Author Topic: Has anyone made removable hitch for WM trailer?  (Read 844 times)
Offline flatrock58
« on: September 21, 2014, 07:50:56 AM »
I was thinking about making a removable hitch for my WM trailer.  Maybe using a 2" receiver and setting it up to use with a pintle.  Just wanted  to see if anyone had some pictures of what they had done.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline drobertson
Re: Has anyone made removable hitch for WM trailer?
« Reply #1 on: September 21, 2014, 08:00:03 AM »
might try and search pintle  hitches, I know at least one member has done it, loves it he said, makes hooking up lots easier
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: September 21, 2014, 09:27:15 AM »
I just take the two bolts out and throw the hitch in the weeds so I don't hit my legs on it. ;D
Offline NMFP
  • 1895 01 Frick Handset(Steel) 2000 WMLT40SH
« Reply #3 on: September 21, 2014, 10:06:03 AM »
I have the stuff to do it but just have not done it yet.  Its very simple and makes backing up to it much easier.  Also, when I plan on welding it, I plan on making the tongue a little longer so that I can swith the controls around and be able to saw with the truck still hooked to the mill.  Some jobs its a real pain to unhook and then rehook just a few hours later and do the same thing in the afternoon.
Someone on here posted a few pictures of their set up but I cannot remember who it was.
    • My homepage
« Reply #4 on: September 21, 2014, 10:14:35 AM »
How will you level the mill with it hooked to the truck? I agree on the pintle hitch. I hate ball couplers.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #5 on: September 21, 2014, 10:15:51 AM »
I changed mine to a ring.
lots of dull bands and chains
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #6 on: September 21, 2014, 11:17:15 AM »
     I saw with the mill still on the truck regularly.  I've got a full set of FAOs; I don't know if that makes a difference or not.  And of course all the outriggers are used every time.  But leveling the mill is no problem.  A few days ago I did two separate jobs, a couple of miles apart, and was still home in time for an early lunch.  The mill didn't come off the truck until I parked it at home again.
     I agree with the pintle hitch too!
WoodMizer LT50HDD51-WR
Lucas DSM
Offline NMFP
« Reply #7 on: September 21, 2014, 11:18:50 AM »
I will typically level the mill by the use of ramps and so on which I already do.  If I need to level the mill side to side, I place boards under the tires to help raise or lower before I put down the jacks.  if I need to raise or lower the mill end to end, I can place boards under the rear tires of the truck to raise the hitch of the mill, not to mention that I have an adjustable hitch that I can raise up and down on the truck.
Simple modifications can save numerous hours of wasted time.
Offline NMFP
« Reply #8 on: September 21, 2014, 11:22:11 AM »
I should mention that I have stationary command control on my mill so turning that around all the time is almost impossible with my flatbed truck as it hits the back of the truck before its completely turned around and operable.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #9 on: September 21, 2014, 11:25:17 AM »
When we set up we drop the mill pull forward 4'-5' drop the tailgate and have a work bench.
The other day I had a log walk back on the mill while turning it to whitle it down. It was to heavy for the drag back so thru a chain around it and hooked a comalong to the truck and pulled it back forward on the mill.
I went to cross over the cable while it was tight while the customer had my attention. That cable told me right quick like that I did not have my foot high enough and I was picking myself up off the ground ::)
Stepping over the hitch all day "will" be a "real" pain ;D
Have never found hooking up to the hitch to be much of a chore, but do like pintal hitches as the are heavier built.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #10 on: September 21, 2014, 12:18:39 PM »
  smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
Offline barbender
« Reply #11 on: September 21, 2014, 12:33:32 PM »
X2,  I was thinking about putting some quick hitch pins in mine to make it quick to pull off, as the bolts that are used don't hold the hitch rigid anyways.
Offline flatrock58
« Reply #12 on: September 21, 2014, 02:16:09 PM »
I was thinking about doing what Dan did with the pintle.  Bought a 2" receiver but it would not fit inside of the square tubing for the WM hitch  I do like the ability to remove the hitch and the ease of the pintle though.
Steve
6' extension
resaw attachment
CBN Sharpener
Help identifing trailer hitch
Started by FarmingSawyer on Sawmills and Milling
Last post November 30, 2014, 07:27:31 AM
by FarmingSawyer
Trailer hitch cover question
Started by Jim_Rogers on General Board
Last post September 08, 2012, 06:53:05 PM
by Jim_Rogers
How to free a rusted trailer hitch ??
Started by chainsaw_louie on General Board
Last post September 28, 2006, 08:49:10 PM
by JimBuis
Ballast box/skidder/trailer hitch
Started by firefighter ontheside on Forestry and Logging
Last post June 06, 2018, 02:12:54 PM
