Tally-I/O
Author Topic: Sharpening bandsaw blades on my radial arm saw  (Read 7616 times)
Offline nrp0450
« on: June 02, 2014, 08:04:39 PM »
I had read about sharpening bandsaws on a radial arm saw on here so I decided to give it a try. I ordered a grinding stone wide enough to get the whole profile in one pass. An extra 4x6 with a groove cut in it holds the band. And I put together an indexer with random parts I found in the shop.
Here's a pic just before I started shaping the stone:
And here's the stone pretty close to ready:
And here's a video putting a blade in it and sharpening a few teeth.
It seems to work well and only takes a few minutes to do one blade. I haven't decided if I'm going to put some kind of shield between me and the stone or just always stand to the side when I start it.
Woodland Mills HM126 sawmill
Husky 450 and Stihl MS250 chainsaws
Foley Belsaw 985 planer/molder
Kubota M4700 tractor
Offline redprospector
Re: Sharpening bandsaw blades on my radial arm saw
« Reply #1 on: June 02, 2014, 08:12:41 PM »
Well, that settles it.
There really isn't anything that can't be done with a radial arm saw.  :D
Pretty cool.
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #2 on: June 02, 2014, 08:18:37 PM »
awesome. :)
Offline WmFritz
« Reply #3 on: June 02, 2014, 08:33:10 PM »
I'd say you nailed it.
Nice job! 8)
~Bill
2012 Homebuilt Bandmill
Offline Ocklawahaboy
  • Learning as I go
« Reply #4 on: June 02, 2014, 08:34:42 PM »
To use the vernacular of today's wayward youth... You got mad skills
Offline boxygen
« Reply #5 on: June 02, 2014, 09:10:24 PM »
For those that sharpen themselves, do you have to set the teeth every time or can you do it once every X times and be ok? From my minimal experience, it seems like if you  hit metal with the blade then the teeth will need to be reset. How well do these bands saw wood now is the question? Nice work. I gave away my radial alarm saw because it was no longer relevent to the shop. Oops.
Hudson Oscar 121. Mahindra 2415, fransgard winch. Husky chainsaws from 346xp to 394xp, most are ported.
Offline bandmiller2
« Reply #6 on: June 02, 2014, 09:26:30 PM »
Boxy, it depends, I check my set with a dial indicator each time I sharpen if its close  I'll let it ride. If tramp metal is hit the band must be examined closer for often some teeth will be set over too much those I use a small adjustable wrench to bring back in line. Very clever use of the radial arm saw, we've got some clever rascals here. Frank C.
Offline nrp0450
« Reply #7 on: June 02, 2014, 09:32:02 PM »
I set the teeth (with my Pineywoods setter) every 2-3 times. I use a caliper to tell when a band needs it. I think the sawing itself bends the teeth back in. But also each time you sharpen you take material off, which reduces the set as well.
Nate
Offline drobertson
« Reply #8 on: June 02, 2014, 09:44:38 PM »
Nice! 8)  no need to set the teeth really for at least two sharpening's, just my experience, but it never hurts to check them, unless it's known that the cycle was a good clean one, I like it!
Offline Delawhere Jack
  • I ought to know better.....
« Reply #9 on: June 02, 2014, 10:25:24 PM »
 smiley_clapping
Pretty slick there NRP!
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #10 on: June 02, 2014, 10:29:05 PM »
I would have never believed it. But now i have seen it. You may get a call from CUSTOMSAWYER and a plane ticket.  ;D
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #11 on: June 02, 2014, 10:56:25 PM »
That's really impressive!
Good job!
FYI:  I set my blades every time!
You don't have to hit metal every time to warrant setting the teeth!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #12 on: June 02, 2014, 11:59:33 PM »
Nice idea! Now I need to find the guy I sold my Craftsman radial arm saw too last year. I will be shopping on Craig's list, I knew I should have kept it.
Offline ljohnsaw
« Reply #13 on: June 03, 2014, 12:39:24 AM »
I like it, too!  Looks to be way simpler than making a cam move a angle grinder - and faster to boot.  All you need to do now is devise a hand cranking do-hickey to advance the blade.  No issue with the blade trying to rise up and mess up your cut depth?  I'd be tempted to put some urethane wheels on top of the blade to keep some down pressure.
As far as turning the blade inside out, couldn't you have stood in the middle of the blade instead of it running around the back of the saw?  Seems scary to try and turn a blade inside out :-\
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #14 on: June 03, 2014, 05:00:53 AM »
     Great idea!!  To set your depth adjustment, are you lowering the saw head or shimming under the wood block?
WoodMizer LT50HDD51-WR
Lucas DSM
Offline nrp0450
« Reply #15 on: June 03, 2014, 12:11:36 PM »
Yeah, I've been pondering the best way to do a "hand cranking do-hickey". It gets tiring on the wrist advancing the blade by hand.
There have been a few times where the blade didn't settle all the way down in the groove. The stone seemed to push it down when it passed over. But it probably took too much of a "bite", like you said. Some wheels holding it down might be a good idea.
It's actually pretty easy to turn a blade inside out. And I wanted the blades going out the back of the RAS because I already had a long board at the right height to support them.
One thing I would do different, (and will probably switch out at some point), is to use eyebolts over some hefty screws on the indexer. My current setup is too flexible. If I pull too hard it only grinds the front side of the tooth and misses the backside.
Offline nrp0450
« Reply #16 on: June 03, 2014, 12:18:39 PM »
Yeah, I lower the head. It's a little course of an adjustment. But 1/8 of a turn or even just until I feel pressure on the crank seems to be small enough. Next time I'm going to use my caliper and see how much I'm actually taking off. I don't think it's much.
Offline Joe Hillmann
« Reply #17 on: June 03, 2014, 12:45:32 PM »
That is a wonderful idea.  Looking on craigslist you can find radial armsaws for cheap or free all the time.  It would be easy enough to build a tooth setter to go along with it for the cost of a dial indicator and some scrap steel.
Offline Lonely Sawer
  • Still learning but cuttin' boards
« Reply #18 on: June 03, 2014, 01:13:34 PM »
That's a slick idea. I'm all over it. NRP , how did you profile the stone? I have now found a use for my radial saw.
Norwood LM29
Sthil 020 16" bar
Sthil 039  24" bar
Kubota L3130 HST W/Backhoe
78 Ford F-800 Boom truck
2017 Ram Laramie Longhorn 3500 Cummins 4x4 crew
Yamaha Viking SXS
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #19 on: June 03, 2014, 02:41:50 PM »
on the cooks sharpener atightening the clamp up helps to hold the saw on the lower roller as it advances, so oiling the boards and tightening a clamp may solve the rise problem. Take a look at the advancing arm set up on any of the tooth setters to make advancing the saw smooth, consistant and with less efort.
Sharpening .055 x 1 1/4 bandsaw blades
Started by Cypress Man on Sawmills and Milling
Last post October 19, 2006, 10:24:05 PM
by Bibbyman
Bandsaw blades... stock up and/or learn manual sharpening...
Started by texican on Sawmills and Milling
Last post February 04, 2011, 12:22:46 AM
by texican
Looking for Planer Blades and Bandsaw Blade Sharpening Info
Started by cloair on Sawmills and Milling
Last post January 02, 2008, 10:52:06 AM
by jpgreen
question
Bandsaw Blades - Who sends sample blades to try out?
Started by Ozarkian on Sawmills and Milling
Last post April 01, 2012, 06:50:08 PM
by Magicman
