them, needless to say while holding your breath falling the trees so you wouldn't get asphyxiated  by the chainsaw fumes!!! ;D
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline JamesE. PikeLogging
« Reply #2 on: February 26, 2014, 03:28:27 PM »
I'm with ya on that woodboogah! the past week ive been runnin grapple skidder for my friend on his mechanical crew! snows just too deep!
Offline Woodboogah
« Reply #3 on: February 26, 2014, 03:40:05 PM »
Loggah-it could be way worse then what it is now.  I am just being a baby I guess.  I am grateful to be working doing something I love, just getting beat up with the snow.  I would rather work in the cold then heat but with snow up to your knees and no traction for the machine its making it tough production wise.  Seeing lots of deer so that is a plus. Look pretty healthy too
Offline loggah
« Reply #4 on: February 26, 2014, 03:52:05 PM »
On the warm days when the snow is sticky  you want to run around thru the woods with the skidder and break out some roads ,it will help in the long run! ;D the last of it when i had my 653 feller-buncher i got spoiled walking around with that and cutting helped the skidders get around a lot. When i was running my skidders i really hated the planetarys  chucking in deep snow. i hate to admit it but the John Deere and Cats with the inboard plants and heavy axles walked thru a lot of snow better then outboard planetary machines. Years ago we would also use dozers to go thru the deep snow to help break it out for the skidders.
Offline red
  • we will never forget
« Reply #5 on: February 26, 2014, 04:27:46 PM »
One good thing is days are getting longer
Sunset about 5:45 pm here
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline 240b
« Reply #6 on: February 26, 2014, 05:19:32 PM »
the snow isnt that deep really, Ive had alot worse to deal with. But the ground is frozen like pavement. Even new ice chains just scratch around on it. And the softwood is frozen all the way through so it just snaps off the stump. Good part 90% of the limbs bust off on impact..  I am going to try salt on the worse uphill section of trail..  Yesterday i counted 18 deer and 3 turkeys in where I was cutting, now they have it tough..
Offline gspren
« Reply #7 on: February 26, 2014, 05:46:14 PM »
  Now I'm just a firewood cutter, not a pro, but this winter has me way behind where I should be so today I thought I'd get some cutting in, dropped a few dead cherry trees OK but the walking killed my ankles. Two steps on top of the crust then break though a few steps then several steps on top before breaking through again, tough on an old arthritic ankle!
Offline Ryan D
    • Long View Forestry
« Reply #8 on: February 26, 2014, 05:49:06 PM »
I didn't mind the snow for most of the winter. We had a warm spell a week or so ago and it back to freezing cold now. The snow is still up to your knees but has a nice layer of crust on it. You can all but forget about working on a hillside and even walking on flat ground is terrible. I fall through about every third step. Better than mud though.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #9 on: February 26, 2014, 07:11:45 PM »
Me too I have ice all over my log yard  :D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #10 on: February 26, 2014, 07:16:01 PM »
The little warm up last week settle the snow a bit, and gave it a crust. I'm 300 pounds, plus all my clothes, shoes, chaps, chainsaw etc., and for the most part it holds me up. The only problem is if I'm trying to move quickly. I tramp down my escape route from the tree now so I don't have to play arctic ice-breaker as the tree is on it's way down. :D
Offline jwilly3879
« Reply #11 on: February 26, 2014, 07:27:38 PM »
My son takes the time to run the skidder around and push snow out of the way like Don said. He calls it brush wacking. He will plow out around the trees also and then cut them the next day. Makes skidding and cutting a little less tiring. The ground is so hard and icy after the rain that we can no longer get up the main trail and had to open one for uphill use only where there is some brush for traction. Coming down the main trail can be interesting, want to stay on the throttle if you want to steer.
Offline loggah
« Reply #12 on: February 26, 2014, 07:38:09 PM »
One job i was on  years ago was just a trench of ice about 150' long on a steep slope that ended on a flat at the woodyard, i had my 230 timberjack you started at the top in low gear and by the time you hit the bottom you better be in high just to keep the wheels turning fast enough so you could kind of steer and not snap everything in the drivetrain !!!
    • A&P Saw mill LLC
« Reply #13 on: February 26, 2014, 07:51:50 PM »
Or how about wanting to cut ice away from the mill building and ride a 22 ton excavator sideways down a hill. :D :D :D
Sawing since 1987
Offline loggah
« Reply #14 on: February 26, 2014, 07:56:34 PM »
 You get used to "NO" control !!!!! ;D ;D
    • A&P Saw mill LLC
« Reply #15 on: February 26, 2014, 07:58:04 PM »
It is fun  ;D
Sawing since 1987
Online Ed_K
« Reply #16 on: February 26, 2014, 08:42:44 PM »
 This is a yr of old, Mon. IO broke a pin on a steering piston,wiped out the 90 deg and a hose.Fix it yesterday,only to back off the skid trail and have the back sink,(no, the ground is not froze under 3' of snow)crawled back up and draged cable 75'.Now today was not a day to be cutting,shoveled out around 3 tree,did I mention the 3' of yuck? and it's 12degs and 20 mi wind.I cut 2 and limbed.went and cut the 3rd.made a HUGE mistake and cut the hinge off.It turned 180 degs on the stump before even starting to fall. I have never seen this happen before.It did land somewhere's close to where i wanted,but i didn't know which way to go.my 45 excape didn't seem right at first but i went anyway ,makes you wonder what am I doing here.If I can't find a flat/dry lot next I believe it's time to quit.
Now that's whining. :(
Ed K
Offline HiTech
« Reply #17 on: February 26, 2014, 09:07:53 PM »
We are getting more snow tonight. Sub zero temps coming. The snow has turned back to the sugary no traction type. We were smart enough to make roads when it was packy. Get off them and you spin/chatter. Just south of me they are getting 2" to 3" per hour. We will have a half of foot here by morning. It just doesn't want to go away this year. It will probably go from winter to summer...no spring. I can't wait to see what the stumps look like when the snow is gone. lol Some may be waist high.
Offline thechknhwk
    • Story of the Trees
« Reply #18 on: February 26, 2014, 09:26:29 PM »
I'm at work tonight, but I have to get lots more wood out of the creek bottom before it thaws and floods.  I'll get at it about noon tomorrow after I get out of work at 7am.  High of 9 tomorrow with a low of -17.  I hope its closer to the high than the low when I get out there.  I'm pulling tops for firewood and the snow is about 30" deep down there where I haven't packed it down with the tractor.  The tops are frozen to the ground and covered in snow, so I look for the lumps and start grappling, cutting, pulling and hopefully skidding...
Offline thechknhwk
« Reply #19 on: February 26, 2014, 09:27:21 PM »
And oh yeah... I'm sick of the cold and snow, real sick...  Not supposed to be above 20 here until the 6th of March.
I'm starting to hate winter!!!
Started by fuzzybear on General Board
Last post January 16, 2012, 06:14:33 PM
by Al_Smith
Starting the winter harvest
Started by adirondack harvester on Forestry and Logging
Last post November 18, 2008, 09:54:52 AM
by hiwayherbie
Starting to winter log finally (sort of)
Started by Quebecnewf on Forestry and Logging
Last post February 02, 2014, 06:09:42 AM
by Quebecnewf
Will this winter ever end
Started by Tam-i-am on LogRite Tools and Rite Leg Co
Last post July 15, 2014, 02:48:39 PM
by Tam-i-am
