Arborwear
Author Topic: C4 ignition replacement  (Read 600 times)
Offline Rybo
« on: November 06, 2014, 07:55:29 PM »
Having trouble getting power to starter on late 60's c4 with ford industrial diesel.  Very likely battery issue. Need to have batteries load tested and some other trouble shooting.
Got to looking at inition set up I see a resister on firewall.  Was curious if it is necessary?  Original  Ignition switch has been replaced. Replacement switch is connected into original switch via resister.  Power cables are also still connected to original.  Not sure if original acted as a disconnect also? Which I would like to add.
Long story short would like to redo setup before weather turns colder. What's the best way to get power to starter?
Offline HiTech
Re: C4 ignition replacement
« Reply #1 on: November 06, 2014, 08:35:30 PM »
Welding cable makes the best leads. Very fine copper wire that carries the juice really well. Positive to the starter and negative to the engine or bell housing. I would use some kind of master switch also. I have my positive lead going to the master, some use the negative. 2/0 is what i use.
Online BargeMonkey
« Reply #2 on: November 07, 2014, 10:06:37 AM »
A master switch is a must. Spend the money on a good one, can save your machine. We tend to put them inside the engine housing or doors, behind the locks so it takes alot more work if someone decides to mess with it.
stihl 056 ignition
Started by iffy on Chainsaws
Last post May 03, 2015, 08:47:10 PM
by John Woodworth
New ignition on Husqvarna 350
Started by iafarmer on Chainsaws
Last post July 23, 2008, 12:52:09 PM
by iafarmer
Stihl 084 ignition
Started by jcsaws on Chainsaws
Last post June 07, 2015, 09:02:12 AM
by stihlsaw066
new ignition switch.
Started by ely on Sawmills and Milling
Last post December 23, 2014, 08:49:47 AM
by ely
