Author Topic: Chickens  (Read 1135 times)
Offline Peter Drouin
    • A&P Saw mill LLC
Chickens
« on: April 23, 2014, 06:53:00 PM »
Is there an easy way to stop a chicken from eating eggs ? Without ringing their neck. I give them the block from tractor supply for egg making.
I have one eating eggs and not sure which one. :D :D :D :D :D
A&P saw Mill LLC.
License NH softwood grader.
Offline thecfarm
Re: Chickens
« Reply #1 on: April 23, 2014, 07:02:50 PM »
I have heard of hot pepper. But the neck is really the only way,IF you can figure out which one. Get it quick,because that one will teach 2,than 2 will teach 4........
Offline red oaks lumber
Re: Chickens
« Reply #2 on: April 23, 2014, 07:35:35 PM »
something must be lacking with their diet, normally they only go after a broken egg.
Offline 36 coupe
Re: Chickens
« Reply #3 on: April 23, 2014, 08:07:34 PM »
Old hens lay weak shelled eggs.You need plenty on nest material as some birds lay eggs standing up.A broken egg starts egg eating.A dark nest helps. hens enter from the side.The door has a cloth flap to keep the nest dark.Egg are collected by lifting the top.Collect eggs early, most hens lay in the morning.Egg yolk on a hens beak or face ids the egg eater.Ring neck, dress and roast.
Offline shinnlinger
Re: Chickens
« Reply #4 on: April 23, 2014, 08:43:27 PM »
Smooth stones/fake eggs in nest tend to cure the problem also
Shinnlinger
Offline kczbest
Re: Chickens
« Reply #5 on: April 23, 2014, 10:40:56 PM »
Take an egg and poke a hole in each end and blow the inside of the egg out. Fill the empty eggshell with yellow mustard and put it back in the nest. Chickens HATE mustard. I have broken chickens from eating way, believe me it works.
Hail State!
2013 F150 Supercrew 4x4
John Deere 5303 4x4 with FEL
Cook's MP 32
Cat 289C with Bradco MM60 Forestry Mulcher Head
    • A&P Saw mill LLC
Re: Chickens
« Reply #6 on: April 23, 2014, 10:58:58 PM »
Tkanks guys, Ill try them all  8)
A&P saw Mill LLC.
Offline blackfoot griz
Re: Chickens
« Reply #7 on: April 24, 2014, 07:12:39 PM »
Golf balls worked for us.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Chickens
« Reply #8 on: April 24, 2014, 09:03:03 PM »
If you were to go to a poultry farm where there are 100's of chickens, you'll find that the chickens all have a bottom beak that's longer than the top beak!
The chickens won't peck on hard items when the top beak is cut back!
To trim the top beak, my dad and I used one of those cutters you would use to trim a dogs toenails, there might be a special tool made nowadays.
Trim them "just" short enough to where they will bleed a little and they will be tender and the egg eating will diminish!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline bugdust
Re: Chickens
« Reply #9 on: April 24, 2014, 09:23:52 PM »
Normally if chickens are eating their eggs indicates they are lacking hard material necessary for food digestion. Try giving them Oyster Shells. Usually works every time.
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
    • A&P Saw mill LLC
Re: Chickens
« Reply #10 on: April 24, 2014, 09:42:57 PM »
There out in the yard :)
A&P saw Mill LLC.
Offline chevytaHOE5674
Re: Chickens
« Reply #11 on: April 24, 2014, 09:59:16 PM »
Clipping their beaks in a sure way to solve the issue but then they won't be able to free range and hunt for food, they also won't be able to defend themselves as much.
Offline Chuck White
Re: Chickens
« Reply #12 on: April 25, 2014, 06:45:49 AM »
You basically just remove the point of the upper beak!
They can still eat, survive and produce while being outside!
~Chuck~
Re: Chickens
« Reply #13 on: April 25, 2014, 07:06:17 AM »
We used to buy laying hens from somebody who clipped their beaks and those chickens could only eat 1/3 of what a full beaked chicken could when out foraging (had trouble catching worms, bugs, etc). Those clipped chickens could always be found at the feeder.
Stopped raising anything with a clipped beak and our bagged feed consumption went down considerably.
Just my experience from personally raising hundreds of free range chickens.
Offline WildDog
Re: Chickens
« Reply #14 on: April 25, 2014, 07:22:54 AM »
If they are laying in nest boxes and not on the ground you could try a roll away nest box or tray insert in existing nest box.
Quote
We are finding this now, our flock has been a closed one for years and my wife just added 18 Isa Brown ex battery hens for their egg production. Their beaks are clipped and they get to free range with others. The egg production is up but the quality is down, not as rich yolks, they don't seem to know how to forage.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Woodboogah
    • Blue Ribbon Outdoors
Re: Chickens
« Reply #15 on: April 25, 2014, 08:13:30 AM »
usually something is lacking in their diet when they are eating eggs.  We use golf balls in the nesting box, mostly in the winter when they slow down.  They are outside all spring summer and fall but have never had a chicken eat eggs unless I drop one they come running over and eat it.
Keenan Logging & Tree Care, LLC
    • A&P Saw mill LLC
Re: Chickens
« Reply #16 on: April 25, 2014, 09:54:07 PM »
They'er let out in a wire in area. They go back in to lay an egg then go out and do their chicken thing  :D One will sneak in and eat an egg , Then run out and mix with the rest and I lose her . They all look the same  :D :D :D
I'm going to try the mustard trick.   :D :D
At least the beak will be yellow. :D :D :D :D :D :D :D :D :D :D
A&P saw Mill LLC.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Chickens
« Reply #17 on: April 25, 2014, 10:02:19 PM »
Peter,
Fried chicken.
Chicken and rice.
Chicken and dumplings.
Chicken parmigiana.
Smoked chicken.
Fried chicken fingers and dipping sauce.
Roasted chicken and deviled eggs (if you have any eggs left  :)).
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: Chickens
« Reply #18 on: April 25, 2014, 10:43:28 PM »
Peter,
Fried chicken.
Chicken and rice.
Chicken parmigiana.
Smoked chicken.
BBQ Chicken
Chicken Creole
Chicken Stew
Chicken Nuggets
Chicken Gumbo
I can't think of no more Forester.
Offline sandhills
Re: Chickens
« Reply #19 on: April 26, 2014, 11:01:34 AM »
Target practice  :D  I'm not much of a chicken eater, nobody cooks like my grandma did anymore.  I will say my wife can make it edible though, if you like chicken you'd probably love hers.
chickens and ERC
Started by Cedarman on General Board
Last post June 18, 2011, 12:25:39 PM
by D Hagens
Chickens
Started by splitter on Wanted
Last post April 17, 2008, 09:37:30 AM
by KGNC
chickens!
Started by ozarkgem on General Board
Last post May 27, 2014, 03:16:03 PM
by drobertson
question
Chickens
Started by Furby on General Board
Last post May 31, 2009, 11:15:41 AM
by Dan_Shade
