TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: 028 stihl questions  (Read 1600 times)
Offline cutter88
  • any day you come home safe is a good day!
028 stihl questions
« on: June 06, 2014, 12:50:22 PM »
I found a pair of 028 stihl saws there about 14 years old, anything I should look for, are the a decent little saw and is 500 bucks for the pair a good price?
Romans 10 vs 9
650G lgp Deere , 640D deere, 644B deere loader, 247B cat, 4290 spit fire , home made fire wood processor, 2008 dodge diesel  and a bunch of huskys and jonsereds (IN MEMORY OF BARRY ROGERSON)
Offline iwiegian
  • Two lifetimes of work and one to do it in.
Re: 028 stihl questions
« Reply #1 on: June 06, 2014, 03:38:01 PM »
Ive had my 028 for longer than i  care to admit and have always been amazed at the longevity and dependability of the saw.  I am on only the second plug and just lately had to finally had to put a new sprocket on it.  I have ran thru many chains and on the second 16 inch bar.  I also occasionally run a 25 on this saw.  I have a 250c now that gets a lot of use because of the easy start system as I have a bad elbow and its easier to start.  Its been a firewood saw not a logging saw.  As far as price it seems a little high but then prices of everything today seem out of line. In other words I'm cheap :) Dave
Offline Caloren
  • 1940 9N ford
« Reply #2 on: June 06, 2014, 03:57:08 PM »
The price seems to be a little bit higher than they sell for around here, unless they were in very good running condition with good bars and chains. They are a very good saw, if well taken care of.
Stihl MS 170, Stihl MS 310, Stihl 028 AV Super, and half a dozen other no-accounts! Cat D4 D.
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #3 on: June 06, 2014, 04:38:20 PM »
Stihl experts: might those 028's be older than 14 years? When did they discontinue that model?  Anyway, $250 bucks each for a used small saw seems steep, even with new bar and chain, even if a Stihl, IMO.
Offline Caloren
  • 1940 9N ford
« Reply #4 on: June 06, 2014, 05:17:06 PM »
Bradmarks,
 Yes, those saws could be older than 14 years since we don't know which 028's they are. I believe they first came out in 1977 as a 43cc saw, then the type II came out in 1979 with 47cc's, then sometime later the AV Super came out with 52cc's. I believe they were made through the '90's or at least most of that decade.
Offline clww
  • Oh yeah? Watch this!
« Reply #5 on: June 06, 2014, 07:12:47 PM »
I've had my first 028 since buying it new in 1987, and have cut hundreds of cords with it. Great saw that has done what I needed it for. $500 sounds a bit more than I would pay for a pair, though.
Many Stihl Saws-16"-60" Husky 372XP
18-Wheeler Driver for Millis Transfer
Offline celliott
« Reply #6 on: June 06, 2014, 10:22:31 PM »
I had three of them this winter, thrown in on a deal for a 385xp along with a bunch of parts.
Got two up and running good. Sold one for $130, and that took awhile. The second one is alot nicer, I'm asking $200 but haven't had any interest at that price. I'll be lucky to get $150 for it.
So yeah, $500 would be a bit steep I'd say, even at Canadian prices.
Are they supers or wood bosses? Either way, they're a decent small firewood saw.
One thing I noticed on the ones I worked on, is to make sure the top AV mount is tight, and check the intake boot real carefully for a tear. That mount can flex too much with a heavy handed operator, and tear the intake boot, usually on the underside where it's hard to see.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline Al_Smith
« Reply #7 on: June 07, 2014, 10:09:20 PM »
FWIW the 028,038 AV super and mag ,the 042 and 048 are all of the same design .One weak link in all of them as has already been mentioned is the top av mount .This can weaken  over time allowing the boot to tear and they usually tear on the bottom where you can't see it .
Offline cutter88
« Reply #8 on: June 08, 2014, 08:59:27 PM »
Thanks for all the input guys u truly are a big help :)
Romans 10 vs 9
Offline VeryBestAvatar
« Reply #9 on: June 13, 2014, 07:50:25 PM »
Unless they are showroom mint, $500 for the pair is out of the question.  A nice clean one can be bought for $150 with a good bar and chain.  I would gladly sell you 2 of the 17 I currently have for $500.
Offline Dave P
  • Member*
  • Let the small things, be the small things.
« Reply #10 on: June 21, 2014, 10:40:28 PM »
I bought one about a year ago, I paid $100.00 bucks. It was the 028AV. It ran like a top and then it died. I took the flywheel off to change the points and the screw had come out that held the points in place. In the meantime I learned that I could convert it from a points spark to electronic ignition. It wasn't that expensive either. Still runs great. I bought another one for 125.00 which was a newer version, already electronic igniition. The price you quoted for the two is quite high in my opinion. If I could sell the two I have for $500.00 I would do it. What ever you do, good luck to you.
David Patterson
Offline thecfarm
« Reply #11 on: June 22, 2014, 07:29:08 AM »
Dave P,welcome to the forum.
Offline deerslayer
  • old cars, saws, trucks, tractors
« Reply #12 on: July 05, 2014, 09:34:43 PM »
The last 028 Super I sold was very nice and I got $275 for it. If those saws aren't the Super version they're overpriced. They're way older than 14 years for sure...
Too many chainsaws, not enough wood.
Stihl, Husky, Craftsman, Mac, Homelite, Poulan. Some live here, some just passing through.
Stihl 046/MS 46 Questions
Started by Bronco on Chainsaws
Last post May 04, 2004, 06:42:38 PM
by Preston
Stihl MS 260 questions
Started by TreeWalker on Chainsaws
Last post November 26, 2006, 10:15:13 AM
by jokers
Stihl 020 questions
Started by deerslayer on Chainsaws
Last post January 11, 2013, 12:17:43 AM
by JuniperBoss
Stihl 028 Questions
Started by homesteader1972 on Chainsaws
Last post January 28, 2016, 11:04:15 AM
by nuke1
