freeze
Started by coxy, December 16, 2014, 05:25:10 PM
coxy
how many times can you freeze and unthaw  fresh meat    the reason I ask is I have a lot of roast that I want to grind up in burger and make stew meat but I have to unthaw to grind and cut then freeze again  its beef that I raised not the store   any help would be great    coxy
red oaks lumber
i won't refreeze meat. :)
petefrom bearswamp
I have thawed and refrozen meat but only high speed beef (read venison) many times but just once per package as this degrades the quality,  with no adverse health/spoilage effect.
I just loses some moisture but not much if unwrapped.
It is a myth that this spoils it.
Beef that you buy in the larger markets has been shipped frozen for years then  thawed and cut and packaged
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Mooseherder
Beef isn't shipped frozen.  That would take all the shelf life out of it when it would thaw.  If you thaw your Meat under refrigeration, process it right away and you shouldn't have any problem re-freezing.  Especially for what you are doing taking whole muscle meat for grinding.  It'll be okay.   I wouldn't make a habit of it though.  I would be more worried about the proper packaging to avoid freezer burn.
LeeB
Keep it 40° or below and you should have no problems.
Chuck White
Agreed, just keep it cold!
Pork or poultry would be a different issue!
