Author Topic: Useful sawmill mods  (Read 298835 times)
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Useful sawmill mods
« Reply #1460 on: May 26, 2019, 12:26:21 AM »
Never.  Havenít for going in a little more than three years, even with whitewood and other sticker stain prone species.  As a matter of fact, the deadstacked 9/4 boards in the picture is a very sticker stain prone wood, basswood.
I will raise some eyebrows with my strategy and technique, but it works, and has little or no degrade, or I couldnít sell the high grade lumber.
Itís very unconventional, though.
I estimate that stickering by one person takes as much as much as 50% time as sawing with 4/4 and maybe 100% as much time as sawing with 8/4 and 12/4.  So I can sometimes double my sawing production, when sawing alone, which I do most of the time, by deadstacking, and keeping the blade turning.
So I separate the jobs to be more efficient.
Since we have about 20 different species of wood in stock, I pick and choose when I mill what.  So Monday through Wednesday I cut and deadstack more sticker stain resistant wood, such a cherry, walnut, oak, sassafras, etc, either in 4/4 and 9/4.  Then Thursday and Friday I get into the more sticker stain wood like maple, poplar, and even basswood.  All are deadstacked off the mill onto pallets and placed under a covered shed.  Then on Saturday, our main open sales day, I bring in three part time employees, including Martha, two of which run the cash registers, and one who I pay as a dedicated lumber stacker.  His only job is to sticker all the lumber I milled during the week and unsticker what comes out of the kilns.  So, I outsource my lumber sticking just as I outsource my planing and get it all done in one day.  The third employee and I both float, so if the stacker needs help I will help with the customers and they will double up with him.  Or I will give him a hand if we are not too busy.  So at any one time on Saturday we may have 1 to 3 people sticking and deadstackimg the weekís wood, or have 1 to 3 people on the sales floor, helping customers or cashing them out.
So in a single shift, one day a week, we as a team may be able process up to 12 pallets of wood, both kiln dried and green in addition to handling the sales of up to 150 customers.  Our dedicated stacker guy gets about 15 cents per bdft and most days earns a very decent paycheck.  I simply consider it the cost of doing business, same as paying 15 cents per bdft to outsource my planing and having to pay for an extra cashier.  I wouldn't need the extra help if I wasn't selling the lumber, so its not a bad thing.
HobbyHardwoodAlabama.com
Online Southside
« Reply #1461 on: May 26, 2019, 07:45:05 AM »
He gets about 15 cents per MBF
Just what kind of dirt do you have on that poor lad to get him to work for that? :D
« Reply #1462 on: May 26, 2019, 07:51:34 AM »
Oops, I corrected it.  About 15 cents per bdft.
Online Southside
« Reply #1463 on: May 26, 2019, 07:58:15 AM »
Shucks - I was hoping he had a brother that needed steady work.   ;D
« Reply #1464 on: May 26, 2019, 03:20:51 PM »
After this weekend, I hope he comes back.  95 degrees, no wind, brutal conditions.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #1465 on: June 10, 2019, 07:36:04 PM »
   For those of you who have a nice WM Vinyl cover, or equivalent, for your mill and have developed a hole or two and need to patch it I have found a handy fix is to buy a can of silicon spray from your local Auto Parts place (I got mine from Advance Auto), take an old pair of blue jeans or equivalent and cut out a couple of patches slightly larger than the size of the hole(s) and spray both sides of the patch, let it dry, then liberally apply a good coat of silicon glue (also readily available at the auto parts store) on the first patch and place it over the hole then do the same with the second patch and place it on the other side of the cover and press them together tightly trying to make sure to ensure the edges are glued well and let it dry. This gives you a flexible, waterproof, relatively inexpensive and heavy duty patch.
This is a picture of the can of silicon spray I used.
 As a side note it is probably better if you remove your vinyl cover from your mill before cranking it even if you only plan to run it a minute or so. If you do that you may never have to make and use one of these type patches but I digress.... ???
Offline Just Right
    • JustRightSawing
« Reply #1466 on: June 11, 2019, 10:41:14 AM »
LMAO.  I will remember that!  Well mine was on the ground long enough the squirrels found it!  Bunch of lil holes. . . . .roll of Gorilla tape and the wife . . . . .she fixed it up both inside and out made a good patch!
If you are enjoying what you are doing,  is it still work?
Online WV Sawmiller
« Reply #1467 on: June 11, 2019, 10:57:34 AM »
   That may work well for small holes but when they are much wider than the tape  it does not hold up so well - at least it did not for me. I had a couple about 5-6 inches wide/diameter so had to find an alternative.
Offline Just Right
    • JustRightSawing
« Reply #1468 on: June 11, 2019, 01:09:16 PM »
I hear ya.  So how long does it take to burn a hole in that type of cover?
Online WV Sawmiller
« Reply #1469 on: June 11, 2019, 09:55:29 PM »
   Mind you I can neither confirm or deny that I have ever committed such and act :D but I have it on very good authority it only takes a minute or so for the exhaust to get hot enough to burn right through the vinyl cover. ;)
sawmill mods
Started by doug olsen on Sawmills and Milling
Last post April 04, 2016, 04:25:41 PM
by WDH
Woodland Sawmill Mods
Started by Billbob on Sawmills and Milling
Last post December 15, 2013, 04:21:35 PM
by Billbob
Home made sawmill mods.
Started by Clover on Sawmills and Milling
Last post March 22, 2017, 08:47:16 PM
by Clover
Mods for a 460 Mag
Started by Ga_Boy on Chainsaws
Last post April 04, 2006, 05:54:41 AM
by Ga_Boy
