Arborwear
Author Topic: oleo mac 952 piston damaged  (Read 6341 times)
Offline shiggins
Re: oleo mac 952 piston damaged
« Reply #20 on: June 02, 2014, 04:05:24 AM »
its looking better. when i drop the damaged piston in with no rings it defiantly slows as it pushes air through. The scores u can see i can badly feel now. feels smooth
Offline ladylake
« Reply #21 on: June 02, 2014, 07:19:22 AM »
This damage came from a lack of oil not a lean setting or air leak.  Steve
Offline celliott
« Reply #22 on: June 02, 2014, 08:10:34 AM »
Well the cylinder is looking good shiggins!
Anywhere there is a mark, use your fingernail and run it across the marks. If your nail catches, it's not smooth enough yet.
Have you located a piston\rings set yet?
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline shiggins
« Reply #23 on: June 02, 2014, 09:37:12 AM »
Thanks mate. I'm going to ring around tomorrow as we had a public holiday today. I've found them online but will look local first. I might need a new gasket and bearing as well?
How do u know it was fuel mix ladylake ? I would love to know
Offline ladylake
« Reply #24 on: June 02, 2014, 02:29:42 PM »
 Saws run lean will score on the exhaust side, most time just if front of the exhaust port.  Without oil they score all the way around or most of the way around.  Did you use fresh gas mixed right preferably with out ethanol and shake it up.   Steve
Offline shiggins
« Reply #25 on: June 02, 2014, 09:03:38 PM »
The piston isn't scored on the intake side. I am very carful with my mixes. It was still working so the damasge could of happened a while ago. Maybe I did make a mistake a while ago. Could of been old fuel that settled down. Is hard to pinpoint now.
Offline shiggins
« Reply #26 on: June 02, 2014, 10:29:29 PM »
Just getting local prices on the piston and also checking cylinder price.
Online I have found them for $90 in the states as that's for the whole cylinder kit.
The price I got here is 150 just for the piston and rings or 536 for the whole cylinder kit. What's the go here? Chinese vs genuine? Thoughts?
I am still getting more quotes.
Edit
Best local quote ATM is 100 for piston and rings and 320 for cylinder kit. I'll need to get a new gasket as well. It's stuck to the cylinder and is ripped.
Offline 7sleeper
  • I'm new here but old elsewhere!
« Reply #27 on: June 03, 2014, 01:57:36 AM »
To be honest I would get the set from the US if it was genuine. I would save the old cylinder and just put in the new set. Further I would renew all the seals, carb boot, impuls line, etc. just for safety reasons. You will have a practically new saw then, but with proper care this time it should last a life time!
7
Offline shiggins
« Reply #28 on: June 03, 2014, 03:06:16 AM »
7
7 can you do me a favour and explain to me how many and what seals the saw has, the carb boot is the rubber part that attaches to the cylinder (I've got that), what is the impulse line ( is it the line from the carby to the cylinder?) I will try to find a new cylinder gasket. Anything else I need?
Sorry mate but I'm new to all of this. I also don't know how to tell if they are genuin pistons. It does say aftermarket and are from Canada. It would be 50 bucks cheaper from eBay compared to my local.
Offline ladylake
« Reply #29 on: June 03, 2014, 06:14:06 AM »
[/q
ote]
  In post number 11 you said it was scored on the intake side, either way when run lean the scoring will be on the exhaust side,  no oil or separated junk ethanol it will be all the way around like your piston looks.   Steve
Offline shiggins
« Reply #30 on: June 03, 2014, 08:24:32 AM »
Thanks Steve
Offline shiggins
« Reply #31 on: June 04, 2014, 02:04:03 AM »
I've gone local with the parts. Ordered a piston kit and gasket. The piston kit is $100. That's $50 more then eBay but I would have to wait a while from eBay and im not ute about the quality of the eBay kit and import taxes ect. I'm also getting the manifold gasket.
I'll upload some pics of the cylinder tonight. It's looking good
Offline shiggins
« Reply #32 on: June 04, 2014, 07:31:52 AM »
thats about it i think. what do you fellas reckon?
Offline 7sleeper
« Reply #33 on: June 04, 2014, 12:10:51 PM »
What we were expecting!
7
Offline celliott
« Reply #34 on: June 04, 2014, 02:50:20 PM »
Looks like it cleaned up real good.
Wasn't too hard, just took alot of elbow grease, huh?
Chris Elliott
265rx clearing saw
Offline shiggins
« Reply #35 on: June 04, 2014, 10:03:58 PM »
Yeh just some elbow grease! lol. now I just wait on the piston and gasket and install. Thanks for the help so far guys.
Offline shiggins
« Reply #36 on: June 13, 2014, 06:21:36 AM »
Well the new
Piston is in and I followed Joe_indi instructions. Only problem I have is tuning. This saw has a pre set high and low so I can only back it out one turn on each high and low.so u can only adjust the high and low by half a turn. The idle can be adjusted as much as I want though.
Offline joe_indi
  • The older I get the more I learn
« Reply #37 on: June 13, 2014, 01:00:36 PM »
..........Only problem I have is tuning. This saw has a pre set high and low so I can only back it out one turn on each high and low.so u can only adjust the high and low by half a turn. The idle can be adjusted as much as I want though.
Ahem, nothing prevents you from creating a suitable tool to extract the limiter caps on those screws so that you could do some decent tuning.
Offline shiggins
« Reply #38 on: June 14, 2014, 01:11:50 AM »
This is true Joe,
The high sounds about right though after adjusting it only in the range the saw gives me. obviously i get the saw to a good idle as well. will this be sufficient? i would of  thought these are set from the factory and should allow the user to only adjust only enough for change of climate. I am only a novice though. would you still take the restrictor parts off and adjust it your way? Thanks Joe
Offline CTYank
  • Ain't he cute?
« Reply #39 on: July 02, 2014, 08:45:11 PM »
This is true Joe,
The fact that the crown of your original piston melted so it could seize the upper ring tells me that the engine was running too lean, no matter the shortage of mix oil.
Thus I'd be sure to be able to adjust the H mixture as required to be certain not to melt things again.
When it's adjusted right, after being warmed up, the engine will 2-stroke @WOT under full load, then transition to 4-stroking when you lift. Lots of info you can "google" on those and how to get there.
Going forward, dump tank when storing saw for more than a few weeks, use FRESH mix and pure-syn oil meeting both these specs: JASO FC or FD, ISO-L-EGD at 40:1. Lots cheaper than engines. Store all the fuel in a cool/dry place- helps avoid moisture probs.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
clip
Chainsaw piston badly damaged
Started by Rik on Chainsaws
Last post March 08, 2018, 11:54:27 AM
by Mad Professor
Replace piston rings, piston, or cylinder?
Started by Spruce_Goose on Chainsaws
Last post May 11, 2014, 10:28:50 PM
by Al_Smith
Oleo-Mac GS720 and 820
Started by joe_indi on Chainsaws
Last post September 29, 2008, 04:01:14 PM
by jacob j.
Damaged Logosol 260 - Help!
Started by bond-lumber on Drying and Processing
Last post June 21, 2015, 10:04:28 AM
by bond-lumber
