Author Topic: Pine furniture pole question  (Read 484 times)
Offline ozarkgem
  • age 65 yrs old
« on: August 24, 2014, 09:33:18 PM »
I went to Colo and cut a load of furniture poles. . Do I need to peel l them now and let them dry or let them dry under cover and peel them later. I have not worked with these kind of poles. Not sure what species they are. Maybe someone  can identify them.
Offline beenthere
Re: Pine furniture pole question
« Reply #1 on: August 24, 2014, 09:55:19 PM »
Very likely lodgepole pine if from Colorado (CO).
Peeling can be learned as soon as you get a chance to test out your stash. I'd give a few a try and see how it goes, as they won't get any fresher. Depends a bit when they died, but suspect you will learn pretty quick what works the best.
Offline VT_Forestry
« Reply #2 on: August 25, 2014, 09:28:42 AM »
I can't speak for Colorado, but I know down here in Virginia it's so humid that I have to peel pine right away or it will get moldy and funky in a hurry.  Hardwood species seem to be a little more tolerant to drying with the bark on.  Peel a few and leave some be to test it out - see which method gives you the best end result for what you're making with them.
Forester - Newport News Waterworks
Lodgepole Pine Logs for Furniture
Started by lawnmasters on Sawmills and Milling
Last post October 08, 2009, 10:05:44 AM
by lawnmasters
Pine Pole Zig-Zag fence
Started by kaskers on Drying and Processing
Last post January 31, 2019, 01:29:33 PM
by kaskers
Pine pole layout video
Started by CCC4 on Forestry and Logging
Last post November 02, 2013, 10:28:45 AM
by GATreeGrower
6x10 Longleaf pine beams for a pole barn
Started by Kerrymr on Drying and Processing
Last post February 24, 2017, 07:06:14 AM
by GeneWengert-WoodDoc
