Arborwear
Author Topic: Log arch build finally complete Video added )  (Read 24418 times)
Offline 21incher
« on: March 27, 2014, 03:18:26 PM »
Today it finally got warm enough for me to go out in my shop and start building my log arch. I had some leftover tubing and steel plate from my sawmill trailer build and a couple of 5 lug 15 inch wheels. The only parts I am looking for are the hubs and spindles, It is being built to handle a max 24" x 12 foot log.
The basic arch frame.
Another view of the start of the frame
The forward support angles. Hopefully it will pivot and drop down to load the log when done
Rear view. The tongue is a old 3" x 4" tongue from a boat trailer
Plasma cutting the front supports
1/4" steel plate supports cut in about 2 minutes
Welding the l.h support in place.
The supports have pockets to lock the log support chains in place. This is as far as I got today but will post more pics as the project continues.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline pine
Re: The start of another log arch build
« Reply #1 on: March 27, 2014, 03:30:54 PM »
I will be following this thread.  Nice plasma cuts!
Offline ljohnsaw
« Reply #2 on: March 27, 2014, 03:31:59 PM »
Wish I had a plasma cutter!  Is it numerically controlled?  Those keyhole slots are sweet!  Need to see the overall in a pic when you get there.
Nice!
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline 21incher
« Reply #3 on: March 27, 2014, 03:38:06 PM »
Nice!
It is a CNC table that I designed and built a couple of years ago. Never got good cuts though until last year when I added Digital torch height control.
Offline Freedom6178
  • Weekend Warrior
« Reply #4 on: March 27, 2014, 03:44:23 PM »
Awesome I want one of those plasma cutters and a good welder.. I'll be following this build as well.. Thanks for sharing smiley_thumbsup smiley_thumbsup smiley_thumbsup ..
------Freedom6178------
Prepare for the unknown by studying how others in the past have coped with the unforeseeable and the unpredictable.
George S. Patton
'12 Mustang, '03 F-250 SD 4x4, Stihl Farm Boss 18"bar, '09 Arctic Cat 550 TRV EFI
Offline m wood
  • How did I get to be a senior member :)
« Reply #5 on: March 27, 2014, 04:01:08 PM »
wow! your metal working is top notch (old saying).  looks like a great build going on.  What ya got for hubs?
I am Mark
80 acre woodlot lots of hard and soft
modified nissan 4x4/welding rig
4x4 dodge plow truck
cat 931b track loader
Norwood mark IV
4' peavy
6' peavy
stihl 034
"her" wildthing limber saw
ALL the rustic furniture  woodworking stuff
check out FB
Offline Andy White
  • I'm not so new anymore!!
« Reply #6 on: March 27, 2014, 06:19:07 PM »
Mark.
Nice looking arch. Workmanship looks top notch. Have plenty of support when you install spindles! Lots of stress there. I like the keyhole notches for the belly chain, but a small caution. Install rings on each end of the chain, because it will come off while traveling empty! Don't ask me how I know this. I had grab hooks on each side of mine, and lost the first chain, then welded the end link on one side and left grab hook on other. No more lost chains. Keep the pictures coming, and be safe.    Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
Offline thecfarm
« Reply #7 on: March 27, 2014, 06:45:27 PM »
Nice looking build!!!
Offline Busy Beaver Lumber
    • Busy Beaver Lumber
« Reply #8 on: March 27, 2014, 07:16:47 PM »
very impressive work. Like the plasma cutter additions. High Class act.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
Offline 21incher
« Reply #9 on: March 27, 2014, 08:07:54 PM »
Thanks everyone. It is always fun to start a new build after a long winter.
Mark I have no idea on the hubs yet. I just started looking on craigslist for a old donor axle and hubs ( hopefully with electric brakes ) but if I don't find one I will have to break down and order new parts.
Mark.
Andy once I get axles there will be reinforcing brackets added to handle the stress plus I will be cutting other braces for the frame. I plan on mounting a couple of old ammo boxes on the tongue to keep the chains in when they are not being used. This will most likely take a while to complete in my spare time so please bear with me.
Kind of like your CNC router. If you can draw it you can make it. What used to take hours only takes minutes.
Offline Rockn H
  • long way to go
« Reply #10 on: March 27, 2014, 08:56:48 PM »
I just thought I was impressed with those banjo holes... really impressed with you building the CNC. ;D
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #11 on: March 27, 2014, 10:14:47 PM »
I'm impressed, too. All else has been said. smiley_thumbsup
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: March 27, 2014, 10:21:00 PM »
Looking good.   smiley_thumbsup smiley_thumbsup
Offline 21incher
« Reply #13 on: March 28, 2014, 01:20:21 PM »
Today I had some time to start on the log lifting claw. Originally I had the stupid idea to tilt the frame to load it, but after mocking it up I found out it will not work. So instead I decided to go with a winch and a claw. Here is the start of the claw
Designed and plasma cut the claws.
They wound up being pretty beefy because I only had 1/4 plate. Wish I had some 1/2 inch.
That is a 16 inch diameter plate, the jaws are designed to handle a 24 inch diameter log weighing 1500 lbs.
This is where the assembly will mount when done.
shown in open position to clear a 24" log. They will drop with a winch to load.
Offline 21incher
« Reply #14 on: March 29, 2014, 01:15:07 PM »
Working on the claw this morning. Cut the pivot plates and lifting links.
Starting to look like a big claw.
Claw in closed position
Pivot plates for the jaws cut.
Lifting links plasma cut.
Only 1 more set of plates and the claw will be complete. Still have to make some bushings, nylon washers, & 3/4 pivot pins. Then I must find a hand winch to raise and lower it. In the future I may add a electric winch so I don't even have to get off the tractor to load a log. Next comes the front log lift / cradle.
Offline arkansas
  • Home made bandsaw mill, NHLA lumber inspector
« Reply #15 on: March 29, 2014, 03:05:26 PM »
Your work is top knotch Wish I could cut like that.  My hat off to you.
Working on a hot LT40HD for now
Offline Billbob
  • Retired..I need to find a job so I can get a rest!
« Reply #16 on: March 29, 2014, 03:20:43 PM »
Wow!  That is some serious craftsmanship!  Excellent work!
Woodland Hm126 sawmill, LS 72hp tractor with FEL, homemade log winch, 8ft pulp trailer, Husqvarna 50, Husqvarna 353, homemade wood splitter, 12ft dump trailer, Polaris Sportsman 500 with ATV dump trailer
Offline Delawhere Jack
  • I ought to know better.....
« Reply #17 on: March 30, 2014, 02:24:17 PM »
When building an arch from square or rectangular section steel, say 2x2 or 2x4 inch, would 3/16" wall be sturdy enough? Or should I go to 1/4"? I doubt the arch would ever be used to carry more than a 3,000lb log.
Offline 21incher
« Reply #18 on: March 30, 2014, 04:05:31 PM »
I am using 3 x 4 x 3/16 wall for mine and only plan on a 1500 lb max log and that is what I will test it with. There still is more bracing to be installed. The material is really dependent on the design and bracing you use. You could probably get away with 1/8" with a good design. The highest stress area will be where the axles mount. and the forces will quickly increase if you are in a rocky area. Also from what I have read the 1" and 1  1/4" axles should only be used with 12" and under wheels. 15 " wheels require the larger stepped axles when there are no springs to help absorb the forces.
Offline 21incher
« Reply #19 on: March 30, 2014, 04:26:45 PM »
Another couple of parts this morning. Cut the pulley brackets that will raise and lower the claw.
Top pulley brackets
Made some spacers and welded the asm together.
Next I have to make the idler pulley for the cable to raise and lower the claw.
This is where the claw will hang. Over center springs will be added to keep it open when it drops and clamp it when down. Next I will pickup a manual winch and add a mount for it and pulleys. hoping to be able to operate both the front and rear lifts with 1 winch.
CNC Router build video clip added
Started by GAmillworker on General Woodworking
Last post July 23, 2013, 04:00:31 PM
by drobertson
New log arch(picture added)
Started by Crossroads on Sawmills and Milling
Last post May 16, 2018, 08:55:12 PM
by Crossroads
LM 29 build complete
Started by jdw on Sawmills and Milling
Last post April 13, 2015, 12:42:46 PM
by jdw
Back at the homemade sawmill video added
Started by Georgia088 on Sawmills and Milling
Last post March 18, 2018, 12:12:51 PM
by gww
