Author Topic: Custom 5hp Foley-Belsaw beam-planer on track system build.  (Read 2473 times)
Offline kastle
« on: March 23, 2014, 11:41:02 AM »
Iím doing a build on a 1970ís $70 foley-belsaw planer moulder I bought at auction to plane my 24í beams and columns.
I thought you all might be interested.
Offline hackberry jake
Re: Custom 5hp Foley-Belsaw beam-planer on track system build.
« Reply #1 on: March 23, 2014, 11:49:03 AM »
Nice video!
Offline morgoon
  • Location: North Western Ontario...Probably further North than the other Northern Ontario
« Reply #2 on: March 23, 2014, 12:53:37 PM »
I have the same planer and built a phase converter thru a10hp 3ph to run its 5 hp motor
It needs new feed rollers... Never thought about using on my saw
Neat idea!
Btw I used to use a garbage bag over my saw motor to protect it from the elements, but I ended up just using a piece of plywood set on top over the years :)
Homemade bandsaw, made by my mentor and dear friend Unto...who turned 85 this year
And I just made my first longbow...awesome
Offline ljohnsaw
« Reply #3 on: March 23, 2014, 01:20:55 PM »
Welcome!  Well?  Did you make it yet?  ??? I want to see it!!!
John Sawicky
Offline Larry
« Reply #4 on: March 23, 2014, 01:45:11 PM »
Belsaw is still in business selling parts.  Do a google to find them.
I bought new rollers some years ago and think they were $30 something.  The front roller wears a lot more than the rear and will be cupped in the center.  This isn't all bad as it works great for lumber with a crown.  Boards will come out pretty close to flat.
With a 5 HP motor these machines can feed faster than the standard 12' a minute.  Belsaw sells a replacement sprocket and chain to boost the feed to 20 fpm.  Can't remember the cost.
There is a trick to changing bearings as they twist to come out.  Watch the bearing on the powered side as it is first to go.  If bad it can spin in the casting causing damage which is not easily repairable.  Better to put new bearings in a old machine if you plan on running it hard.
The down side is dust collection.  I've got a picture in my gallery of one I retrofitted.  Did another where I brought the dust out the top like the new ones.
These are great machines considering the price they bring.  One could buy several and sit one up to plane, and the next for molding.  Cheaper than tax and shipping on a new machine.
Welcome to the forum kastle...impressive first post with a video.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: March 23, 2014, 02:03:33 PM »
Welcome to the Forestry forum, kastle.
Offline thechknhwk
    • Story of the Trees
« Reply #6 on: March 23, 2014, 10:27:10 PM »
Nice SV, I had a 2003.
Offline Cguignard
« Reply #7 on: March 24, 2014, 08:55:45 AM »
Looks like the one I have pulled apart on my bench right now, I am retrofitting it to be powered by a gass engine so I can plane right at my drying piles.  Just got my last order of parts in, new stand made and new drive shaft and bearings installed. Just need to figure out belt lengths and clean rust off the table.
Offline 21incher
« Reply #8 on: March 24, 2014, 10:20:14 AM »
Great video, welcome to the forum. I have that same planer that I bought in 1982. Have replaced the drive rollers and bushings once and it will definitely outlast me. I love to see people recycle old machinery into new projects.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Rockn H
  • long way to go
« Reply #9 on: March 24, 2014, 11:02:43 AM »
Thanks for posting and welcome to the Forum.  Wish I still had my dad's old Folley Bellsaw Planer Molder... his had sprockets for the feed rollers though.
Offline m wood
  • How did I get to be a senior member :)
« Reply #10 on: March 24, 2014, 03:38:23 PM »
Welcome Kastle.  Cant wait to see the next vid when it is rolling down the EZ boardwalk tracks.
mark
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Offline morgoon
« Reply #11 on: March 24, 2014, 04:56:31 PM »
I'm digging that gas powered idea...
I have a 7.5 briggs I have been saving, might be just the thing!
Offline hardtailjohn
« Reply #12 on: March 25, 2014, 01:09:00 AM »
Welcome Kastle....  hmmmmmmmmmm......a Big Mountain cap.... are you local?
John
I'm so far behind, I think I'm ahead!
Foley Belsaw planer/molder
Started by Mad Professor on Drying and Processing
Last post November 06, 2008, 08:12:20 PM
by Mad Professor
Last post January 09, 2009, 12:03:43 PM
by jheike
thumbup
foley belsaw
Started by Buck Sawyer on Wanted
Last post July 25, 2011, 04:19:02 PM
by HOGFARMER
foley belsaw m14 pto
Started by Jgreen on Sawmills and Milling
Last post October 28, 2015, 06:48:52 PM
by Jgreen
