Author Topic: sharpening toward the power head  (Read 1283 times)
Offline 47sawdust
« on: May 04, 2014, 06:48:23 AM »
I just received my latest SAwmill&Woodlot magazine.There is a lengthy article about chain filing and the author's technique is to file toward the power head.I am not familiar with this method.Is this common practice?
Mick
Offline Oliver1655
  • Old Man
Re: sharpening toward the power head
« Reply #1 on: May 04, 2014, 08:49:53 AM »
Typically with square filed chain you file into the cutting edge, outside to inside, towards the power head.  With round filed you cut from the inside to the outside of the cutter, away from the power head.
I do know a fellow who file everything  "towards the power head.  Says it won't cause the chrome plating to flake off.
Now consider grinding. With the left side cutters the wheel turns from the inside to the outside while the right hand cutters have the grinding wheel spinning into the cutting edge.  Maybe this contributes to folks feeling hand filed is sharper?  Thoughts?
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
Offline HolmenTree
« Reply #2 on: May 04, 2014, 01:00:04 PM »
One thing to consider is a square ground sawchain cutter has 2 cutting edges shaped like a chisel or hand plane knife .
Now consider both of those tools have a flat tapered surface and best sharpened flat or level.
A chain grinder wheel is round in shape......a file is flat. Which one makes the better chisel cutting edge surface?
Hand filing takes alot of practice or being a born natural  to avoid the "rocking chair motion" in the filing stroke.
A filing jig will help solve the rocking motion.
Offline charleswalton
« Reply #3 on: May 06, 2014, 09:42:44 PM »
What type of chain do you use a flat file on?All of the chain I have ever filed has been with a round file.
Offline HolmenTree
« Reply #4 on: May 07, 2014, 10:52:57 AM »
These chains are pre ground  at the factory with a square 2 cutting edge design called chisel bit .
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #5 on: May 07, 2014, 11:29:53 AM »
We always called filing from the outside toward the power head "goofy filing".  Now when I file, because of my wrists/hands, I file that way on the outside(right) cutters, and conventional on the inside(left) cutters.  Call me goofy but still am able to have a sharp chain - at least it cuts! ;D
Offline ZeroJunk
« Reply #6 on: May 07, 2014, 12:28:48 PM »
I have always filed in to the cutter. No particular reason other than that I figured if you sharpened a knife in to the blade might as well sharpen a chain that way. Been doing it wrong for 45 years.
Offline Oliver1655
  • Old Man
« Reply #7 on: May 07, 2014, 12:46:57 PM »
A "Double Beveled" file is use for filing square ground chain.
Madsens has some interesting training resources which may be helpful:
For hand filing:
http://www.madsens1.com/bnc_cb_angles.htm
http://www.madsens1.com/bnc_chisel_qna.htm
For Grinding:
http://www.madsens1.com/sim_tuning.htm
John
Saw head travel power
Started by ljohnsaw on Sawmills and Milling
Last post March 15, 2018, 04:27:55 PM
by Kbeitz
Hay Getoverit don't cut the legs off of your power head just yet
Started by Part_Timer on Sawmills and Milling
Last post August 13, 2006, 05:35:08 AM
by Captain
TK 2000 power head return speed diminishing
Started by AshArb on Sawmills and Milling
Last post July 29, 2016, 10:28:01 PM
by AshArb
Real life weight of Stihl 241 power head?
Started by mister sunshine on Chainsaws
Last post May 09, 2017, 07:43:37 PM
by mister sunshine
