Arborwear
Author Topic: how to layout this 24" Red Oak  (Read 1717 times)
Offline brownloggin
  • timber!
« on: February 01, 2015, 06:07:02 PM »
i'm looking to do some timber framing (rookie).  i have this nice red oak that i'd like to use. its 24" in diameter at base and 18" about 20' up the log.  can i get two 6x8 beams out of this or do i need to take the full heart and go with one?  what should i expect out of this log.... its free of knots.  after 20' it does "Y" off, should i stay away from cutting by this?  i'm anxious to see what i can get out of it! thanks
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
Re: how to layout this 24" Red Oak
« Reply #1 on: February 01, 2015, 08:02:03 PM »
What ever you do, Id go ahead and put sealer on the end / ends.
Where's the Spoon?
Offline Lawg Dawg
  • True South Sawmill Lumber
« Reply #2 on: February 01, 2015, 08:30:52 PM »
I'd say go for it(2 beams)!  Life is short, and you just don't get a chance to mill logs like that everyday.  Nice and straight, clear, tight ring, etc.
LT 40 Wide 999cc
John Deere 4000, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong.
True South Sawmill Lumber,  located  approximately 45 miles south of Charlotte, NC
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #3 on: February 01, 2015, 09:48:36 PM »
I'd watch out for that first slight bend to the right. I'd buck it right there and make a second log above that.
All logs have knots. It will be interesting to see what they are like when you mill it. ;D
Offline Evergreen Man
  • You have to laugh or cry...I prefer to laugh.
« Reply #4 on: February 01, 2015, 09:50:42 PM »
I'm intrested to hear what you guys have to say about this one :)
Is that off centre pith gonna give him a little trouble?
Would he want to take the beams out of the "tension wood" above the pith and over size it so he can trim the bow out later?
I have no idea what I'm talking about and probably sound like an idiot, but I'd rather sound like an idiot and learn then keep my mouth shut and remain ignorant :D
I used to think I was crazy, then I realized: I'm the only normal one.
Offline BCsaw
  • Love to build, fabricate and make saw dust!
« Reply #5 on: February 01, 2015, 10:23:24 PM »
I would take a timber from the centre, heart centred, and take lumber from around it.
Oh ya...2nd what Poston said, seal the ends!
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
Offline brownloggin
  • timber!
« Reply #6 on: February 02, 2015, 05:10:39 PM »
"IF" i took two beams out of it, split the heart.... how much could i expect a 20'er to move?
-what does sealing it do?
-if you look down the log at the "Y", can i cut through this to the left?  it is the main part of the tree.
Offline beenthere
« Reply #7 on: February 02, 2015, 06:08:03 PM »
Do you care if the beams you saw out are straight?
Would assume you do, so unless you just want to experiment with the two beams and sawing through the crotch wood (Y to the left), I'd also say stick with one beam, pith center.
Much more likely to have a good outcome. But then again, you may get lucky and fool mother nature.
;D
"sealing" is just to keep the drying end checks from running in the log ends as much.
Offline brownloggin
  • timber!
« Reply #8 on: February 02, 2015, 10:00:30 PM »
sometimes i hate the truth.  but its better to be safe than sorry.. i have a lot of work in draggin this monster log out of the woods.  my duramax proved itself worthy.  i'll just have to think of some more ways to use the wood????  ;D
Offline 5quarter
« Reply #9 on: February 02, 2015, 11:34:05 PM »
Do you have to have 6x8s? If you split the pith, they will certainly bow on you. you can get 1 6x8 heart centered That will most likely be fine. but you can also get 2 FOH 4x12s  with some wood to spare, for example. Take a black sharpie and draw a 4" box around the pith. as long as you don't cut through the box, you have a decent chance to get nice, straight timbers. As a rule, I like to cut a little oversize to account for some movement, and then resaw them to final dimensions.
