Arborwear
Author Topic: Norse 3500 Parts  (Read 1413 times)
Offline Vtroger
Norse 3500 Parts
« on: May 27, 2014, 12:43:32 PM »
I'm trying to source parts for an older Norse Winch, Model 3500.  Does anyone have a good source?
Roger
Offline thecfarm
Re: Norse 3500 Parts
« Reply #1 on: May 27, 2014, 04:50:05 PM »
Vtroger,welcome to the forum.
I suppose you tried Labonville?? Have the manual,parts breakdown?
http://www.labonville.com/Winch-Manuals_ep_43.html
I have the 450 with the butt plate that tilts up.
What do you use for a tractor,hp??
Offline Vtroger
« Reply #2 on: May 27, 2014, 06:57:53 PM »
Thanks for the reply welcome!  Labonville does have some parts, but the model 3500 is no longer supported.  I'm looking for the chain tensioner and a drum brake.
I'm using a Kubota 7040,  70 horse.
Offline thecfarm
« Reply #3 on: May 27, 2014, 07:40:16 PM »
I know each model is diffeant. On mine the chain tensioner is just a piece of metal,kinda as thick as your ring finger that goes to a point. That's on a pivot with a spring.
The drum brake is even simpler than that. Just a hunk of metal about 1X 3 inches with some sort of wearable metal. Adjustable with a bolt. When I pull the cable out it just slides on it,but a soon as I let go it will hold the spool in place.
The 450 manual is hard to figure out but that 3500 is real bad. What a poor job they did with that model.
Offline Hilltop366
« Reply #4 on: May 27, 2014, 08:42:54 PM »
http://www.novaintl.ca/norse-skidding-winches.htm
These guys have been around a long time, they may have some old stock.
Offline celliott
« Reply #5 on: May 28, 2014, 09:44:37 AM »
Welcome to the forum Vtroger!
Can't help with your winch problem, sorry....
Going by your forum name, are you from Vermont?  ??? And is your name Roger maybe?  ??? ??? ??? OK one of those is probably true  :D
Maybe fill out your bio in your profile a bit?
I'm from Danville BTW.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline North River Energy
« Reply #6 on: May 28, 2014, 02:10:36 PM »
Parts broken, worn out, or missing?
Offline Vtroger
« Reply #7 on: May 28, 2014, 02:27:31 PM »
The parts are worn.  The chain tensioner broke away from the frame.  I might be able to salvage some of it, an re-weld to the frame.
I can re-line the drum brake.
Norse doesn't make parts for the older winches, though the clutch disks are available....so We'll keep it running.
I'll work on that profile.  Thanks for all the help.  This is a great site!
Roger in Granville, Vermont
Norse 400 winch parts
Started by Holmes on General Board
Last post January 18, 2014, 04:40:55 PM
by thecfarm
Norse 190 winch?
Started by wolfden on General Board
Last post October 29, 2006, 07:58:28 AM
by wolfden
norse 450 winch
Started by SNAFU on Forestry and Logging
Last post April 15, 2009, 11:31:42 AM
by Stephen
norse 450 logging winch
Started by hogs4hobby on For Sale
Last post September 22, 2010, 07:00:01 PM
by hogs4hobby
