BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Whatcha Sawin' ???  (Read 919606 times)
ellmoe, sealark37, woodyone.john and 7 Guests are viewing this topic.
Offline Sixacresand
  • John and Nancy
Re: Whatcha Sawin' ???
« Reply #7620 on: November 14, 2017, 08:57:25 AM »
I edge on the mill, also.  I get all the edging done before starting the next log.  If you have an experienced helper, edging on the mill is not bad.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7621 on: November 14, 2017, 12:03:05 PM »
I finished and left a slab/edging/sawdust pile and a whack of lumber.  Sawed it and left.
WDH, I did very little edging which is one of the joys/advantages of portable custom sawing.  If there was one good edge where the customer could run it through his table saw, he said that it was "good enough".  He can squeak out every possible fraction of an inch from every board.
Offline Bandmill Bandit
« Reply #7622 on: November 14, 2017, 01:31:03 PM »
i am starting a job next monday where I will be sawing ALL 10' logs minimum 10" small end to 4/4 thick. Open the log flip 180* and cut to bed. No edging. ALL for wind fence slabbing.
It for a feed lot that has room for about 15000 head. Total of 5 miles of new wind fence for this cutting session.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
2001 Dodge 1500 4x4.
2007 Woodmizer LT40HDG28 almost Super
2 Logrite 36 inch cant hooks and a bunch of stuff I built my self
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7623 on: November 14, 2017, 06:35:07 PM »
Cutting some 14"x8"x 20'an 18' timbers for a customer on Jewett Street, Georgetown, Mass  ;D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7624 on: November 14, 2017, 08:04:28 PM »
MM,
You just saws em and leaves em.  Me, I have to saws em, stickers em, air drys em, kiln drys em, planes em, and stacks em.  Em.  Em.   :).
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #7625 on: November 14, 2017, 08:29:54 PM »
Peter,
   My back aches just looking at those beams.
Offline paul case
  • Original wearer of the PCM.
« Reply #7626 on: November 14, 2017, 08:50:06 PM »
MM,
I just buys them, hauls them, saws them. cuts them to length, deals with all the trash, loads them, straps them down and delivers them and sheds a tear(misses them) and goes home only to do it all over again. smiley_crying smiley_blush smiley_confused smiley_cry smiley_annoyed01 smiley_dozy_bored smiley_mellow smiley_sweat_drop smiley_sweat_drop smiley_sweat_drop
PC
pc
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7627 on: November 14, 2017, 08:56:11 PM »
And my customer will be loading em, hauling em, and stickering em for the rest of the week, and I will be off.
Oh, but I did have to go to the bank em and deposit em the check em.   :D
    • A&P Saw mill LLC
« Reply #7628 on: November 14, 2017, 09:12:43 PM »
Peter,
Easy with the Cat. ;D
Em, I did that too MM, But not no more. Now my travel in less than a min. :D :D ;)
Sawing since 1987
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #7629 on: November 14, 2017, 09:51:45 PM »
I saws em and leaves half of em and halls the other half of em home. I'll do that 'till I don't need no mo of em then I'll do like MM and saws em and leave em all.
1992 LT40HD
Offline longtime lurker
« Reply #7630 on: November 15, 2017, 01:45:35 AM »
MM,
PC
I fells um, skids um, hauls um, saws um, docks um, treats um, stickers um, dries um, dress/moulds um, sells um, sweep floors, answer phones, and mechanic to keep this old gear running.
My fishing gear has gone rusty. I LOSE!
« Reply #7631 on: November 15, 2017, 02:13:58 AM »
Serious question Peter (and anyone else in the same situation)  how does that work for ya?
Reason I ask is that with Mary away on a 12 month contract and the managers residence at the mill vacant I been considering moving in there. I currently commute 1/2 hour to work.
Thing being I already spend 12 to 15 hours a day there 6 days a week and I can see the last bit of normal in my work life disappearing real quick if its 100 yards to the breakdown saw. Im a workaholic with sawdustitis.
So how do you manage to have a life away from a sawmill when you live next door?
Sorry for the hijack MM but the question is bugging me and the opportunity came up
Offline Ianab
« Reply #7632 on: November 15, 2017, 02:28:44 AM »
This afternoons mission, find the max log size capacity of the little JP.  Yes it's 36" inches on mine.
Log was a bit ugly inside with some big knots and bark inclusions, but still got some very nice boards from it.
Offline LeeB
« Reply #7633 on: November 15, 2017, 03:04:42 AM »
I don't see any boards.
Offline Ianab
« Reply #7634 on: November 15, 2017, 03:55:48 AM »
Quote
Some I prepared earlier.   :D
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #7635 on: November 15, 2017, 05:49:44 AM »
LL that is the thing to do around here.  I know of 4 different sawmills and one millwork shop local where the guy in charge of the show lives on site.  I am trying to make that happen for me too because Im sick and tired of a 40min commute
Boy, back in my day..
Offline PA_Walnut
« Reply #7636 on: November 15, 2017, 05:58:13 AM »
Picked up a BIG maple butt on SAT that was sitting in a hedgerow for almost a year.
Fun rewards peeling 10/4 slabs off it, after wrestling it onto the mill and trimming it up enough to get my LT40 wide past. Claw wouldn't roll it, pushed it sideways on the mill, fell off onto the arms twice, etc.    :o
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
    • A&P Saw mill LLC
« Reply #7637 on: November 15, 2017, 06:17:37 AM »
Long time, For me, I like it. I'm the only sawmill in town selling lumber. I have a sign that gives the time I open and close. [8 am to 5 pm] Close on Sundays, Only had one customer come after hours for lumber, Cows got out.  :D :D :D :D
If Ann and I want to go some place I close the gate, turn off the phones and go. ;D
The mill and house are 150 + yards apart.
A tank of gas in the truck will last 30+ days.
The only fits I have is looking for tools, I have a wood shop and metal shop, now sawmill.
Tools all over and the older I get, the less I remember where they are.  :D :D
Sawing since 1987
Offline thecfarm
« Reply #7638 on: November 15, 2017, 06:20:44 AM »
I,well,we,  ;D  really need to take a day trip to your place Peter.
    • A&P Saw mill LLC
« Reply #7639 on: November 15, 2017, 06:35:33 AM »
All are welcome, With a business like this you have to like [most] people. :D
Kindness and patients that I have learned from MagicMan over the years here have helped.
Sawing since 1987
Whatcha NOT Sawin' ???
Started by terrifictimbersllc on Sawmills and Milling
Last post May 22, 2018, 11:51:19 AM
by Crossroads
Whatcha All think About This ??
Started by Fla._Deadheader on General Board
Last post June 28, 2005, 06:44:55 AM
by crtreedude
Still sawin'
Started by NCDiesel on Sawmills and Milling
Last post June 21, 2016, 01:21:01 PM
by taylorsmissbeehaven
Sawin' again
Started by Bigdogpc on Sawmills and Milling
Last post May 03, 2004, 10:47:32 AM
by Bothy_Loon
