Author Topic: Brace Layout Question and Answers  (Read 42671 times)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Brace Layout Question and Answers
« Reply #80 on: July 13, 2018, 09:02:41 AM »
Jim,
About the 1/8th extra thickness you add to braces. I assume you pair down that inner face to 4 inches to get a tight fit? My braces are up to 1/8" under nominal 4" . This will leave a gap in the mortise. Should I layout my mortises at 3 7/8"? I could lay out a 2" mortise 1 7/8" from the reference face?
Thanks,
Tim
Tim:
Yes, I hand plane down the inner face, the face that is flush with the tenon to make the tenon 2" thick.
Quote
This is exactly why I mill my brace stock over sized.
I would not do a 1 7/8" mortise, I'd still cut it two inch and shim the gap with something that won't show. Your tenon offset has to be 2" off the outside face, so the shim goes on the inside but trim it back so it doesn't show in the mortise.
Jim Rogers
Offline TimFromNB
  • New guy here.
« Reply #81 on: July 13, 2018, 09:11:11 AM »
Hi Jim,
Thank you, appreciate the help! Too bad I didn't read this before milling ;D
Will the gap cause any structural problems or is it just aesthetic?
Tim
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #82 on: July 13, 2018, 09:12:58 AM »
Brace strength is in compression. So the missing 1/8" shouldn't be a problem.
Jim Rogers
Offline Roger Nair
« Reply #83 on: July 13, 2018, 03:16:11 PM »
There is another option.  Survey the brace material for minimum width.  Lets say it is 3 3/4".  So maintain the 2 plus 2 system, use a 2 inch mortise and tenon with a housing that extends toward the center of the post 1 3/4" beyond the mortise.  Reduce the brace with a 3 3/4" gain at the joint to account for irregularity.  The advantage here is that the outside mortise line becomes reference, the brace becomes fully mortised, no shimming to keep tight m+t and no shrinkage gaps will appear.  Plus centered braces have to my eye a more pleasing appearance.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
rafter joints at ridge question and answers
Started by Jim_Rogers on Timber Framing/Log construction
Last post August 15, 2015, 09:05:08 AM
by Jim_Rogers
Brace question
Started by addicted on Timber Framing/Log construction
Last post August 23, 2013, 11:53:32 AM
by addicted
H Brace Question
Started by Ironhead80 on General Board
Last post June 23, 2016, 08:56:54 PM
by Magicman
question on size of brace
Started by laffs on Timber Framing/Log construction
Last post December 30, 2010, 06:20:43 PM
by laffs
