Author Topic: Hydro Ax shear question about mulching attachment  (Read 691 times)
Offline H.Watts
« on: August 08, 2014, 08:56:27 PM »
I have come across a early 80's 311 Hydro Ax with a shear head.  I haven't seen it yet and am wondering if someone can tell me if a mulcher(brush hog) deck attachment can be used on this machine in place of the shear?  I don't have any experience with these machines but assumed the shear or saw head or mulcher units were all attachments.
Any info would be helpful.  Early 80's, maybe 1982.
Offline redprospector
Re: Hydro Ax shear question about mulching attachment
« Reply #1 on: August 08, 2014, 09:13:29 PM »
Hydro Ax used 2 shears on these machines. One was a "high speed" 16" shear, if you have that one then theoretically it should run a mower just fine. I ordered a set of books for my 311C and they had the specs. When I get near them I'll look up the flow and pressure again.
Offline MesquiteSawyer
    • Missouri Land Clearing LLC
« Reply #2 on: August 09, 2014, 01:22:51 AM »
I don't know that particular series, but have seen a bunch of old Hydro Axes that all ran mulchers.  A good friend used to buy old wore out fellers and swap out the felling head with a mulcher, sometimes needing to swap pumps as well.  He always said it was no big deal, and I don't think he ever spent more than $20k on a tractor.  He would run them for a year or two and usually sell them for double that amount.  I would say it is certainly possible if you are handy with that sort of thing.  Also depends on what you intend to mulch.  If you are just cutting brush, you should do fine.  If you are wanting 6" and larger stuff, I would start thinking drum style mulcher instead of rotary.
Hydro-Ax 221 shear wont cut. swapped heads.
Started by Jasen logger on Forestry and Logging
Last post November 28, 2015, 08:00:10 AM
by Jasen logger
Hydro Axe 221 Question
Started by Wes Lyon on Forestry and Logging
Last post October 13, 2012, 10:44:27 AM
by treefarmer87
WM hydro trailer question
Started by JustinW_NZ on Sawmills and Milling
Last post December 18, 2013, 02:02:27 PM
by JustinW_NZ
Resaw attachment question
Started by thechknhwk on Sawmills and Milling
Last post October 22, 2012, 12:56:02 PM
by thechknhwk
