KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Useful sawmill mods  (Read 276291 times)
Offline Bob_T
Re: Useful sawmill mods
« Reply #1300 on: August 12, 2017, 08:48:03 PM »
I'm only halfway through reading the 65 pages in this thread and I haven't had my mill (1992 LT30) long enough to learn how to use it, much less try and improve it but I did make a minor mod.
When I got the mill the blade guide roller adjustment arm was flopping all over, up down and left and right.  Every time I thought I was  making progress by adjusting the cam bolts per the manual, I'd turn something the wrong way and be back at square one.  I ended up engraving a line on the bolt heads marking the cam high points.  Now I at least have an idea where the cam high and low points are and which direction things are going to move when I make an adjustment.
1959 FWD Model 286 Dump Truck
1955 Allis Chalmers HD-6G Crawler Loader
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #1301 on: August 13, 2017, 10:46:53 AM »
What is the issue with two tanks? nn 950 hours and 9.5 years the only hydraulic issue I've had was one bad solenoid.
Offline Bandmill Bandit
« Reply #1302 on: August 13, 2017, 11:03:03 AM »
No matter what I have done to get the return oil to flow to both tanks evenly it doesnt work very good, so I get over flow out the vent cap on the outside pump/tank ALL the time. If some one has a hint that would help me out here I wouldn't bother. The return hoses and fitting are EXACTLY the same, but that doesnt seem to help much.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4.
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built my self
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #1303 on: August 13, 2017, 11:12:06 AM »
So what would happen if you closed that vent and then the oil would just go to the second tank ?
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #1304 on: August 13, 2017, 11:29:03 AM »
Flowing out of one vent is what happens when one pump isn't  working (for me has been total pump or solenoid failure).  Is it possible one of your pumps isn't pumping as fast as the other?
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
« Reply #1305 on: August 13, 2017, 12:08:43 PM »
I have tested the pump flow by disconnecting power from each pump separately and the hydraulics seem to be about the same on each pump.
Offline BigZ La
« Reply #1306 on: August 13, 2017, 12:26:28 PM »
I would put a pressure gauge and run each pump separately under normal lineup. Find out if one is running higher pressure than the other, it could be something as simple as a plugged suction or a bad pump.
« Reply #1307 on: August 13, 2017, 04:04:32 PM »
Have you examined the connections across the bottoms of the two pumps to see if the bore of the fittings and connecting hose is maximized?
Offline Nicefeller
« Reply #1308 on: August 13, 2017, 06:28:25 PM »
Another thing to consider is the hose lengths. The longer hose will have more resistance to flow and the flow rate will decrease slightly. The only reason I mention legth is because I encountered a similar problem with fuel flow rates.
« Reply #1309 on: August 13, 2017, 07:54:06 PM »
the hose length was the first thing I did a change up on and had a hose and T fitting made out of that slippery red silicone hose by the local Pumps and Pressure shop. Also made sure that the path they run is very smooth with no sharp bends.
 They also did a pressure test with an electronic test system and pressure was within the spec range and with in 5 PSI of each other.
Have not checked the line that connects the tanks across the bottom. Didnt think of that one.
Thanks for the reminder terrific
Offline DDW_OR
« Reply #1310 on: August 15, 2017, 01:13:19 PM »
cleaning band blade before removal
before i take the dull blade off i idle down the engine to the lowest speed, then engage the blade clutch, then use an angle grinder with a wire wheel to remove any buildup on the band blade.
i do all of this while standing BEHIND the blade teeth.
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline pineywoods
« Reply #1311 on: August 19, 2017, 11:06:20 AM »
JP clutch re-visited.  Local sawyer just back to sawing after some extensive surgery. Found he couldn't pull the clutch lever on his lt40 super. Them kubota diesel engines are heavy  ::) I remembered a post by member JP green about adding a helper spring to reduce the force needed to engage the clutch. We used a 6 inch long piece cut from a stretch type garage door spring. Wedge a couple of the coils apart and cut with a hand held grinder. Bending a hook on each end is a bit of a job. the bottom end hooks under the pin on the end of the brake band. Upper end hooks to a small eyebolt through a hole drilled behind the water tank. With the clutch engaged, there should be a little tension on the spring. Dis-engage the clutch and the spring will support some of the engine weight. Makes a big difference in the effort required to pull the clutch lever. Not as good as an autoclutch  option, but it would make a big difference if the old shoulder is showing some wear and tear.
Offline pineywoods
« Reply #1312 on: August 19, 2017, 11:22:53 AM »
Buck $1.98 redneck autoclutch for woodmizers.. Clutch lever too hard to pull for whatever reason ? Short piece of 2 inch pvc pipe and 6 foot of rope. Holes drilled in the pipe and rope attached. Return mill head all the way back to the hitch end. Drop the pipe down over knob on the clutch lever, the tie the other end to the hitch / sawshed post etc. Hold pipe in place with right hand and actuate forward lever. The head moves forward about 6 inches and pulls clutch lever nicely. The pipe will just pop off . Worked good for leroyC after a heart bypass...
Offline JB Griffin
« Reply #1313 on: November 25, 2017, 08:39:05 PM »
Bandmill Bandit, did you ever fix your dual pump issue? Going to put another pump on mine and was wondering.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline barbender
« Reply #1314 on: November 25, 2017, 11:14:38 PM »
Good mods, Piney!
Offline 47sawdust
« Reply #1315 on: November 26, 2017, 06:08:39 AM »
Wow! an autoclutch for $1.98,that is truly a good deal.
Mick
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #1316 on: November 26, 2017, 08:13:33 AM »
Brilliant idea.
HobbyHardwoodAlabama.com
« Reply #1317 on: November 26, 2017, 06:39:35 PM »
In the process right now. Changing the bottom pipe bungs on the tanks to 1.5 inch black pipe and will connect the tanks with 1.5 inch tube with a 1.5 Black T at center to allow for a good drain for the tanks.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #1318 on: November 26, 2017, 07:55:03 PM »
That $1.98 autoclutch mod could really come in handy on those days when your shoulder needs a little help!    thumbs-up
~Chuck~
I LOVE MY SAWMILL
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #1319 on: January 02, 2018, 06:42:45 PM »
DDW: I don't use an angle grinder, that's too high tech for me. Instead, I keep a few 8" lengths of busted blade on the sawmill console and with the blade running full speed, carefully put a piece of busted blade down onto the moving one to scrap off the pine resin build up. Works like a charm as long as, as you said, you do it from the backside of the blade. Turns out I have to do this most anytime I'm cutting resin-full pine when even the pinesol blade drip doesn't keep up. Simplest solution I could come up for a really vexing problem cutting SYP.
LJ
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
sawmill mods
Started by doug olsen on Sawmills and Milling
Last post April 04, 2016, 04:25:41 PM
by WDH
Woodland Sawmill Mods
Started by Billbob on Sawmills and Milling
Last post December 15, 2013, 04:21:35 PM
by Billbob
Home made sawmill mods.
Started by Clover on Sawmills and Milling
Last post March 22, 2017, 08:47:16 PM
by Clover
Mods for a 460 Mag
Started by Ga_Boy on Chainsaws
Last post April 04, 2006, 05:54:41 AM
by Ga_Boy
