Author Topic: Whatcha Sawin' ???  (Read 1183681 times)
0 Members and 6 Guests are viewing this topic.
Offline thechknhwk
    • Story of the Trees
Re: Whatcha Sawin' ???
« Reply #9640 on: May 16, 2018, 08:47:15 PM »
Dustintheblood, must see pics!  sounds awesome
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #9641 on: May 16, 2018, 08:48:57 PM »
Dang, when you get back into something. You donít fool around!!
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #9642 on: May 16, 2018, 10:16:23 PM »
This Saturday's Job..... Big'ns
10/4 Slabs
Will be the biggest I've attempted.  Nervous, but can't wait!!
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9643 on: May 16, 2018, 10:41:08 PM »
That last one will be interesting for you anyway.  I'll just watch and smile.  :)
Offline dustintheblood
  • Home in the woods
« Reply #9644 on: May 16, 2018, 11:06:01 PM »
The home mill's still and always will be small potatoes.  The big northern SPF mills that I do work with --- now they're the big ones.  When you're watching them spit studs out so fast out of the planer line that they're a blur, it's really quite something.
Case 1494, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln, plus other toys - cause well - gotta have something to play around on
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #9645 on: May 17, 2018, 07:12:24 AM »
E,
I bet sparks will fly ;D
Offline KirkD
« Reply #9646 on: May 17, 2018, 12:14:54 PM »
Sawed a backstop yesterday >:( So I guess I am in that club now :D
Wood-mizer LT40HD-G24 Year 1989
  • Home in the woods
« Reply #9647 on: May 17, 2018, 12:33:35 PM »
Some days it feels like I was aiming for them  :D :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9648 on: May 17, 2018, 01:03:51 PM »
Maybe you should not have paid as much attention to WDH's comment above but at least you did make the sparks fly.  ::)  :D
Offline paul case
  • Original wearer of the PCM.
« Reply #9649 on: May 17, 2018, 01:31:45 PM »
4/4x3.5''-8 red oak post oak and a little blackjack oak mixed in. We get a lot of logs that will not tie and 4/4x3.5''-8' is what we make from them. The buyer I have for most of that size will cut them down to 4' and notch them for pallet stringers. I had not sold any to him for 5 months and back in April he called needing them as his largest supplier cut him out for some reason.
We have cut him 2 loads of 1600 each back in April and now he needs more. Got 200 ties( a semi load) ready to go out and Scott should finish our load of 3x4-10 today so I can deliver it Monday.
We are just rocking along.
PC
pc
Offline Brad_bb
    • My timberframe blog
« Reply #9650 on: May 17, 2018, 02:59:26 PM »
Well I'm on a Chainsaw mill kick.  I'm going to do everything I have that requires the CSM.  Here is a large Walnut trunk 10 ft long.  It has a hollow in one side with a bunch of carpenter ants in residence.
I got three good slabs.
Slab 1 top.
Slab 1 bottom.
Slab 2.
The 3 good slabs plus what was left.
Here's what was left with the big hollow in it.  You can see the start of the ant next on the left side.
So I split it down the middle with my chainsaw(didn't take much) and will mill the solid part on the left on the band mill.  I might throw the right side on, but I know I probably won't get much of anything.
I noticed last week after the first ash log that I have some broken teeth it appears.  I don't recall hitting any metal, I didn't see any.  I've got about 5 teeth like this on my 66" bar.  Two are next to eachother, and the others are spread out on the chain.  I was wondering if I should do anything or just keep running.  Should I replace the part of the chain with broken teeth?  I'm thinking not because then the new teeth would be longer/taller than the rest of the chain.  It's a 10 degree grind skip tooth rip chain from Granberg.
Offline Hilltop366
« Reply #9651 on: May 17, 2018, 03:28:26 PM »
If replacing the teeth you should sharpen them back to match the rest.
Offline Ianab
« Reply #9652 on: May 17, 2018, 03:49:59 PM »
I would just grind them off and call it a "semi-skip" chain.
If you have ever looked at the chain on a Lucas or Peterson chain slabber, they run a "super skip", which is a pair of cutters every 8 or so links.  In a wide cut, you won't notice the missing ones. It wont  run rough or jerky because you still have plenty of cutters in the wood.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #9653 on: May 17, 2018, 04:32:58 PM »
Nothin!
Blew the 225 amp fuse. Called Wood-Mixer Portland yesterday afternoon and 3 new ones will be delivered today. So should be sawing tomorrow.
When I looked in the fuse box I saw that the previous owner of the mill had used the extra fuse and not replaced it. Bad me for not looking sooner.
1992 LT40HD
Offline Darrel
« Reply #9654 on: May 17, 2018, 06:41:36 PM »
PLook what just showed up!
1992 LT40HD
Offline olcowhand
  • I'm new- ish!
« Reply #9655 on: May 17, 2018, 07:02:37 PM »
Brad,
I'm following your CSM activities with great interest. I just got my Granberg and a longer B/C combo for my MS 461, most of next year's firewood is cut- and I'm going to saw some when I get it rigged with an auxiliary oiler and winch (plenty of tips on how to do on this site.
Between yours and Busybeaver's recent posts, I'm learning enough to be dangerous (hopefully only to a log).
Are all the broken cutters on your chain on one side? If so, does it want to pull to one side like some improperly sharpened 30* chains do (don't ask how I know about that, guys talk!)?
Thanks.
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #9656 on: May 17, 2018, 07:06:53 PM »
What blew the fuse Darrel?  Bad/loose connection somewhere?  You would never regret replacing and upgrading to the new fuse block and fuses.
Offline Brad_bb
« Reply #9657 on: May 17, 2018, 10:51:18 PM »
olcowhand,
The broken cutters are mixed on both sides.  With the experience I have so far, i would not use the winch/cable.  At least you would not be cranking on it hard.  I find, even with the 090 you can bog it down easily in a wide cut.  You have to listen and feel the saw to keep  your RPMs up.  You want to be cutting at full RPMs or close to it.  It's slow cutting.  Also if you're leaning over to push the saw, it will wear on your back.  If I can kneel I do.  It's easier to do when you've cut a few slabs and are getting closer to the ground.
As I've been telling some others, CSM'ing is a young mans game and I'm not as young as I used to be (46).  Last Saturday I was on a marathon to get the second big Ash cut, the next day my back was really sore, and my arms were aching all day.  I didn't feel good.  It was 50 percent better on Monday, and by Tuesday I was ok.  I'm trying to get all the pieces I've saved up for CSM'ing done so I can be done with it for awhile.  The walnut definitely sawed a bit easier than the Ash.
Offline Darrel
« Reply #9658 on: May 17, 2018, 11:18:08 PM »
Yes MM, it took me a while to find it but the big wire that goes to the contractor that contacts the contact strip had a bare spot in it so I replaced it. Everything in the hydraulic box looks good.
Someday, I will upgrade to the new fuse block.
1992 LT40HD
Offline Crossroads
« Reply #9659 on: May 17, 2018, 11:30:23 PM »
Nice slabs Brad, I really like the color
Whatcha NOT Sawin' ???
Started by terrifictimbersllc on Sawmills and Milling
Last post May 22, 2018, 11:51:19 AM
by Crossroads
question
Whatcha Sawin' 2019 ???
Started by Magicman on Sawmills and Milling
Last post Today at 08:16:18 AM
by Magicman
Whatcha All think About This ??
Started by Fla._Deadheader on General Board
Last post June 28, 2005, 06:44:55 AM
by crtreedude
Dis ain't sawin' !!
Started by Magicman on General Board
Last post November 12, 2018, 04:36:09 PM
by curved-wood
