Author Topic: Insulated Barn Doors  (Read 2890 times)
Offline Brian_Weekley
  • I am Batman!
« on: May 04, 2014, 02:55:59 PM »
I needed a set of barn doors for my newly constructed timber frame workshop.  Instead of traditional barn doors with crossbucks, I opted for a smooth, finished-style door.  Mainly for two reasons:  I wanted the doors to be insulated and it just seems like crossbucks would potentially collect or trap water.  Id like to give credit to Raoul Hennin (bungalow in a box), whos video on YouTube inspired my design.  This was the final design I came up with:
I think the 45 degree angled boards still give the doors that traditional look.  Its definitely worth taking the time to figure out the layout of the boards so they are evenly spaced in the frame.
First, I made an internal frame from kiln dried, dimensional lumber (1.5 inches thick).  I used 2x4s and 2x6s--some ripped to thinner widths.  I purposely positioned the internal frame members so I would have screwing substrate for the board edges and also provide solid surfaces to securely mount strap hinges.  The internal frame was constructed with biscuits and wood glue.  Care was taken to keep the frame flat and square during the glue up.
Next, I added a layer of Tyvek to the external side of the frame.
I planed my rough cut pine boards down to 3/4 inch thick.  The radial arm saw was my workhorse for this project.  I used it to rip the boards to width (8 inches wide for the rails and stiles and 6 inches wide for the field boards).  Also used it for all my crosscut and miters.
A molding head on the radial arm saw was used to cut the tongue and groove in all the boards.  However, it can be a little tricky to cut tongue and groove in the end grain of the boards.  Therefore, sleds with clamps were used to hold the boards in place.  This makes this operation easier and safer.
My router table was used to add a slight chamfer to the board edges.  This gives a little definition between the boards.  Without it, the whole door just looks flat.
The rails and stiles were screwed down while fitting the field boards in between.  The tongues are always positioned up to help shed water.
The 45 degree boards definitely takes a lot of time since each piece is unique and must be cut and fitted individually.  However, I think the final look is worth it.
After the front sides were completed, I flipped the door over and filled the cavities in the internal frame with two layers of 3/4 inch polystyrene foam.  The foam sections were cut slightly larger with a straight edge and sharp utility knife and stuffed tightly into the openings.  One side of the foam was foil covered, so I chose to face the foil sides towards the outside surfaces of the door.
Strap hinges will be attached with stainless steel carriage bolts.  On the interior side, the nuts and washers were countersunk into the frame so you wont see the fasteners from the inside once the internal boards are applied.
After staining, I think they look pretty smart!
I still have to apply the interior boards, but when complete, the doors will be 3 inches thick and very solid.
e aho laula
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Insulated Barn Doors
« Reply #1 on: May 04, 2014, 05:08:00 PM »
Thanks for sharing.
Jim Rogers
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #2 on: May 04, 2014, 09:28:12 PM »
Very nice doors, great work, you will be very happy when you go to work and see those doors.
Offline WmFritz
« Reply #3 on: May 04, 2014, 10:23:55 PM »
Super job Brian. Nice work.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline Mooseherder
« Reply #4 on: May 05, 2014, 06:08:08 AM »
I like the doors and molding Head on the Radial Arm saw.   :)
Lane Circle Mill
Homemade Bandmill
Online thecfarm
« Reply #5 on: May 05, 2014, 07:52:28 AM »
That does look nice. And than some.
Picture of it in place,please?  :)
  • I am Batman!
« Reply #6 on: May 05, 2014, 08:23:09 AM »
Thanks.  Unfortunately, that will have to wait till later this summer when I'm back up in Maine to do some more work on the barn.  In the meantime, I'll be buiding some windows for it too.  A transom window for over the doors is the next project on the list.
e aho laula
Online thecfarm
« Reply #7 on: May 05, 2014, 08:26:02 AM »
Where in Maine will the doors be hung on a barn?
  • I am Batman!
« Reply #8 on: May 05, 2014, 09:31:49 AM »
CFarm, not too far from you--in Montville.  You probably remember my photos from the barn raising over Labor Day weekend.
Here's what the front will look like:
e aho laula
Online thecfarm
« Reply #9 on: May 05, 2014, 09:48:14 AM »
I forgot about that. But went looking at your gallery and found this.
Offline D L Bahler
  • Hopp Schwyz!
    • Traditional Swiss Carpentry
« Reply #10 on: May 07, 2014, 04:09:14 PM »
I like the concept a great deal. I might adapt it to my own uses, with your permission of course.
question on running insulated pex from my boiler to my barn.
Started by adamant on Firewood and Wood Heating
Last post November 30, 2015, 09:13:33 AM
by sam-tip
old barn/new doors
Started by giant splinter on General Board
Last post June 12, 2012, 09:42:41 PM
by shelbycharger400
Pole barn doors
Started by John_Haylow on General Board
Last post August 28, 2013, 09:09:44 PM
by shinnlinger
Need help re: barn doors (mill shed)
Started by roger 4400 on Timber Framing/Log construction
Last post March 04, 2014, 07:51:58 PM
by Tom King
