Please welcome new sponsor:
with a semi functional debarker
There are lots of reasons this may be slipping and for sure the guys at WM can help you through this.But I think I can speak for them when I say: do not tighten the belt beyond their specs.If you do this you will almost certainly get more power to the blade and faster cut speeds in the very short run. In the medium or long run you will very likely damage, if not destroy, your engine due to excessive side-load.(Keep in mind this is true of any engine and any mill -- I'm not in anyway saying this is a "Wood-mizer" thing. It's a physics thing.)
Mike in WM Tech Support emailed me and mentioned that putting a thin coat of ordinary bar soap on the belts helps them to 'buff - in' to the pulleys. I'm going to try it on my next V-belt change.
Started by Jhoff on Sawmills and Milling
Started by SAnVA on Sawmills and Milling
Started by JRWoodchuck on Sawmills and Milling
Started by DR_Buck on For Sale
