Author Topic: Accuset questions on Woodmizer  (Read 1376 times)
Offline woodworker9
    • Elite Concrete Raising Co.
« on: November 29, 2014, 09:50:58 AM »
Sadly enough, the previous owner of my mill has no honor.  I purchased the mill over a month ago, and before making the 6 hour drive, I was assured that the mill ran great...."Like New", and that he had all the books for the mill.  When I arrived, the mill wouldn't run (I fixed that problem already), and he had none of the books ready.  I really, really, REALLY wanted this mill, so I trusted him to send everything, as he couldn't find where he put them.  I FINALLY just received the manuals in the mail from the PO, 6 weeks later, and there's nothing in them at all about operating the Accuset controls.
I'm clueless.  I've learned a long time ago not to just mess around pushing buttons on computer-controlled devices.  If it isn't mechanical, I cannot fix it.  I have absolutely no idea how to work these controls.
I found a video on the WM website of our very own Bibbyman speaking about Accuset 2 controls, which is the newer version.  Will this video tell me what I need to know about operating the Accuset controls?  Or is it different enough to cause a problem?
I looked all over the internet and cannot find a operations video regarding the older version of Accuset.  My mill is a 2003.
Thanks for any help you provide in either directing me to a learning video, or if it isn't too much trouble, telling me how to use Accuset here.
Thanks a million.  Love this forum.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline flatrock58
Re: Accuset questions on Woodmizer
« Reply #1 on: November 29, 2014, 10:02:10 AM »
Have you tried calling the closest Woodmizer store.  The woodmizer store near me in Georgia sent me the PDF of manuals I needed.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #2 on: November 29, 2014, 12:26:12 PM »
I was in the same boat when I bought my mill traveled from Oregon to Pensilvaina to pick it up, mill in sad shape no manual.
Poking buttons answered most of my questions but finding the save button was elusive ::) no books to look thru :P turned out to be simply pushing the uper left button :)
When I upgraded to the Accuset 2 it was a seamless transition as the control panel is about the same.
Watch the video, call about a pdf and make sawdust.
Offline woodworker9
« Reply #3 on: November 30, 2014, 01:47:26 AM »
Thanks.
Offline drobertson
« Reply #4 on: November 30, 2014, 11:33:52 AM »
Pushing buttons while you are in pattern, auto up/or down won't hurt anything.  the up down keys as backwoods mentioned are the toggle buttons for several functions,  just stay out of  advanced settings that control pid settings. these are factory set. As to the saw head drop and raise functions it just takes a little practice to remember the sequences.  Once you get it, you will love it.  I forgot to mention,  don't forget there are sixteen pattern sets for each function.  Each one toggles their respective bed set.  ex. #1 is also bed set #5,
#9 and #13. the other three, 2-4 work the same way, for whatever pattern mode you are in.  What this means is you can set a large variety of drops, patterns, and up moves to maximize the board recovery.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #5 on: November 30, 2014, 05:31:48 PM »
Just don't drop the head when the band is over a log, board, or cant on the mill bed.  It is easy to do this if you do an "auto down" while still over the cant.
The whole weight of the head will set down on the band and if the outer guide roller doesn't break off of the mounting arm,the force will probably bend one or two of the 4  cam bolts that goes through the arm guide rollers.  I've done both-broken off the guide roller, and bent the cam bolts (all now fixed).  The learnin' continues!
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline customsawyer
    • The Custom Sawyer
« Reply #6 on: November 30, 2014, 05:49:20 PM »
Get a hold of WM and register the mill in your name and ask for any manuals you need. What mill do you have? I have 4 complete manuals for the LT70 if you need one I would be happy to send one to you if you pay shipping.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline drobertson
« Reply #7 on: November 30, 2014, 09:16:48 PM »
The manuals just don't give that much added help in the complete functions of the system in my view.. the manual will direct you through the basics, which covers adding the kerf setting, this is very important when using the programmed sets.
Offline woodworker9
« Reply #8 on: December 03, 2014, 10:31:18 AM »
Thanks again for all the replies and offers of assistance.  I appreciate it.
Marty from Woodmizer contacted me via email and has sent me the pdf file for the controls.  Terrific guy.
I have already registered the mill with WM, and have the manual for the mill.  Unfortunately, the manual for the Accuset controls was not present, but I have it now.
I still have let to cut my first log.  I've been busy with an addition to our home, and need to get all the siding on before too much more of the white stuff flies.  It's been unseasonably cold here in Chicagoland, as with everywhere else.
Cheers!
Woodmizer Accuset
Started by jdgese on Sawmills and Milling
Last post May 10, 2007, 09:38:18 AM
by jdgese
Questions about running Accuset in Metric.
Started by Dave Shepard on Sawmills and Milling
Last post June 04, 2008, 10:07:19 PM
by Tom
Woodmizer Accuset one parts. SOLD
Started by ShowMeSawyer on For Sale
Last post July 14, 2018, 10:41:14 PM
by stihltoomany
Woodmizer accuset glass cloudy
Started by just_sawing on Sawmills and Milling
Last post July 11, 2007, 06:35:33 AM
by treetech
