Author Topic: Wood splitter motor  (Read 811 times)
Offline husky2100
Wood splitter motor
« on: October 10, 2014, 04:02:55 AM »
My wood splitter just took out the motor on it and it had a vertical shaft Briggs on it can I put a horizontal shaft motor on it without having to mess with the old hydraulics. I'm only asking because if I go horizontal the pump would sit above the filter from were it feeds in to the pump.
Offline blades
Re: Wood splitter motor
« Reply #1 on: October 10, 2014, 05:46:42 AM »
Normally the filter is on the return line, although there might be a screen in the tank on the feed line.  Pump doesn't care about its orientation but you do need to be mindful of the coupling system pump-motor and eng shaft size. Pump input port should be located lower than the feed line from the tank .
Offline sawguy21
« Reply #2 on: October 10, 2014, 09:54:27 AM »
It will work although you will need to fabricate a mount for the motor and pump. also extend the hoses. The tank is below the pump on most splitters so I don't understand blades' last statement.
Online beenthere
« Reply #3 on: October 10, 2014, 10:07:38 AM »
 Here is the pump to filter to supply tank (in the axle tube) arrangement on my splitter. Has worked fine since Jan. 1985. Original pump but just switched out the B&S engine for a new 8hp.
Offline Oliver1655
  • Old Man
« Reply #4 on: October 11, 2014, 03:29:19 AM »
While most horizontal/vertical splitters have the tank lower than the pump, it is preferred to have the tank higher.  If the pump is higher, the oil has the potential to drain out of the pump causing dry starts which can lead to premature pump failures.  The risk increases the longer the splitter sits unused.
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
Electric wood splitter, need new motor
Started by mudnut on Chainsaws
Last post October 24, 2016, 06:22:01 AM
by Kbeitz
New splitter motor
Started by Logging logginglogging on Firewood and Wood Heating
Last post September 14, 2019, 08:27:36 AM
by Corley5
Log splitter motor question???
Started by smsnipes on Firewood and Wood Heating
Last post August 28, 2017, 10:42:08 PM
by jmur1
question about selecting a log splitter motor
Started by snaponman1526 on Firewood and Wood Heating
Last post February 05, 2012, 09:01:59 PM
by John Mc
