Author Topic: Automated Twin blade sawmill build.  (Read 38651 times)
Offline CaseyK
  • Keep it simple enough anyone can operate it
« on: September 24, 2014, 10:19:37 AM »
Hi everyone, im a newbie so thanks for the add. I have been enjoying reviewing your forum and seeing all of the home builds.  Im building a 35hp diesel twin blade sawmill. I got the engine last week from and have started on the frame this week. Ive got 3 main questions that i was hoping to get some input on.
1st Does anybody have a source for a 35hp electric clutch supplier (1.75" bore)or would a belt tensioner apparatus be sufficient to engage and disengage the load for starting the engine?
2nd For the vertical blade i found a supplier for Lucas blades (16.7 5 tooth) but was wondering if anyone knows of a supplier for the arbor shafts besides just having one milled in a machine shop?
3rd For the horizontal blade i was hoping to be able to cut 10" boards so im thinking i will need a 26" blade. What would be the tooth count i would be looking for with this 26" blade? Most of the blades ive seen had a large tooth count which im thinking would require more HP than i have available, so would a 10 - 15 tooth blade be what i need? Also if anyone knows of a supplier for the horizonal blade and possibly a matching arbor i would greatly appreciate it.
Home built automated twin blade
Offline Hilltop366
Re: Twin blade sawmill build questions.
« Reply #1 on: September 24, 2014, 11:57:48 AM »
Welcome to the Forestry Forum. I'm sure someone will be along soon with some good advice, sound like a interesting build.
Offline CaseyK
« Reply #2 on: September 24, 2014, 05:22:44 PM »
Reviewed the forum some more and found some great news concerning getting saw blades from B.H. Payne so i gave them a call and they were a big help. They had a 5 tooth lucas style 21" edger blade and a 8 tooth peterson style 26" vertical  blade in stock and ready to ship so i ordered them. And now to get the gear box and roller chains ordered tonight.
Offline Hilltop366
« Reply #3 on: September 24, 2014, 06:35:57 PM »
Gerat, I'm hoping you will to bring us along with the build.
Offline bandmiller2
« Reply #4 on: September 24, 2014, 08:38:42 PM »
Welcome Casey, An electric clutch for that size engine would be costly, "V" belts with a over center pulley to tighten them would be much more affordable and do the same job. Depending on the engine mechanical clutches are available but also costly. Where are you located Casey.?? Frank C.
Offline Don_Papenburg
  • I need money
« Reply #5 on: September 24, 2014, 09:31:33 PM »
If you want to automate the overcenter clutch get a small hydraulic cylinder . You are going to have hydraulics on your mill  ?   Electric clutches snap in fast ,jerking everything they engage to speed right now .  That is harsh on equipment.
Offline CaseyK
« Reply #6 on: September 24, 2014, 10:15:57 PM »
Hi Frank, Im located in North Louisiana near a small town called Farmerville.
Don, yes, i will have hydraulics on the mill and a small hydraulic cylinder should work great for the overcenter clutch. Thats a great idea. I haven't seen that yet in the forums.
I found a great deal on a military surplus air compressor an individual had purchased a few years ago and was needing it anymore. Gave him 375.00 for a 35 HP Kubota diesel mounted on trailer with 5 piston air compressor and air tanks. Removing the air compressor took a while but she cranks right up and is hitting on all 4 cylinders.
Im going to give this picture posting a try to showw the before and after compressor pics and the start of the 10x4x8ft high frame (laying on its side).
Offline CaseyK
« Reply #7 on: September 24, 2014, 11:14:47 PM »
Any lucas operators with the  21" 5 tooth blades tell me what rpm your running at?
Also any Peterson operators using the 26" 8 tooth blades tell me what rpm your running at?
Offline tjhammer
« Reply #8 on: September 24, 2014, 11:59:55 PM »
Hi Casey I think Lucas runs a 1 to 1 gear box so the blade would run @3600 rpm and I think the Peterson is the same, I have a Lucas blade I run on my saw but I had Payne to hammer it for 3200 rpm Peterson has a 6 bolt pattern and Lucas 5 bolts, Payne does good work, I started on a two blade saw myself but haven't done much but gather parts I have a 22 horse Kubota for the big saw and thought about running a electric on the edger
tj
hammer
Offline Hilltop366
« Reply #9 on: September 25, 2014, 07:18:49 AM »
B.H. Payne should be able to tell you what rpm the blades are designed to be run at.
Great score on the Kubota!
Offline CaseyK
« Reply #10 on: September 25, 2014, 04:50:29 PM »
Today i got the casters, rollerchains, sprockets, gearbox, pullys, bearings, and conveyor chains ordered. Now to get some welding done this evening and go look for a car axle tomorrow for the arbors.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #11 on: September 26, 2014, 12:16:47 AM »
How big and long of log are you setting up to handle?
Will you drag back cants?
Offline CaseyK
« Reply #12 on: September 26, 2014, 04:51:14 PM »
Hi Backwoods Sawer
Im probably going to build the tracks so i can do a 24ft cut and im thinking it should handle a 5 ft diameter log. It will have the ability to pull average side boards back.
I got the engine pulled last night and its on the back porch.
Just received my first shipment of pulleys and parts in just a second ago and placed an additional order for some more stuff also.
Talked to B H Payne and they were able to locate a 545 blade with the Peterson hole layout so that both of my arbor layouts will match, however the 660mm blade will have 4 additional holes that the 545 blade does not have.
The 2 truck axles should get dropped off this evening and hopefully if my buddy is home we can get the shafts turned down and cleaned up tomorrow.
I went with a design for 1900 rpm for the 660 mm blade and 2400 for the 545 mm blade so that if i did ever decide to go with inserted tooth blades the speeds would already be slow enough.
After welding tonight i still have to dig through the forum to decide how to power my carriage up and down, it has 4 post which are 10ft left and right wide and 4 ft fwd and aft), and on each end of the carriage there is 2 shafts with 2 sprockets on each shaft there will be one 10ft of 50H roller chain attaching to the top of each post coming down to the sprocket below it then going horizontal to another sprocket (4ft) then down the post and attaching to the post. there will be one 1-1/4 drive shaft connecting the left and right of the carriage. I purchased a 20:1 gear box with a 1-1/4 hollow output shaft from surplus center and am planning on driving it with a hyd motor with a 1" shaft stuck directly into the gear box.
From there i have got to settle on exactly how im going to power the travel of the frame down the tracks.
Hope everyone has a great weekend. I am going to try to get some pictures posted this weekend.
« Reply #13 on: September 26, 2014, 05:22:18 PM »
Look forward to seeing it all come together.
Offline pineywoods
« Reply #14 on: September 27, 2014, 09:31:29 PM »
Casey, to answer your IM questions, my mill uses a 12 volt dc motor driving a gear box hooked to a roller chain for head position. Carriage travel is a bigger 12 volt variable speed motor driving V belts and a long roller chain. The factory hydraulics uses a 12 volt dc power pac. My mill is fixed, so I get away with a 110 volt ac motor to run a small gear pump. Standard cylinders to power a log turner, log clamp, adjustable backstops, and toe roller for log leveling. No log loader, I use a tractor with homebrew hydraulics and forks to load logs. The remote uses a handheld infra-red control(looks like a tv remote) to remotely control all the electric stuff, hydraulics is all standard lever operated control valves
Offline CaseyK
« Reply #15 on: November 02, 2014, 11:26:16 AM »
lets see if these pics will post.
Offline CaseyK
« Reply #16 on: November 02, 2014, 01:00:27 PM »
Offline CaseyK
« Reply #17 on: November 02, 2014, 01:04:18 PM »
Finally got the post a pic problem solved. The above pis show the military air compressor that i drove 3-1/2 hrs to get, once i removed the top cover i was able to remove the air compressor and then pull the engine. Its a 4cyl Kubota diesel v1702 i think, around 30-35hp. Next is the frame, its 10ft wide, 8ft tall and 4ft deep. Its going to be for a twin blade.
Offline CaseyK
« Reply #18 on: November 02, 2014, 01:11:38 PM »
  this is the frame once i got it all welded up & pulled out into the yard. Now im placing the saw carriage into the frame.
   Here is a pic of the motor frame before i mountthe right angle gear box and place it on the saw carriage.
  this is an older pic when the frame was under the back porch, notice the new mig welder & stick welder, cant build a sawmill without the right tools.
Offline CaseyK
« Reply #19 on: November 02, 2014, 01:15:50 PM »
Here is my youngest of 5, Kaleb. Learning to make minor alignment adjustments to the right angle gearbox assembly.
Automated setworks for a twin blade wish list for either mode of cutting
Started by CaseyK on Sawmills and Milling
Last post December 21, 2014, 06:40:37 PM
by backwoods sawyer
DIY Swing blade vs Twin blade sawmill
Started by nastcat on Sawmills and Milling
Last post March 26, 2014, 08:22:54 AM
by 5quarter
Norwood Twin Blade Edger- (and Sawmill)
Started by Slingshot on Sawmills and Milling
Last post January 26, 2011, 11:22:52 AM
by Mike@Norwood
Discovered a new type of twin blade sawmill.
Started by Satamax on Sawmills and Milling
Last post September 03, 2015, 07:47:06 AM
by Satamax
