Author Topic: Useful sawmill mods  (Read 291427 times)
plowboyoo51 and 5 Guests are viewing this topic.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Useful sawmill mods
« Reply #1400 on: March 15, 2019, 07:23:03 PM »
That looks good! thumbs-up
I consider the power anywhere mod one of the best, most useful things that can be done.  As you say, using the power strip in tandem with the hydraulic anywhere mod gives you the best of both worlds.
It also has the added benefit off solving the power strip arcing issue, which is caused by working the hydros when the head is traveling.  So its of multiple benefit, and it allows and operator to make movements on the fly, at any time, even when the head is moving.  It allows simultaneous movements, instead of sequential, which really speeds things up.
One one my favorite techniques is to raise the backstops as soon as the head passes, when edging.  The backstops will keep the edgings from falling off the left side of the mill, assuming they are tall enough relative to the boards being edged.  Then I clear the edgings, and drop the backstops about halfway down the height of the edged boards with the mill head still on the far end, non power strip side, and then drag back all the edged boards to the roller table.  No more pulling edged boards back by hand.
HobbyHardwoodAlabama.com
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #1401 on: March 15, 2019, 09:28:30 PM »
@terrifictimbersllc I had trouble with my cables wearing through the coating so I had to put them in tubing to protect them.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline trapper
« Reply #1402 on: March 15, 2019, 09:54:22 PM »
MM where did you find the led tail lights to replace the originals on the mill?
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #1403 on: March 16, 2019, 04:28:00 AM »
There was a similar gouge in one of my three wires, maybe 8 ft back from the head-you can see where I taped it in one of the photos-I believe this happened with it catching a piece of wood falling into the tracks-but no wear elsewhere.  I do like the idea of putting the wires in a casing though. I'll keep this in mind if something else happens, thanks.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #1404 on: March 16, 2019, 08:13:49 AM »
Here is what I used:  LINK
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Fixing New EPA Gas Tank Problem
« Reply #1405 on: Today at 03:07:19 PM »
Even before I bought my new LT40 Super-Wide I knew I was going to hate the gas tank arrangement.   I had seen the new EPA mandated tanks on the Woodmizers at a few shows and did not like the idea of having to fill up the tank, not only on the machine, but while on site milling for a customer.   I had an 2nd tank for my old LT40 that that could easily be swapped out when needed.    It didn't take more than once or twice spilling gas while trying to refill this new arrangement that I was serious about finding a solution.     First I ordered a new tank from Woodmizer.  Then I spent some time  trying to figure out the best way to mount a handle on it for lifting and carrying it similar to any regular gas can/tank.   Drilling holes to mount a handle was out of the question. So I had to find a better solution.
I ended up buying a $5 barn door handle at the local farm store and mounting it on a strip of gray UV safe 1/4" thick PVC with counter-sunk machine screws.  The PVC strip was then attached on top of the tank with 4 extra long heavy duty (170 lb) UV safe tie-wraps.   In addition to countersinking the screw holes I filed notches in the PVC strip where the tie-wraps crossed to keep the handle from sliding end-to-end.
Then I added a set of quick-connect fitting to the fuel and air return lines so the tank can be pulled and swapped quickly.   The fittings came from US Plastics.   I could have gone with plastic to save a few bucks, but went for the better quality brass fittings.   I put the male fittings on the tank and the more expensive female fittings on the sawmill end of the lines.  That way I only needed to buy one set of the more costly ones.   You'll need one set of male fittings for each tank you do.  The fittings I chose are also "shut-off" when disconnected.  That way no fuel will spill or drip.   Below are links for each of the fittings I used.
I suppose you could do this mod for a single tank and just remove it from the mill and fill it at ground level if you want to.  I'd rather have the 2nd tank ready to go.
Fittings
1/8" In-Line Hose Barb MC Series Chrome Plated Brass Insert - Shutoff | U.S. Plastic Corp.
1/4" In-Line Hose Barb MC Series Chrome Plated Brass Insert - Shutoff | U.S. Plastic Corp.
1/8" In-Line Hose Barb MC Series Chrome Plated Brass Body - Shutoff | U.S. Plastic Corp.
1/4" In-Line Hose Barb MC Series Chrome Plated Brass Body - Shutoff | U.S. Plastic Corp.
I haven't installed them yet because of the rain and mud but the metal box around the gas tank is removed and the modified tank will be held in place like on the older mills using the black EDPM tie-downs.  This will make swap out quick and painless.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
sawmill mods
Started by doug olsen on Sawmills and Milling
Last post April 04, 2016, 04:25:41 PM
by WDH
Woodland Sawmill Mods
Started by Billbob on Sawmills and Milling
Last post December 15, 2013, 04:21:35 PM
by Billbob
Home made sawmill mods.
Started by Clover on Sawmills and Milling
Last post March 22, 2017, 08:47:16 PM
by Clover
more lt 15 mods
Started by alanh on Sawmills and Milling
Last post August 24, 2018, 02:42:42 AM
by charles mann
