Author Topic: Must be the season for mill tune and painting! Here is mine freshly done.  (Read 1338 times)
Offline golddredger
  • Keep on Keep'in on!
I added another 8.5 ft so I can cut a 21'6" long log now. Then painted the entire rig. Came out great and have already been slicing up logs for the last week now that the paint is dry. I am cutting the lumber and timbers for a mill shed for the mill. Will post pictures when the mill shed is finished and it is parked inside nice and cozy. This is the mill I built from recycled metal from various projects and park model trailer frame. I used the 18" upright bandsaw now on it's side with a 1957 or so Wisconsin 9.25hp engine. The muffler is International Harvester from around 1930's. I will be adding power up and down very shortly. I run Cook's blades right now and I built it to use the 158" Wooodmizer size. So I am going to give some Woodmizer double hards a try next. This is not the permanent spot for the mill just set here and leveled to cut the few more beams I need for the mill shed. I will pull the wheels and tires once it is under the shed to lower the setup down and that way there will be no blocks under the leveling jacks. Total cost in this mill is $700 including the first box of 10 blades.
Home built bandsaw mill and trailer for a mini logging operation. Lots of chainsaws and love the woods.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
That is a neat build, golddredger.   8)
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Nice job!
About 38gs less than my WM
Pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Peter Drouin
    • A&P Saw mill LLC
Nice job. 8)
A&P saw Mill LLC.
License NH softwood grader.
Offline slider
  • sawyer,trucker,tree service
It looks fairly stout ,good build.
al glenn
Offline drobertson
OH YEA!  now you're cooking!  nice!  That ought to work just fine!
Offline thecfarm
Looks good. We would not mind seeing picture of the the mill shed being built too.
Offline reswire
Awesome!!
LT 40HDG 35, JD 5205, some Stihl saws, 15 goats, 10 chickens, 3 Chessies and a Weiner dog...
Offline ljohnsaw
That is a really clean looking build!  Nice.   8)
You could just dig a little ditch for the tires to drop it down.  Then you would be ready to go portable any time the need arises!  You could do a reverse "speed bump" - back up until it drops and you know you are in the right place.
John Sawicky
Offline Joe Hillmann
How do you lock the head down when you travel with it?  So far mine has only moved around the yard and I have just use small ratchet straps and I don't think they would cut it for highway travel.  I am trying to figure out a way to bolt the head solidly to the trailer for towing it or getting some chain binders to hold it good and tight to the trailer.
Offline golddredger
Re: Must be the season for mill tune and painting! Here is mine freshly done.
« Reply #10 on: October 28, 2014, 11:34:00 PM »
Thanks for the comments guys.
Joe,
I to use rachet straps when moving around the yard. I have not taken it yet to a new site. But I plan to simply make a flat plate for both sides that runs a grrade 8 bolt through the frame rails and the carriage legs. This will be 1/4" plate. That will lock it down for road travel. Also lower the saw head to the lowest it can go. I need to make those plates and mount tail lights.
Speed bump and dip....... yes that is a good plan. I will see if I can do that. Will just depend on the rocks in the ground. But I will try it!
Yep I will snap some shots of the mill shed as well. I am doing a timber frame build.
Offline 36 coupe
« Reply #11 on: October 29, 2014, 07:27:25 AM »
I dont see any provision to keep the mill head from  coming off the track if some thing goes wrong.My Thomas has a pair off steel clamps for moving the mill.Came with the mill.Do not trust straps, the fabric degrades in sun light.Ask Joe Hillman about having the mill head derail.He has first hand knowledge...
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #12 on: October 29, 2014, 07:42:28 AM »
Very nice job, nice and clean design. Congradulations!
 I know about saw heads coming off the track, my 1st mill after I repaired it, I was moving it in the yard, my strap let go and I was on a small incline and the saw head came into the back of the pick-up truck. The dents are still in the back of the tailgate. :(
« Reply #13 on: October 29, 2014, 11:07:57 AM »
Here is the thread 36 coupe is talking about.
http://www.forestryforum.com/board/index.php/topic,76459.msg1160037.html#msg1160037
We got lucky that no one was hurt and it only did $200 or so worth of damage to the mill.
Offline mmartone
  • I'm new! but I'm old.
« Reply #14 on: October 30, 2014, 08:38:14 AM »
I like the jacks on it.. lookin good
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
question
Gluing felling cracks in freshly mill poplar.
Started by Delawhere Jack on Drying and Processing
Last post March 22, 2014, 08:04:28 PM
by George Walnut
Can U help identify this Banjo Tune? Neat old mill video
Started by Cutting Edge on General Board
Last post February 09, 2012, 06:53:41 PM
by dukndog
The Mill Is Mine This Friday
Started by DaveinNH on Sawmills and Milling
Last post July 12, 2018, 03:51:58 PM
by shortaction
Preserving/painting old circular mill
Started by Vikingwood on Sawmills and Milling
Last post June 04, 2018, 06:54:57 AM
by bandmiller2
