Author Topic: bar cost - $250 for a 48 inch bar !  (Read 3492 times)
Offline rebocardo
  • Atlanta GA
« on: July 24, 2004, 07:02:33 PM »
I have been checking out bar prices in case I bought a bigger saw to run it and the thing that really discourages me from buying a 48 inch bar and the machine to run it is the cost of the bar. Bailey's at $250 is just about the cheapest I can find a 48 inch bar. So, between the bar and chain, you are talking $300.00.
Why are 48 inch bars so much money, especially compared to 42 inch bars? For that extra six inches, you have a $200 price jump. Is it because so few people buy them or is there something I do not know about bars?
Offline David_c
  • treat people the way you want to be treated.
Re: bar cost - $250 for a 48 inch bar !
« Reply #1 on: July 24, 2004, 07:20:17 PM »
what do you need a 48" bar for in GA ::)
Offline Sawyerfortyish
  • Bigger they are the more mess they make
« Reply #2 on: July 25, 2004, 06:55:18 AM »
 Thats my  thoughts to why do you need such a big bar? Maybe if you have a chainsawmill. I have cut lots of trees logging over 30" and some even over 40" Dbh with a 24" bar.
Offline rebocardo
  • Atlanta GA
« Reply #3 on: July 25, 2004, 09:40:26 AM »
I have a white oak that is 48 DBH (a lot bigger with butt flare) that I might want to turn into 48"x2" rounds and maybe 48" slabs, if it can be cost effective.
I tried cutting 36 inch rounds on an earlier tree with my 28 inch bar and it did not come out correctly going from side to side.
The biggest I can fit on my mill is 24" wide, so if I get an Alaska type mill and 48 inch bar I can slab it where it sits after felling it. Which is the main reason for looking into a 48 inch bar.
Offline David_c
« Reply #4 on: July 25, 2004, 09:45:24 AM »
knew it had to be something like that have fun.
Offline DanManofStihl
  • Cut em down Dan
« Reply #5 on: July 26, 2004, 03:57:58 PM »
I know oregon and windsor make the 42 inch bar but they do not make anything bigger I dont think so you end up buying the expenive cannon or woodsman pro name if you try ebay they have some nice bars on their that are 48 inch Heres a link http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=20538&item=4314517625
This one is sitting at 50 for the bar and chain
Two Things in life to be proud of a good wife and a good saw.
Offline Furby
  • Blurb....
« Reply #6 on: July 27, 2004, 03:36:29 PM »
Did you do a google ???
For a bar that you may only use a little bit, you might find a no name for cheaper.
Offline rebocardo
  • Atlanta GA
« Reply #7 on: August 01, 2004, 03:54:58 PM »
I have done yahoo and ebay searches, no real results. Thank you for the E-Bay link, it is only for a Stihl, I have been watching for Husky stuff.
  • Cut em down Dan
« Reply #8 on: August 01, 2004, 05:32:29 PM »
I will keep a watch full eye out for a 48 inch bar for a husky saw. I mostly see them for stihl but if i see anything I will tell you you might want to email the guy who had the stihl bar he has alot of saw bars for sale. Thanks
Offline rebocardo
  • Atlanta GA
« Reply #9 on: August 03, 2004, 11:05:58 AM »
Thanks!
Offline sawguy21
« Reply #10 on: September 15, 2004, 10:07:22 PM »
You wanna see what we pay in Canbucks for bars, or anything else for that matter. The demand for the 48 is so low that production costs make the pricing brutal. It is too unwieldy for use on anything except a mill. Ever tried packing on on a 090?
Offline Stephen_Wiley
  • Forester.
« Reply #11 on: September 16, 2004, 01:11:22 AM »
Rebo,
I will make some calls and see what is currently available.
We have a few hidden bar shops out here, that cater to the big saws.
What size of Husky are you trying to fit ?
" If I were two faced, do you think I would be wearing this one?"   Abe Lincoln
Offline rebocardo
  • Atlanta GA
« Reply #12 on: September 16, 2004, 08:59:38 AM »
I was going to put it on a new Husky 395. But, decided to go with a 365 because of my limited mill use (so far) and save more money for a Husky 3120 that I would use just for the chainsaw mill. The 365 is way too slow and underpowered so I stick with 14" wide logs on the 28" bar, even if I have to split them before I saw them.
Offline sawguy21
« Reply #13 on: September 16, 2004, 10:24:54 PM »
Minimum 372 on that mill. The more the better
Offline jokers
  • Chainsaw Freak
« Reply #14 on: September 17, 2004, 07:11:00 AM »
Rebocardo,
I`m a little confused, though since I`m simple I`m not too alarmed, but are you planning on running the 48"er on your 365 for the time being after the statement about the 365 being way too slow and underpowered to handle anything larger than a 14" log on the 28" bar?
After reading your other post about the carbon chunks and buildup on your sparkplug, I think that you are leaving alot of power "on the table" by running your carb way too rich. If you can`t set your carb adequately by ear and power in the cut, try having it tach set about 300-500 rpm below factory spec and see how it performs.
When you get back to looking for the long bar, check out Jeff Sikkema at http://www.snssawshop.com, he sells GB products. They make excellent bars and mills.
Russ
Offline rebocardo
  • Atlanta GA
« Reply #15 on: September 19, 2004, 10:40:00 AM »
No.
Correct, unless I like going from feet per minute to inches per minute. I finally have the mill, saw, and chains set up so I can do feet per minute.
I will try that. I guess my automotive tach does not work correctly (at all) on my saw. I guess I need one just for a two cycle.
  • Forester.
« Reply #16 on: October 08, 2004, 11:59:10 PM »
Rebo,
Checked with bar shop, currently their is a 50" 'Cannon' hanging inside the door for $100.00
However, the shop produces bars out here for our big wood a manufactured 60" is $225.00
The above mentioned 'Cannon' was formerly used for slabbing and is about 1/2 the thickness of the bars he makes. The Cannon owner bought one of his to overcome the bar sway issue.
Since the bars are manufactured here they are made to fit whatever power saw you have.
If interested send me a pm and preferred chain saw application.
Offline John_Boisselier
« Reply #17 on: October 10, 2004, 06:17:03 PM »
You can contact GB American directly for top notch GB bars (and quite a bit of other stuff too) and get a far better price than what I've seen anywhere else on really quality titanium bars.  They usually get them to you pretty fast too.
GB AMERICAN Inc.
Rt. Whitefield Road,
P.O. Box 514
Lancaster, New Hampshire
USA 03584-0514
Phone: 603-788-2825
Fax: 603-788-4529
The Woodsman
6 inch piece of wood cost $2000.00
Started by just_sawing on Sawmills and Milling
Last post June 27, 2013, 09:43:35 PM
by rmack
10 inch X 4 Inch beams Coastal Douglas Fir
Started by ultraglide62 on Drying and Processing
Last post June 11, 2012, 10:36:24 AM
by metalspinner
Nine inch post oak vers four inch white oak..
Started by Banjo picker on Ask The Forester
Last post November 01, 2008, 09:06:18 PM
by Banjo picker
Mortising 8 inch x 8 inch hardwood posts
Started by christopherw on Drying and Processing
Last post December 22, 2008, 07:55:28 AM
by Meadows Miller
