Author Topic: Wood for old pick-up bed  (Read 5430 times)
Offline Furby
  • Blurb....
« on: August 10, 2004, 05:19:19 PM »
A buddy of mine just started restoring, I think he said a '53 Ford pick-up truck.
He asked me about some wood for the bed. We were talking Q sawn white oak, but I got to thinking that maybe he can do better. I've heard of honey locust being used before, and looked real nice.
He wants it to be kind of a "show truck", so something fancy looking, that might still be historically true to the truck.
Any suggestions?
Also any suggestions for a finish would be helpful.
Offline etat
  • Member*
Re: Wood for old pick-up bed
« Reply #1 on: August 10, 2004, 05:37:14 PM »
Quite a few years ago I completely tore down to nothing a 63 gmc pickup and rebuilt.  Started with a 72 frame and stripped everything off of it that would come loose.  Sandblasted it and started back over.  Every bolt, line, and wire, and other components  that could be replaced, was.  Added power steering, and power brakes.  Found and cut down a long bed stepside into a short wheel base stepside.  Looked for a year for some gmc parking light lenses for the front hood, (they're different from a chevy). Finally found some NOS still in the boxes where it'd sat for 30 years.  It was once when I was working for someone else, his truck, and I worked on it for two years. On rainy days he'd usually send every one else home but me and I'd work on the truck.  Sometimes he'd keep me on it weeks at a time.  Every piece of trim was replaced, and recromed.  Carpet, air, tilt steering column.  Chevy 350 motor all dressed up.  Had everything dang near back together and made a mistake of mentioning stainless steel bolts. Some of the black coated ones he'd bought was starting to rust.  He had me take the whole dang thing back apart and put it together with them stainless steel bolts. This guy had more money than he had brains!!!!
Oh, sorry, back to the point.   For the bed we used quarter sawn white oak and found new trim pieces that went between the boards in stainless steel.  We finished the oak with a marine varnish.  It hardly ever gets out of his shop where he keeps it covered up but here a while back I saw it parked at WallyWorld and kinda snuck up to it and looked it over.  It was still looking pretty good.
Offline hawby
  • Just "Bearly" gettin' by ;-)
« Reply #2 on: August 10, 2004, 06:16:44 PM »
Furby,
What color is he gonna paint it? That might influence what wood, what finsh he should use.
Locust will last forever...course if it is a show truck, it'll be inside all the time anyways.
I wish I had an old truck. Wish I had a new truck. ;D
Some day the ole '66 Lemans convertible will be done and we can cruise  8)
hawby
Hawby
Missin' loggin', but luvin' the steady check...
Offline Furby
  • Blurb....
« Reply #3 on: August 10, 2004, 06:21:29 PM »
Don't know if he's thought that far ahead yet, but I'll ask him next time I see him.
I kinda think he may drive this thing a little, just a hunch.
I'll get some more info when I can.
To be honest I'd like to see a pic of it. Since it's a couple of hours south of me, that's the only way I'll see it for a while.  :-/
Yeah, I wish I had an old truck or a new truck too! :-/
Online sprucebunny
  • Gender: Female
« Reply #4 on: August 10, 2004, 06:33:06 PM »
Ash would be good. They make UV resistant epoxy that would be a good finish but epoxies are toxic to work with .Marine varnish lasts about two years out doors.
Offline rebocardo
  • Atlanta GA
« Reply #5 on: August 10, 2004, 09:51:56 PM »
White oak is what the older Fords are finished with for wood beds and you use stainless strips in between the boards. I think it is wise to undercoat the bottom of the boards and ends with a marine epoxy paint and provide drain holes in the front of the bed at least 1/2 to 5/8 iiches wide in each corner.
Offline CHARLIE
  • Don't wait 'til both feet are in hot water before you decide to put your best foot forward.
    • Coulee Region Woodturners
« Reply #6 on: August 10, 2004, 10:06:40 PM »
I'd vote for quarter sawn white oak.  Especially since they use to use white oak.  But Don''t use red oak. Red oak is no good outside.
Charlie
Kirk_Allen
  • Guest
« Reply #7 on: August 11, 2004, 06:09:15 AM »
White Oak was the most popular in the old trucks from what I have read in the past.
I know you said its a Ford but maybe Captain can do some checking with GM history on their trucks.
In regards to Honey Locust, dont get that one mixed up with Black Locust.  The Black locust would out last the truck.  The honey locust is no where near as rot resistant as the Black Locust or the White Oak.
Kirk
Offline Patty
  • Gender: Female
« Reply #8 on: August 11, 2004, 10:35:47 AM »
Furby,
Kirk is correct. Honey locust is not nearly as rot resistant as Black locust. We can send you a sample of black locust if you want to see what it looks like. We are clearing about 13 acres of black locust off the back of our farm, where a tornado went through & trashed the area. It is extremely hard (tough on the chainsaw). Both the quartersawn white oak or black locust would work well.
Women are Angels.
And when someone breaks our wings....
We simply continue to fly ........
on a broomstick.....
We are flexible like that.
Offline crtreedude
  • A proper coffee break...
    • Finca Leola Reforestation
« Reply #9 on: August 11, 2004, 11:10:07 AM »
Here in Costa Rica, the beds are made out of Cortesa - which is so hard that they use it for bridges. It is almost black in color at times and is so dense that the wood will not absorb water. It is amazing stuff. Not exactly original equipment though.
It is interesting, when you saw it with a chainsaw, it makes smoke because it is so hard!
Some of the logs we use are about 80 feet log, just drop a few over a stream or small river, fill between with gravel and dirt and you have a bridge that will support a 10 ton truck. I will say the first time you drive over one, it does make you a bit nervous...
Anyone want pictures?
So, how did I end up here anyway?
Offline Paschale
  • Got bit by some snow snakes...
« Reply #10 on: August 11, 2004, 12:05:10 PM »
I think everyone's a fan of pictures!   :)
Y'all can pronounce it "puh-SKOLLY"
Offline Buzz-sawyer
  • To see it is to saw it....
« Reply #11 on: August 11, 2004, 12:07:17 PM »
Your kidding right? Send em!
    HEAR THAT BLADE SING!
Offline crtreedude
« Reply #12 on: August 11, 2004, 12:30:05 PM »
I went to find them and saw that I already had them on my website:
http://www.fincaleola.com/country_bridges.htm
No pictures of a pickup truck with a Cortese bed.
Feel free to snag the pictures and put them in the forum if you want.
Offline rebocardo
  • Atlanta GA
« Reply #13 on: August 11, 2004, 01:49:24 PM »
One wood I have used before that might be great for a pickup bed, if it is meant to be a show truck, is Purple Heart.
I was told it was a tropical wood. It is very tough and bouncy, I guess one of the main uses is bed slats for mattress/box supports. You have to predrill any screw holes because a stainless steel screw will snap in 1/2 trying to drive it.
It is deep purple, looks excellent finished, very resilent, has a gum/wax/resin that would probably make it pretty rot and water proof in a truck bed, especially with a good finish. Plus, it is expensive so that might appeal to some people  :D
I used it to make wall and floor trim.
Offline crtreedude
« Reply #14 on: August 11, 2004, 01:56:45 PM »
Purple heart would be very pretty, but I don't think it is weather resistant - could be. It does grow in Costa Rica. Also, it would be REALLY expensive - since it is very scarce now.
Fred
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #15 on: August 11, 2004, 02:21:45 PM »
  How's things going down there, Fred ???
Offline crtreedude
« Reply #16 on: August 11, 2004, 02:31:30 PM »
Having too much fun,  8) But that isn't a problem, is it?
I went out to get my mop of a head of hair cut yesterday and it cost me 600 colones - in other words, less than 1.50 - you have to love it. They did a good job too, of course they did an excellent job considering what they had to work with... ;D
So, when you coming to visit? We had a pig roast Saturday, honestly, I wasn't trying to compete, we just finished planting and all.
Fred
« Reply #17 on: August 11, 2004, 02:33:50 PM »
  If we could sell some wood, I will try in Feb.
Offline crtreedude
« Reply #18 on: August 11, 2004, 02:38:18 PM »
Beautiful time to be here, but you probably know that - you will have to bring a pan to pan for gold. I have to see how you do that.
If you get the airfare, I am sure we can put you up somewhere.
Fred
« Reply #19 on: August 11, 2004, 02:46:43 PM »
That would be great. Thanks, Fred
About the truck, got any Hedge Apples up there ??? That would make an eye catcher truck bed ??? ;D
Has Anyone Made a Pick Up Rack From Wood (1st Choice) or Metal (2nd Choice)
Started by H60 Hawk Pilot on General Board
Last post October 19, 2010, 08:43:42 PM
by jbeat
smiley
Pick-up !
Started by isawlogs on General Board
Last post September 22, 2012, 05:33:23 AM
by SwampDonkey
Why do they pick me
Started by Skytramp on General Board
Last post December 16, 2005, 07:18:52 PM
by tmullen
Help me pick a saw
Started by Tinbeers on Chainsaws
Last post April 19, 2018, 08:21:30 AM
by Fishnuts2
