Author Topic: Drying hickory an ash together  (Read 607 times)
Offline MIsawyer
« on: July 25, 2014, 09:23:13 AM »
Would drying hickory and ash together work?  I am using a conventional kiln, I run a pretty aggressive hickory schedule but would the high humidity early hurt the ash other than just some  mild surface staining that will surface out?
Offline red oaks lumber
Re: Drying hickory an ash together
« Reply #1 on: July 25, 2014, 12:50:51 PM »
ash can handle a greater moisture loss than hickory, if you have good air flow in the kiln ,i dont forsee any issues
Offline Den Socling
  • just wondering
    • PC Specialties
« Reply #2 on: July 26, 2014, 03:40:52 PM »
Thinking about the green moisture content for Ash, it's around 42%, and that makes it nearly indestructible. It doesn't have pronounced rays ready to split on you, either.
Offline GeneWengert-WoodDoc
« Reply #3 on: July 26, 2014, 06:29:00 PM »
I see a high risk of sticker stain in the ash.  Plus there is a small risk of grey stain in the interior, especially if the hickory schedule starts over 115 F.  My suggestion is to avoid this mix unless the wood is well air dried.
Offline CRThomas
« Reply #4 on: July 28, 2014, 02:08:11 AM »
I am making a test run now drying Hickory and Ash in different ways. I have 4 rank set up. One rank is sticked and stacked I cut the pieces short and fat they are drying faster than all the rest that is on only one rank. I do not sell bulk fire wood so it would not work for me. So I think I will stick and stack my wood now top row the bark up so see about bundling some hard wood. I have a semi load of rock cherry to start on tomarrow I sell it for cooking wood its been stacked for over a year in chunks. I got caught up for a few days so I am going to do some get caught up work. My daughters came and help me bundle wood so we got 1500 bundles ready when the customers get low. Its 01:00 now I have to be up at 05:00 to get started agin. Later
Offline MIsawyer
« Reply #5 on: July 30, 2014, 08:39:23 AM »
Thanks for the input everyone i am going to try and avoid the combo but if i have to run them together i will make sure they have some good air
question
Air Drying Hickory and White Oak
Started by Frank_B on Drying and Processing
Last post April 10, 2006, 06:54:21 PM
by woodbeard
difficulties in drying hickory
Started by mikeb1079 on Drying and Processing
Last post December 01, 2013, 08:44:51 PM
by mesquite buckeye
3 sided husk on hickory nut - what type of hickory is it?
Started by Lanier_Lurker on Tree, Plant and Wood I.D.
Last post August 25, 2007, 09:18:14 AM
by Lanier_Lurker
Red Hickory (Pignut Hickory) value?
Started by jbburd on Sawmills and Milling
Last post July 18, 2007, 08:37:00 PM
by jbburd
