KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: moisture regain  (Read 736 times)
Offline Den Socling
  • just wondering
    • PC Specialties
moisture regain
« on: August 06, 2014, 08:36:37 PM »
A couple days ago I pulled a load of 10/4 White Oak. It all read around 7% with my Wagner after 8.5 days. The core may have been higher. The next day it had cooled and I went back to look for wet pockets. Almost everything read around 10%. I never saw such a change in MC so quickly.
Online beenthere
Re: moisture regain
« Reply #1 on: August 06, 2014, 09:25:35 PM »
Do you have the temperature change and the relative humidity change that this block went through over that 24 hour period?
Or just the cooling effect on the moisture meter reading?
Offline jim blodgett
Re: moisture regain
« Reply #2 on: August 06, 2014, 09:29:29 PM »
What's the MC of other wood nearby, Den?  What will you expect that to stabilize at? 12-16 per cent?
Offline red oaks lumber
Re: moisture regain
« Reply #3 on: August 06, 2014, 10:00:02 PM »
den
 does your meter have temp adjustments you can change?
Offline Den Socling
  • just wondering
    • PC Specialties
Re: moisture regain
« Reply #4 on: August 06, 2014, 10:05:00 PM »
Wagners aren't supposed to be affected much by temperature but I know capacitance does change. I would expect EMC around 12% but not in one day.
Offline 5quarter
Re: moisture regain
« Reply #5 on: August 07, 2014, 01:31:53 AM »
3% is a lot of regain in one day. Either the RH was very high, the core is still very wet or the meter is on the blink. I would bet its a wet core, if I were a betting man.
Offline Den Socling
  • just wondering
    • PC Specialties
Re: moisture regain
« Reply #6 on: August 07, 2014, 09:36:22 AM »
I just checked a piece of 8/4 White Oak that has been leaning in a corner for a couple years. It is in the high 11's nearly 12%. That's apparently the EMC in here but doesn't explain the low readings when I took the WO out. You may be right, 5/4, but that Wagner will "see" your hand if it's under a piece of 4/4. Also, I had no open checks in the WO. Maybe it was just a combination.
Offline GeneWengert-WoodDoc
Re: moisture regain
« Reply #7 on: August 08, 2014, 08:07:29 AM »
1.  Did you have air space underneath the wood when you tested it?
2.  The meter is expecting 4/4, so when you have more wood underneath, it thinks that there is more moisture (just like when you place you hand underneath).  This is why the 8/4 read high.
3.   Although the outside EMC is 12% EMC average in your area and most of the USA, inside a shop or lab, it will be 1 to 2 points dryer in the summer and maybe 6 points dryer in the wintertime.
4.  The meter will respond more to what is happening at the surface closest to the plate, so initially, the surface may have been quite dry.  (Test it out yourself by taking a reading, then gently wetting the surface and take a second reading.  Do this on both sides of the piece, but only wet one side.  Do it for 4/4 to see the biggest effect.)
5.  If wood changed MC that fast, then we would not need kilns.
6.  With thick lumber, the pin meter offers more reasonable readings, especially with respect to the core MC.
Offline Den Socling
  • just wondering
    • PC Specialties
Re: moisture regain
« Reply #8 on: August 08, 2014, 09:39:30 AM »
The wood was 10/4 - quite heavy. I just took a few readings of the pile both times.
It's been hot and humid. The surface would have regained some moisture.
I took the water out at a rate of more than 8% per day. Who needs (conventional) kilns.  :D
I should have mentioned that this oak is going to a '49 Dodge dump truck that is being restored with a White Oak bed. I didn't need to worry about MC. I was just curious.
Looks like more moisture is on its way
Started by Tom_in_Mo. on General Board
Last post April 04, 2008, 03:45:34 PM
by Warbird
How do you keep the moisture in a log
Started by alsayyed on Forest Education
Last post June 18, 2007, 06:09:24 AM
by Dan_Shade
moisture meters
Started by woodhick on Drying and Processing
Last post November 20, 2005, 07:03:53 PM
by Gunny
Moisture Meter
Started by woodsdog2015 on Firewood and Wood Heating
Last post April 08, 2018, 04:11:14 PM
by woodsdog2015
