Author Topic: Wood-Mizer Hydraulic Pump "HOLD ON" Circuit?  (Read 1702 times)
Offline Ga Mtn Man
  • Y'all can call me GMM
« on: March 29, 2014, 09:02:31 AM »
I started noticing the other day while sawing just how much the hydraulic pump is cycled ON/OFF while nudging a log into position and it got me to wondering - How hard is that cycling on the pump and solenoid and would there be any benefit (or cost) to adding a simple "HOLD ON" circuit to the solenoid?  I'm thinking a simple MOSFET with and adjustable R/C time-constant circuit set to hold the solenoid ON for 1-3 seconds after any hydraulic lever is released.  Just throwing the idea out there for discussion. :)
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline drobertson
Re: Wood-Mizer Hydraulic Pump "HOLD ON" Circuit?
« Reply #1 on: March 29, 2014, 09:23:35 AM »
No doubt about it on the cycling of the pump and solenoid,  I had to replace the brushes once at just over 2000 hrs, the solenoids have held up to this point,  It may be a bad thing, but I where a radio head set while sawing, so I don't here as much of the goings on with the solenoids and motors.  I'm not too sure I would want any more electronics on the mill,            david
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: March 29, 2014, 09:31:08 AM »
I do not see it as a matter of great concern because those solenoids last several years.  I know that I give mine a real workout during a day's sawing.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #3 on: March 29, 2014, 11:11:30 AM »
Working a large odd shaped log and get heavy handed on the hydraulics and you are changing a set of fuses $20 and well it takes time to change the fuses in the small box, but a pair of 12 needle nose pliers will help.
Battery life is already being pushed with the amount of draw the pumps pull. The solenoids use a heavy layer of silver and last for years, last time I changed mine was when there was a fire in the hydraulic box back in 06. I dont see that the pros outweighing the cons.
Practice flowing from one lever to the next and you can load, rotate and set a log without the pumps disengaging but listen for battery drain when working heavy odd shaped logs and give the alternator a chance to keep up.
Offline Red Good
    • www.cycleonemanufacturing.com
« Reply #4 on: March 29, 2014, 12:53:30 PM »
Is every one still using fuses . Has no one switched to circiut breakers of the same amps ? I like them because they pop and reset . Just a thought . Red
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
Offline Delawhere Jack
  • I ought to know better.....
« Reply #5 on: March 29, 2014, 08:08:59 PM »
Jim Rogers and I switched to breakers. 100A time delayed. The type they sell at auto parts stores for boom cars. Pardon the blurry photo. Made the change after installing a $28 "marine grade" fuse which I blew immediately after installing.
« Reply #6 on: March 29, 2014, 10:59:34 PM »
can you stack them, need 200 amp for two pumps.
Online Chuck White
  • Sawing Mobile since 2005
« Reply #7 on: March 30, 2014, 07:25:35 AM »
Jack; I switched from the fuse to a CB about 5 years ago.
It's the same CB as the one you posted above, I think I paid around $25.00 for it and it's only tripped once or twice since I installed it!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline stavebuyer
« Reply #8 on: March 31, 2014, 07:44:26 PM »
On my LT70DCS the circuit came with a delay to keep the pump running for about 3 seconds. Great idea for log positioning as you described but wrecks havoc on the power strip by arcing if you move the head before the pumps cycle off.
Offline Brucer
« Reply #9 on: April 03, 2014, 12:48:49 AM »
There's many types of hydraulic valves, and many ways of plumbing them.
On a WM, if the pump is running and a valve isn't open, all the fluid the pump is moving has to flow through a relief valve. So -- do you want to start and stop your solenoid and pump a lot, or use the relief valve a lot. One or the other is going to see a lot of wear.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Ga Mtn Man
« Reply #10 on: April 03, 2014, 08:12:37 AM »
So the guys that are using external pump units (ElectricAl, bibbyman) are constantly hammering the relief valve?
Offline Brucer
« Reply #11 on: April 04, 2014, 01:02:30 AM »
Maybe! I took a closer look at the diagrams and there are a bit ambiguous.
There is a type of control valve that will send the fluid back to the tank when the valve is centered. You can daisy-chain these valves together so there's a flow path back to the tank until a valve is operated. It's typically called "power beyond" -- when you operate a valve, it cuts off the flow to any valves that follow it in the chain. The WM mills I've used don't use this type of valve -- you can operate more than two cylinders at once.
Looking at the diagrams (with a magnifying glass), they appear to be using a type of control valve that dumps fluid to the tank until a valve is operated, but doesn't daisy chain the pressurized fluid from the pump. But I only see that on one diagram. All the other diagrams show a conventional closed center valve, which would cause your relief valve to operate.
I suspect they may have changed their valve configuration at some point, but I don't know when.
How to find out? Ask Bibby or Al directly, or do a simple test. Open up your control box and manually activate the micro switch that starts the pump. If your control valves bypass the relief valve when they aren't activated, you'll just hear the pump running. If the flow is going through the relief valve, you'll hear it screaming above the motor noise.
Wood-Mizer LT40HD 1/4" Hydraulic Hoses
Started by Ga Mtn Man on For Sale
Last post November 20, 2014, 12:00:35 AM
by JB Griffin
Wood-mizer Blades - 0.045x1.25"x158" - Some brand new
Started by mjl_2007 on For Sale
Last post January 31, 2016, 07:54:46 PM
by jmouton
Sharpening and Setting (Helpful info from "Wood-Mizer" Tech support)
Started by Cutting Edge on Sawmills and Milling
Last post May 11, 2012, 02:47:51 PM
by Cutting Edge
Looking for a Wood-Mizer operators seat for a "92" LT40
Started by RayMO on Wanted
Last post June 01, 2013, 08:57:53 PM
by RayMO
