Author Topic: Anyone using a Norwood Dremel Type blade sharpener  (Read 5800 times)
Offline papow22
Re: Anyone using a Norwood Dremel Type blade sharpener
« Reply #20 on: February 08, 2015, 02:15:51 AM »
I have one that came with my used norwood mark 2 mill. they make a good mill but the sharpener is a joke don't waste your time. I got tired of cranking on it for an hour per blade
 I seen on Norwood's forum one guy there put a 18 v  dewalt drill to power instead of hand cranking.it seem to work just fine.
Lives to do sawdust,run a trapline,hunt big game,live life to it's most.Got 4 mills a circle mill,(2 band sawmills) Norwood's 2000, Trim Saw,Beam Machine (chainsaw mill).
Offline robomower
« Reply #21 on: November 11, 2017, 11:10:54 PM »
Hi Jjoness4;
I am responding to a 3 year old post and expect you have probably solved or deserted your quest to solve your issue. However, in case you or anyone else with this dremel sharpener is still struggling with it, the answer is simple. The solution is confounding to me, but for whatever reason, it solves the problem. After that, who cares?
At some point in it's life, the tooth position adjustment screw was unwound too far and came away from the tooth position tie rod. The spring (item 37) fell out and the screw came off and the tie rod fell down. Who remembers if the spring was after the tie rod or after the tooth position block before it all came apart? The answer is it MUST be next to the tie rod, not the tooth position block. (See attached diagram with circled spring) As soon as I switched the spring position all the problems went away. Tom at the Canadian office for Norwood Industries put me on to the solution after I had suffered 3 months with the issue and many many thanks to him.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #22 on: November 12, 2017, 07:12:20 AM »
File wont open........
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline LAZERDAN
« Reply #23 on: November 12, 2017, 08:10:24 AM »
IT opens in microsoft word for me.
Offline robomower
« Reply #24 on: November 12, 2017, 03:59:53 PM »
Thanks very much laserdan.
Got it in as an attachment. Upload didn't like jpg but ok with doc file.
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #25 on: November 12, 2017, 04:07:55 PM »
Here's the PDF:
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Kbeitz
    • My Hobbies
« Reply #26 on: November 12, 2017, 04:16:24 PM »
Offline robomower
« Reply #27 on: November 12, 2017, 08:25:47 PM »
Thanks for the pdf mountain man
Offline tribalfarmer
  • Member*
« Reply #28 on: April 15, 2018, 10:31:48 PM »
I have always liked this forum and have gotten good insight from it many times, so decided to join.
I have used this sharpener. It does need a lot of help. it sounds like coastlogger
had a good idea on how to make it better
I would like to see his pictures of the one he modified.
I have a Harbor freight right up the street
Offline fluidp
  • I'm new! To this site
« Reply #29 on: April 16, 2018, 11:01:09 PM »
 Hi all, I have a new (One month ago) Norwood lm29, 16 hp , and also bought the dremel sharpener and tooth setter. I would not want to go into business sharpening blades with it, but only after sharpening a few blades I got the hang of it. One key thing is to keep it Clean. Blow down after every blade.
Im not overly happy with the Norwood instructions, as the detail is limited. also the standard cam in it should be profiled to match the Norwood Sabretooth blades better, as the first sharpening took three passes with the sharpener to profile the saw tooth so the entire "Back" of the tooth got touched.  Oh well, what ever....
First blade I sharpened was the one I hit my back rest on the mill with, so it was kinda messed up  lol., But after some care full setting and three passes with the sharpener, it turned out just fine.
Ive done 4 blades and lots of stone left on the dremel, so im happy about that. Just don't try to grind too much at a time, that will wear out stones and put heat in the blade.
Happy Milling lol lol
Norwood Standard band saw blade sharpener
Started by logfarmer on For Sale
Last post January 01, 2018, 06:29:40 PM
by Jeff
LT40 changing blade type, WM sharpener changes required?
Started by amberwood on Sawmills and Milling
Last post January 08, 2007, 01:02:57 PM
by sparks
Dremel Tool Sharpener???
Started by Woodhog on Chainsaws
Last post May 29, 2005, 07:26:25 AM
by Al_Smith
question
Dremel + Al Oxide Grinding Stone + Steady Hands = Sharp Blade?
Started by Deese on Sawmills and Milling
Last post November 23, 2013, 06:58:03 PM
by bushhog920
