Baltic Abrasives Technologies
Author Topic: sanding thick slabs  (Read 2872 times)
Offline copperhead10
sanding thick slabs
« on: August 23, 2014, 10:47:18 AM »
after you cut your slabs , air dry, kiln them, maybe plane them (with your slaber planer), how do you sand it ? do any of you folks use a floor sander? do you use a belt or drum sander? thanks for all the info.
Offline kevin19343
Re: sanding thick slabs
« Reply #1 on: August 23, 2014, 07:00:19 PM »
I have a shop built 36" drum sander. It works great but creates clouds of dust.
I also have a stroke sander that will sand anything you can lift onto the bed.
Offline WIwoodworker
    • Milwaukee Woodworks
« Reply #2 on: August 24, 2014, 10:09:32 AM »
I've seen people use all the methods mentioned. It really depends on what your final project is. I've seen people use a floor sander and get decent results but if you're going to do this more than once or twice either buy a wide drum sander or find a cabinet shop that has a wide panel sander and pay them to do it for you. You'll get much better and more consistent results.
Peterson 9" WPF
Offline red oaks lumber
« Reply #3 on: August 24, 2014, 10:19:01 AM »
if the surface is fairly smooth to start, i use my orbital sander, start with 60 grit and work up, if the surface is alittle rougher to start i'll go with 36 grit and work up.
i have a widebelt sander but, slabs tend to be heavy and awkward to handle plus the older i get, there is more than 16 oz. to the pound :D
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #4 on: August 24, 2014, 11:38:24 AM »
I have a wide belt sander that works well , but for REALLY big slabs I use a Surcare surface sander. I really like this machine for finishing off a slab after planing. Rob
« Reply #5 on: August 24, 2014, 12:01:04 PM »
that looks like a very very handy tool :)
« Reply #6 on: August 24, 2014, 03:28:51 PM »
That's a big boy tool. What size disks do you use?
Offline rasman57
  • Location: Manistee National Forest Pine River Michigan and Home in Illinois
  • When you come to a fork in the road...take it.
« Reply #7 on: August 24, 2014, 04:09:58 PM »
He creates unbelievable big boy masterpieces!  Very nice!
  • roborob
    • tule peak timber
« Reply #8 on: August 24, 2014, 04:47:56 PM »
6 inch disks, hook and loop.I start with 40 grit and progress to 320 before starting the fill process. Rob
Offline cypresskayaksllc
    • Cypress Kayaks LLC
« Reply #9 on: August 25, 2014, 11:53:19 PM »
festool sanders.
LT40HDDR, JD950FEL, Weimaraner
Offline Ianab
« Reply #10 on: August 26, 2014, 01:35:39 AM »
If you can get a good surface with your planing device (router bridge etc) then the slab doesn't need a lot of sanding. A machine like Rob shows is probably the ultimate, although a sanding disk on a swing mill is a quick way to tidy things up. ~20 hp orbital sander on rails   ;)
Otherwise a normal Random Orbital or even careful use of a belt sander will do the job. You should only need to be taking out some light "swirly" machining marks left by the router bit.
  • roborob
    • tule peak timber
« Reply #11 on: August 26, 2014, 09:42:40 AM »
   Cypresskayak mentioned Fesstool sanders , and yes they are strong ,really good tools.The little 2 inch random orbit Grex is a great tool for the natural edges, but requires quite a bit of air to operate. Lastly the purple 3-M sanding disks are my first choice in abrasives. Their purple "cubitron" abrasives in both disks and wide belts for the bigger machines out perform other abrasives and tend to not load-very good stuff ! Rob
Offline kevin19343
« Reply #12 on: October 04, 2014, 09:15:38 PM »
I have a bunch of sanders, but I've also done a lot of slab leveling with hand planes. I have a scrub plane to get the heavy stuff off quickly, and smoothing planes to get it flat. Sometimes I'll drum sand it down with #60 paper and plane it from there.
 It takes about 30 minutes to smooth a 36" x 72" slab even if its really gnarly. The finish is superior to sanding IMO. You'll need sharp blades
how thick to cut slabs
Started by ethanbrush on Sawmills and Milling
Last post March 11, 2014, 09:58:35 PM
by francismilker
drying thick slabs
Started by copperhead10 on Drying and Processing
Last post December 06, 2014, 06:15:37 PM
by addysdaddy
Kiln for thick slabs
Started by Seaman on Drying and Processing
Last post January 30, 2014, 10:38:27 PM
by WDH
Stickering thick lumber/slabs
Started by WV Sawmiller on Sawmills and Milling
Last post March 19, 2018, 09:37:14 PM
by YellowHammer
