Author Topic: Axe Handle Repair?  (Read 3051 times)
Offline lowpolyjoe
  • Hey
    • JeRM Software Page... Hobby projects
Axe Handle Repair?
« on: January 31, 2015, 09:43:55 PM »
Hey Guys
Is this repairable?   I don't really need it, but rather than throw it out I was wondering if it's fixable.  Is it reasonable to chop off the busted top then shave down a new tenon (if that's what you call it) to remount the head?
Offline Don_Papenburg
  • I need money
Re: Axe Handle Repair?
« Reply #1 on: January 31, 2015, 09:48:49 PM »
It'l look a little funny but it could be done.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #2 on: January 31, 2015, 09:51:56 PM »
 I don't beleive that there is enough head on that handle to reseat the axe properly. ... Now that being said,  you could reseat the axe and hang it on a wall, but I would not do that. I would be afraid of someone taking it down and using it.  Make a new handle for it, carve one and call it yours.  ;)
   Marcel
Offline Al_Smith
« Reply #3 on: January 31, 2015, 10:00:12 PM »
They don't cost that much .Buy a good one like a Union ,Ames or something ,Hickory .Mind the grain .Should be like a baseball bat with the grain parrellel to the head .
Use the old  one for an ugly stick . ;D
Offline beenthere
« Reply #4 on: January 31, 2015, 10:59:15 PM »
Time for new..
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #5 on: February 01, 2015, 07:28:21 AM »
Use the old  one for an ugly stick. ;D
My brother, the dog warden in this area used to carry an old axe handle in the truck when he went on a dog call, now he uses some kind of high pitched electronic device that will stop most dogs lookin' for a lunch.
Warning:  In some areas an axe handle (or similar items) are viewed by law enforcement as a weapon, so you could run into legal problems!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline lowpolyjoe
  • Hey
« Reply #6 on: February 06, 2015, 08:34:59 AM »
Thanks for the advice guys.
Might be fun to try to make a handle from scratch.  I might have an oak log that's long enough laying around - been sitting for years.  I also have some ash that's been sitting about a year.  Are either of those usable for this purpose?
If that doesn't work out I see that a new handle is pretty cheap, as you guys have mentioned.
Offline beenthere
« Reply #7 on: February 06, 2015, 10:43:24 AM »
Ash or oak should be good.. I'd pick the ash.
But "rive" out the handle blank, don't saw it out. By splitting the wood, you will find the true grain pattern and can fit your handle to the natural curves of that grain. Then work the blank down to the final handle shape and size.
Offline trapper
« Reply #8 on: February 06, 2015, 03:51:53 PM »
Didn't one of the guys from canada give us a step by step on making an axe handel a couple years ago?
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline kevin19343
« Reply #9 on: February 06, 2015, 06:00:33 PM »
Cutting down the original handle and refastening it will change the balance of the ax. Get a plastic replacement and be done with it.
Offline thecfarm
« Reply #10 on: February 06, 2015, 07:07:42 PM »
Offline rjdankert
« Reply #11 on: February 06, 2015, 07:21:01 PM »
Hey Guys
Is this repairable?   . . .
I can't tell looking at the pictures, but if there is enough wood left to fill the eye, then it is.  I've seen this done many times when someone wants to preserve an old handle.  The shorter length is no problem.  It's very common to see 30-36 inch handles on 3-4 pound heads.  It just depends on the user's preference.
Offline lowpolyjoe
  • Hey
« Reply #12 on: February 06, 2015, 09:51:13 PM »
Offline SwampDonkey
  • Large Tooth
« Reply #13 on: February 07, 2015, 05:00:18 AM »
Avoid the oak it will shear off. Ash or ironwood or hickory. Uncle had some oak handles for axes one time from a fisherman friend. He wasn't impressed.  :D My uncle hand split a mountain of wood over the years. His uncle always made ironwood (hop-hornbeam) handles. The handles never broke from the force of splitting, but the wood your splitting does not always split neatly in two like white birch, so it chews into the handle wood over time. That's what usually takes them out.
Marcel has made a few handles, I have made some from maple. Never broke one yet, and my old axe has had a handle I made 30 years ago. Of course mine's a camping axe, I'm not splitting a mountain of firewood. ;D
Move'n on.
Offline isawlogs
« Reply #14 on: February 07, 2015, 10:48:56 PM »
Ray .. thanks for bringing that back up, been a while that I put that together. I've added a few handles since then.   :)
  I'll be glad to help any out if questions need answered   :P
   Marcel
Offline lowpolyjoe
  • Hey
« Reply #15 on: February 08, 2015, 08:08:32 AM »
Thanks a lot Marcel!  That was a great thread you wrote.  I'll share my project if I ever have a chance to work on it and i'll probably have some questions :)
Offline Al_Smith
« Reply #16 on: February 12, 2015, 09:16:17 PM »
 :D I've broken so many axe handles I used to buy them 2 or 3 at a time .Anymore you have to go through about a dozen to find a good one ,even Ames .
Offline SwampDonkey
  • Large Tooth
« Reply #17 on: February 13, 2015, 04:25:44 AM »
You shouda had a Garant.  ;D :D
Something funny, my grandfather was in Rhode Island visiting relatives. He picked up an axe down there, made in Canada stamped on it. My uncle began using it for splitting firewood in March-April. The metal wasn't tempered for an axe, as the thin edge crumbled to bits.  This time the handle outlasted the head. :D
Move'n on.
Offline Al_Smith
« Reply #18 on: February 13, 2015, 04:56:08 AM »
I'm not certain if you can find any modern made axes that are good splitters.They seem to be made for combination stuff and aren't well suited for either .Long skinny head.
I have a 5 pounder ,hand forged that is likely in excess of 100 years old.Short broad head that was made for splitting.
In addition to that I have my dads double bit cruiser that has never been left outside,never had the handle replaced and never had a file used on it .Reason no file,steel is too hard .It's as old as I am .
Offline Al_Smith
« Reply #19 on: February 13, 2015, 05:05:53 AM »
Now as far as recycling a broken handle for an ugly stick .When I was a teeny bopper I had a trap line .I used old axe handles,sledge hammer handles and shovel handles to dispatch critters in the traps .A live 'coon or muskrat can flat eat you up if you aren't carefull  :o
Always had a bunch of broken handles,I could break them all expect a pick handle .
question
Repair to a beam drill handle
Started by routestep on Timber Framing/Log construction
Last post January 23, 2008, 02:20:47 PM
by Jim_Rogers
Top handle saw-which one
Started by Tinbeers on Chainsaws
Last post May 05, 2018, 01:45:51 AM
by beauj5
Can I handle it?
Started by Brad_S. on Sawmills and Milling
Last post March 27, 2006, 09:35:29 PM
by wiam
How big a bar will a 441 or 460 handle?
Started by OneWithWood on Chainsaws
Last post April 23, 2008, 10:52:44 PM
by Danny Dimm
