Author Topic: Stihl 018 Will not start  (Read 882 times)
Offline spike47
« on: March 17, 2014, 06:12:16 PM »
Hi there
I have a Old Stihl Chainsaw , I can not get it to start , good spark , but everytime I try to start it , the plug gets wet , that is with and without using the choke , it seems to have good compression ,  but if I pull it over slowly , I can here hissing coming out of the carb inlet , is there some sort of reed valve for these 2 stroke engines ! .
cheer
spike
Offline spike47
Re: Stihl 018 Will not start
« Reply #1 on: March 18, 2014, 10:28:15 AM »
Hi there
OK got it started , I put a little oil in cylinder and it started up straight away , so I think it will need a set of rings at least , will strip it down and see what condition everything is , thanks for your help .
cheers
spike
Stihl MS 660 not start when hot
Started by otherguy on Chainsaws
Last post June 20, 2017, 07:25:43 AM
by CTYank
stihl 025 won't start
Started by ronaldlee on Chainsaws
Last post April 19, 2007, 02:16:57 AM
by windthrown
Stihl HT 101 Ext c-saw, will start, won't run?
Started by tstex on Chainsaws
Last post June 04, 2011, 05:41:13 PM
by fuzzybear
Stihl 031 won't start.
Started by ahiggins1 on Chainsaws
Last post October 24, 2009, 11:55:55 PM
by ahiggins1
