Arborwear
Author Topic: Log arch build finally complete Video added )  (Read 23754 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Log arch build finally complete Video added )
« Reply #200 on: November 13, 2017, 09:00:30 PM »
This looks really handy!
I work with an urban logger from time to time and he needs something like this on a larger scale to load logs onto his trailer.
Have you seen any bigger models like this?
I made this one... I think its BIG....
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline firefighter ontheside
  • I like trees.
« Reply #201 on: November 14, 2017, 10:48:03 PM »
Has anyone ever made just an axle that you would put under one end of a log and then pick up the other end of the log with the 3 point on a tractor and then be able to pull the log that way?  Thats what Im dreaming up to bring big logs out of the woods.
Woodmizer LT15
Kubota L245DT
Stihl 025 and MS291
2017 F350 Diesel 4WD
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #202 on: November 14, 2017, 11:07:12 PM »
   I had a rear dolly built and use it in conjunction with my log arch. The arch holds up the front end of the log. I don't see why something like this could not be used with a tractor to pick up the front and tow it within the limits of the tractor and terrain.
See dolly on left on the ground.
I lift the log with the winch on the log arch (You could use your tractor) set the log in the Vee and strap it in place with a ratchet strap.
I then hook the front of the log to my arch and tow it to my log yard - I see no reason you could not do this with your tractor if within its limits.
Offline Dakota
  • Swing'en in South Dakota
« Reply #203 on: November 15, 2017, 10:40:10 AM »
Similar idea as WV Sawmiller's.
Dave Rinker
Offline Satamax
« Reply #204 on: November 15, 2017, 02:53:26 PM »
I like this last one.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Kbeitz
    • My Hobbies
« Reply #205 on: November 15, 2017, 03:17:33 PM »
ahhh... Who needs an arch ?
Offline 21incher
« Reply #206 on: November 15, 2017, 03:43:50 PM »
That makes for a pretty big turning radius in the woods. I kept mine as short as possible to track behind the tractor in my tight trails. It will go anywhere the tractor can fit.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
  • I like trees.
« Reply #207 on: November 15, 2017, 07:28:38 PM »
I can only handle about10 at the most on my mill,so I wouldnt be towing anything longer than that out of my woods.  I think it will work great for my needs.  Pickup back with loader and slide wheels under.  Then pick up other end with 3 point and tow to my mill.  I dont want to be trying to carry big logs long distances with the loader.  This gives me some ideas.  Thanks.
Woodmizer LT15
Kubota L245DT
Stihl 025 and MS291
Offline olcowhand
  • I'm new- ish!
« Reply #208 on: January 11, 2018, 05:30:11 AM »
I'm a new member, and I read this string after seeing a reference to it in another. 21incher, that is one of the most innovative and professional Fab jobs I have seen. Great job.
Just another one of many things I'm learning by being on this forum. Thanks for walking us through the thought process and build of this handy Log Arch!
Type slower! I can't read that fast.
Offline 21incher
« Reply #209 on: January 12, 2018, 12:44:45 PM »
Thanks olcowhand and welcome to the Forestry Forum. That is what happens when you have too much time on your hands.  You will find unlimited reference info on here and I am sure you will be contributing info and ideas in the future also.  :)
CNC Router build video clip added
Started by GAmillworker on General Woodworking
Last post July 23, 2013, 04:00:31 PM
by drobertson
LM 29 build complete
Started by jdw on Sawmills and Milling
Last post April 13, 2015, 12:42:46 PM
by jdw
What should I cut from this monster white oak? video clip added
Started by GAmillworker on Sawmills and Milling
Last post July 23, 2013, 10:55:00 PM
by GDinMaine
Has anyone tried a lumberjacktools 15 deg staking tool? Video Added.
Started by 21incher on General Woodworking
Last post June 09, 2017, 08:17:54 PM
by 21incher
