Arborwear
Author Topic: when to rebuild  (Read 868 times)
Offline stihl32
when to rebuild
« on: June 23, 2014, 03:21:18 PM »
hi guys im new here and new to saws but not new to working on my own stuff. I recently had a stihl 011av gave to me. first thing I done was had the compression tested and it was 110. im wondering when to start thinking about rebuilding. now when this test was done the saw wasn't running the coil is bad. will it change the reading when the saws ran awhile and warm. thanks in advance
Offline ZeroJunk
Re: when to rebuild
« Reply #1 on: June 23, 2014, 07:34:13 PM »
Well, if it is actually 110 it won't run well if at all. But, accurate compression readings are not the easiest on small displacement. So, if it runs and  will keep idling without cutting off you may get a little more work out of it.  I wouldn't expect the compression  change to amount to anything.
Offline dougand3
Re: when to rebuild
« Reply #2 on: June 23, 2014, 10:03:17 PM »
I recently got an 011 AVT. It had 110 PSI. I put 2 tbls of Marvel Mystery Oil in the spark plug hole and gently moved piston occasionally over 24h. Freed some gunk around ring and PSI = 130 now. Runs pretty good for 40+ yo saw.
Husky: 272xp, 365, 261, 61, 55 (x3)
Stihl: 036, 026, 011AVT
Poulan: 4218, 2000
Offline stihl32
Re: when to rebuild
« Reply #3 on: June 23, 2014, 11:15:33 PM »
well I got the saw running replaced sparkplug cleaned carb and air filter. it ran for 1 day then died and hasn't started since. so I had a chainsaw shop test the compression they told me it was 110. I put a little gas straight in to the cylinder and it still wouldn't even try. but with 110 compression I figured it was time for a rebuild probably. thanks for the replys
Offline CTYank
  • Ain't he cute?
Re: when to rebuild
« Reply #4 on: June 24, 2014, 12:09:58 PM »
There is some expertise and equipment required to get an accurate compression reading.
Without the proper (soft-spring) schrader valve at the plug end of the tester, the readings will be notably low. For a dealer, that could help boost sales or service business.
With straight MIX in the chamber, if it won't fire, you have other probs there.
Longer term, use of latest-spec full-syn mix oil gives ring(s) best chance of free movement.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
Offline AdkStihl
    • J.Miller Photography
Re: when to rebuild
« Reply #5 on: June 24, 2014, 09:34:07 PM »
Check the coil and the flywheel key
LT 40 Rebuild
Started by whittle1 on Sawmills and Milling
Last post January 27, 2016, 09:38:04 AM
by paul case
Another 044 rebuild
Started by ENTS on Chainsaws
Last post June 17, 2009, 04:13:58 PM
by ENTS
024: rebuild, or ........
Started by MotorSeven on Chainsaws
Last post April 07, 2013, 08:53:31 AM
by thecfarm
Rebuild BW T-9?
Started by sandersen on Forestry and Logging
Last post September 14, 2015, 11:08:31 AM
by sandersen
