Author Topic: Ash for flooring  (Read 2345 times)
Offline Lenny_M
Ash for flooring
« on: July 25, 2004, 02:54:40 PM »
 What would be the best way to saw Ash for Flooring.Should it be quarter sawn or flat sawn??
The logs are 24"-30"x16`
                               Thanks Lenny
Re: Ash for flooring
« Reply #1 on: July 25, 2004, 03:14:18 PM »
I'm not much on Ash or some of the other woods you fellows up there saw but I can give you something to think about.
Most flooring is cut "vertical grain", if possible,  for a reason
Vertical grain moves side to side and can be pulled up tight to the next board.
Flat sawn boards lift, and while they can be nailed down, are always trying to pull away from the joist or subfloor.
Vertical grain boards expose more "late wood" (harder) to the wear surface than flat sawn boards (early wood).  Since the late wood is denser and harder, it wears better.
Flat sawn boards suffer from a problem called "shelling".  That is when the late wood and early wood separate from one another and the layers project up from the floor.
Even if the layers of a vertical grain (quarter sawed) board were to separate, the layers would be contained and wouldn't be exposed to foot traffic.
That may not be the specific info you were looking for but it is some general stuff that I have learned. :)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #2 on: July 25, 2004, 04:05:18 PM »
  This may not help.  ::) ::)  If you would like to compare each method and how it will look, go to Heartpine.com. They have the different looks, showing vertical and flat sawn flooring.
 What Ash I have sawn, in Arkansas, I doubt if the shelling that Tom illustrated would happen. I made stair treads from Ash and never put a finish on it. It stayed smooth, did not raise splinters.
Offline Lenny_M
« Reply #3 on: July 27, 2004, 02:47:05 PM »
   Thankx Tom and deadheader
                                    Lenny
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #4 on: July 27, 2004, 08:39:10 PM »
   Ash make a very nice light colored floor and holds up to wear.  It does better flat sawn for the grain looks and is fairly stable wood.  You can qsaw it but it does not have any rays to make it eye poping but it is more stable.   Tom is used to pine about 20 inches wide and it takes some holding down.
 But in boards less then 8 inches cupping should not be a problem is dried right and if the log did not have shake then the boards should not shell or break apart.
ARKANSAWYER
ARKANSAWYER
Offline stevareno
« Reply #5 on: July 27, 2004, 09:44:48 PM »
Do you guys end match your flooring?  We ran a flooring job out of Ash a few days ago but we just squared the ends of the boards..  I personally don't see anything inferior about flooring with square ends as opposed to t&g ends but it seems most of the large mills end match their flooring..  Any opinions?
Steve
Offline iain
  • bonnin stuff
    • Leafbone Furniture
« Reply #6 on: July 28, 2004, 02:23:22 AM »
i LOVE ash flooring and t&g all round so it dont have to end an joist its also worht taking a punt on the upper sections for some stunning grain patterns you may need to cut a little over thickness to allow for any warping around the branch joints but ive not had many probs with my dh kiln and the end result is normaly well worth an extra pass on the thicknesser
Offline stevareno
« Reply #7 on: July 28, 2004, 09:53:29 AM »
Aian,
What system do you use to t&g the ends?  I've looked at some end matchers but they cost around 80,000.00 for a high production model.. I've heard of people doing it on a shaper but that just seems very labor intensive..
Offline iain
  • bonnin stuff
« Reply #8 on: July 28, 2004, 03:48:00 PM »
dont laugh but i use a matched pair of cutters in a pair of big routers takes about 14 seconds to do the ends from picking up the board to ready to pick up the next one :) but then all of my floors are top end hand made
Offline Lenny_M
« Reply #9 on: July 31, 2004, 06:11:17 PM »
 The ash log owner decided to have it flat sawn. It will match better with the ash floors in the rest of the house.
T&G flooring
Started by dean herring on Drying and Processing
Last post August 31, 2017, 09:49:58 PM
by TKehl
flooring
Started by donald_harby on Wanted
Last post May 02, 2007, 08:26:44 AM
by donald_harby
T&G Flooring
Started by sawwood on General Woodworking
Last post September 28, 2016, 09:30:19 PM
by sawwood
Flooring
Started by Wes on Drying and Processing
Last post March 26, 2004, 03:58:19 PM
by Wes
